Question about Sylvania SRT2232S 32" TV
Needs vertical height adjustment - Sylvania SRT2232S 32" TV
  • 647 Answers
Is the picture stretched or shrinking and is it distorted or have lines? There are no vertical Height adjustment the circuit is prest and there is likely a problem in the vertical o/p circuit.
The problem is a bad Vertical Output IC (usually mounted on an aluminum heat sink with the part on it labeled LA78?? ) and 1 or 2 bad capacitors. Some times you can even fix the problem by re-soldering the contacts of the IC- To find the IC follow the 4 wires that come from the Yoke (which is a contained coil of wires slipped over the neck of the picture tube(s)) back to the board. 2 of the wires go to the horizontal o/p and 2 to the Vertical o/p the thinner gauge wires are for the vertical.
Posted on Sep 28, 2009
Trayl bike owners manual. or how do I adjust the height of the handle bars?
Your bike has a modern "threadless headset" which usually allows very little vertical adjustment. See this page for an explanation of how to change height on that style:
How to adjust handlebar height BikeRadar
If you can't adjust enough that way you can try buying a shorter stem or one with a steeper angle,. The final option is to buy a "stem riser" - Google the term for more info - needs to have correct dimensions for your bike
It's best to get advice at a bike shop as to what option is best for you..
Jun 04, 2017 | TRAYL Cycling
What is the correct vertical headlight height [in millimetres] for my 93 Suzuki rf600r motorcycle, with tyre size 120/60 ZR17
I wouldn't as concerned about specs as function. Simply park your bike say, 25 feet from a closed garage door or wall and observe where the light is shining. If your new tire is a bit taller, lower the light, shorter raise it up. When you ride, adjust it to your needs and wants, just take into account you don't want the light shining up and left to annoy other drivers.
Jul 18, 2014 | 1993 Suzuki RF 600 R
Adjust vertical height kg 55lh55
To adjust the height of the picture, you have to enter its service mode option, and should adjust the vertical amplitude data value, accordingly. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy.
Mar 24, 2014 | LG 55LH55 55 in. HDTV LCD TV
Top of screen disappeared...cant see score of game
The Height adjustment is off... look in the back of the TV set, it has some knobs in the back, one should be vert.lin for Vertical Linearity adjustment, and there is another call Vert.Hgt. for Vertical Height adjustment. try adjusting the Vertical Height first with someone watching in the front of the big TV to see if the top comes back into view, you might have to adjust the knob very slowly one way then the other way, to make this adjustment. If it doesnot adjust take it to a TV shop to get it repaired.
Good Luck.
Nov 11, 2010 | Hitachi 57F500 57" Rear Projection...
My JVC AV-27020 TV that I bought used on craigslist needs videa adjustment. The video needs to be reduced so that the entire pictures fits on the monitor. For example, if I'm watching a baseball game I...
the problem is the vertical height adjustement but usely you dont need to adjust this setting its inside
the set , thats is probably a capacitor in the vertical deflection circuit chips but you can disconnect the set and open it and look for a mini control wheres its write v height because the guy sale you the tv should have a problem with this;i highly recommend that you dont do wath i say but call a tech at home and make it fix its an hour jobs about
its not verry expensive...
hope that will help you ps if you decide to open it and fix that by your self watch you have very high voltage inside it can arm you seriously
regards allan ,pro tech..
Oct 03, 2010 | JVC AV-27020 TV
Diamond TV
The vertical height driver that controls the height of your picture has weakened and needs to be adjusted. If you are somewhat handy you can do this yourself. It requires that you gain access to back of the set & remove the cover. Once removed, locate the vertical height & centering adjustments. Sometimes they are located on the main board & other times are located on the color gun driver circuit board that is plugged into the end of the picture tube.
Respond to this post if you need additional assistance. Good luck!
Mar 14, 2008 | Televison & Video
Adjusting vertical height
I looked for info for your the Mct-2051 & imagine my surprise that Magnasonic not only doesn't have a manual for your model they don't recognize the model #. Excuse my sarcasm.
If MCT-2051 is not a typo, then the closest I could find was an MCT-2053 & there was no mention of a vertical height adjustment by software control. From my past experience this adjustment can only be performed by a TV tech because you need to access the inside of the TV.
The fact the picture has shrunk this much means that the vertical height driver is failing & eventually you will see nothing but a vertical line, stretched across the screen. Which will mean, that do to Magnasonics' lack of support, you'll be out of luck.
When shopping in the future for a TV try to stay with name brands who will support their products.
By the way, where did you hear that you could adjust the VH utilizing the remote? That could possibly be a function of digital device like a computer monitor, not an analog device like your TV.
Feb 25, 2008 | Televison & Video
Vertical height adjustment on Magnavox 19 inch LCD HDTV
try to adjust at the vertical section.hope this will help
Feb 01, 2008 | Philips 19MF337B/27 19 in. LCD Television
Vert hight adjustment
How do I adjust the vertical hight of a SANYO 36" TV. vertical height can adjusted by height conrol that is inside tv in your case you can also adjust by remote control. for that you will have to open menu by giving service code. regards thanks
Sep 10, 2007 | Sanyo AVM-3659S 36" TV
Sylvania SRT2232S 32" TV Logo
301 people viewed this question
Top Sylvania Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
