Question about Acer Aspire 5500 5570-2609 Laptop
Blinking yellow light on Acer Aspire
My daughter had a problem with her laptop not booting up. When she pressed the "on" button, the yellow light would blink several times but would not turn on.
After eliminating the possibilities including checking the voltage etc., from the power cord, I grab a flashlight and looked into the ac adapter receiving port on the laptop and found that the back of the housing had broken off, probably from forcing the adapter plug in. The piece that broke off was attached to the center (positive) pin and was soldered to the MB. When the piece broke off, it separated from the MB. With no connection to the MB or the AC adapter, the battery couldn't charge and that is why the yellow lights would blink.
I hope this helps as a possibility for your situation.
  • 558 Answers
You can find the broken piece on line to purchase,This can be repalced by soldering it to the motherboard.You will need to find someone to replace this probably a tv repair technician who is good at soldering small circiut boards.You can also purchase the motherboard and replace it
Good luck
Posted on Sep 28, 2009
If the computers lights are just yellow what does that mean?
Just Yellow when? Tell us what happens time you put the power cord in and press the power button? Does it try to boot? Do the lights blink? Hear any beeps? Hear any fans? Does anything ever appear on the screen?
When you plug in the power cord is there any lightswhatsoever on the laptop, where the plug goes in or on the AC Adapter of thepower cord?
When you press the power button do you hear fans running, hard drive spinning,lights on the computer, hear any beeps or lights constantly blinking, hear theDvD/CD drive click and the light on the drawer of the DvD/CD turn on for asecond or two? If so the laptop is trying to boot or may have booted, butthe screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with thelaptop and why it is not booting. Most times it's a motherboard issuewhen you hear beeps or blinking lights continuous.
Maybe your power cord is bad if you don't get anything to happen whatsoeverwhen you press the power button. And if that's true maybe you wasoperating off the battery the last time you had it on and since the power cordis bad, it was not charging the battery so the battery is drained and the powercord is bad.
Maybe you have a Static Charge Buildup. Remove the Power Cord, Remove theBattery, then Press and Hold the power button for 30seconds. After 30 seconds plug the power cord back in (leave the batteryout) and hit the power button to see if it boots. If it does, you can putthe battery back in and let it charge. Remove the Power Cord, Remove the Battery, Remove the Memory Cover on the bottom of the laptop and remove one of thememory chips. Set the chip aside then try rebooting the computer. If it boots, then you know the memory chip you set aside is bad so mark an x onit with an ink pen. If it fails to boot then move the chip to the nextmemory slot and try rebooting. If it fails take the chip out and set itaside, then put the other chip in and try booting it in both slots. If itboots, just to verify that the chip set aside is bad, mark an x on it and putit into the open memory chip slot and try booting.
Apr 07, 2012 | Acer Aspire 5500 5570-2609 Laptop
Hi i have an acer aspire one 523h-2588 and in the bios it says "IDE0 HDD Password is : Frozen" how can i get rid of it to use my laptop again cause it wont let me see my windows
Acer Aspire One BIOS Recovery The Acer Aspire One has a built-in BIOS recovery routine, which can boot into a minimal BIOS environment via a special boot block to re-flash the BIOS, even if the system does not pass POST and does otherwise not boot anymore. This procedure is also known as Crisis Disk.
First format an USB flash drive with FAT. It does not need to be bootable.
Download the latest BIOS, and extract all files. Put both FLASHIT.EXE and the BIOS file with FD suffix in the root directory of the flash drive. The files must not be in a folder. Rename the BIOS file to ZG5IA32.FD before proceeding. It only works with this exact filename.
Turn the AA1 off, and verify both battery and AC adapter are plugged in.
Press Fn and Esc simultaneously, keep them pressed and press the power button. Release Fn+Esc after a few seconds. The power button starts blinking at this point. Press it once. The AA1 will now access the files on the flash drive and initiate flashing the BIOS. After a while the power button stops blinking, and the AA1 reboots by itself. Wait patiently.
If it doesn't reboot, but keeps blinking, wait at least a few minutes before turning it off, and try again.
Oct 06, 2011 | Acer Aspire One AO532H-2527 Netbook
The cmos on my laptop(acer aspire 5536) was wiped and when i turned it on it wouldnt boot up just blank screen and a fan still works plus the power button still glows and the little yellow and blue lights...
yellow light indicates that it is offline mode/ log off/ power save mode/ hard reset by pressing power button for 10 sec and restart machine in safe mode that it could solve any h/w related problem
May 30, 2011 | Acer Aspire 5500 5570-2609 Laptop
Power on but screen blank acer netbook AOA110-1588 model ZG5
hello sir
Downloads the bios file from this site.. Extract into a formatted usb .. Plug the charger ... and plug the usb .. keep pressing FN+ESC button then turn on the laptop u can see light is blinking .when light stop blinking release buttons wait for 5 min ..System will restart.. And u can see display.. Thanks
http://macles.blogspot.com/p/acer-aspire-one-bios.htm
Oct 22, 2010 | Acer Aspire One Netbook 8.9" Notebook
It turn on but is a blank screen.
for acer aspire one
This is bios problem. need to update bios.
Downlaod the bios file from this site.. extract into a formated usb .. plug the charger ... and plug the usb .. keep pressing FN+ESC button then turn on the laptop u can see light is blinking .when light stop blinking relase buttons wait for 5 min ..system will restart.. and u can see display.. Thanks
Oct 08, 2010 | Acer Aspire One PC Notebook
My aspire aoa150 wont start up. turns on but screen remains black
Oct 08, 2010 | Acer Aspire One Netbook 8.9" Notebook
It powers on, but the screen doesn't pop up...used less than 3 months...just doesn't boot up.
Downlaod the bios file from this site.. extract into a formated usb .. plug the carger ... and plug the usb .. keep pressing FN+ESC button then turn on the laptop u can see light is blinking .when light gose off u can relase buttons wait for 5 min ..system will restart.. and u can see display.. Thanks
http://macles.blogspot.com/p/acer-aspire-one-bios.html
Sep 05, 2010 | Acer Aspire One PC Notebook
Laptop wont switch on fully
Did you press F8 as you boot up to get boot up options and did try the Last Known good Configuration and Safe Mode?
If these didn't work I suggest you re-install Windows.
Apr 10, 2009 | Acer Computers & Internet
Acer Aspire 5500 5570-2609 Laptop Logo
745 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
