Posted on Mar 14, 2017
Surround sound isn't working with TV or PS3
My TV has an option for external speakers and I've been trying to connect it to my dvd/surround sound. It should be simple. There are two audio out jacks on the TV and there are audio in jacks on the receiver. There are four audio in jacks on the receiver, two for TV and two for an aux. I tried plugging it into either one, but neither worked. I plugged in my PS3 and it doesn't work either. If I turn up the volume to a high setting the speakers will make a scratchy buzzing sound, as if the audio was coming through. I'm pretty sure that I've exhausted the options for connecting. The speakers work because when I play a DVD in the receiver it is fine. I'm starting to think that it is the audio in ports that are some how damaged. Any suggestions? BTW, the warranty has expired. And I've made sure to toggle the settings on the receiver to TV or Aux.
4 Related Answers
Anonymous
  • 84 Answers
  • Posted on Jul 31, 2007
SOURCE: Surround sound problems.
Dolby 5.1 is not supported via either of the Aux inputs. Be sure to check your main menu/audio setup screen to ensure that "stereo" is not selected. If it is, DVD's will not downmix, giving you only 2.1 stereo.
Anonymous
  • 5 Answers
  • Posted on Nov 24, 2007
SOURCE: how do you connect headphones to the philips mcd139b dvd micro theatre system?
you need to be sure about what kind of plug do you have...and try with a convert from RCA to your headphone's plug...
Anonymous
  • 3 Answers
  • Posted on Dec 14, 2007
SOURCE: Can't play AUX inputs through Panasonic surround sound
Check the TV audio output setting. There may be 3 settings for audio output. Fixed/variable/none. Try all of the settings, and see if you get your audio back. If not, try a different cable between the TV and DVD player. I suspect this is a red/white RCA audio cable.
Anonymous
  • Posted on Dec 06, 2011
SOURCE: cannot get surround sound to work with Philips hts3106/f7 andonic tcp50g25. It works fine for Blue ray via the hdmi out of philips dvd/receiver, but not for xbox or cable etc (only works in stereo).
i have the same system. all you have to do is when you connect your xbox 360, press the surround button on the remote and then use the arrow buttons to change it to dolby music pro2 or multi channel audio. same goes with any device you connect. hope it helps. In my case the xbox is connected to the Tv via HDMI and bluray player is connected to xbox via compoent cable
Onkyo surround system. The subwoffer isn't making sound. I've tried all remote settings. No luck though. Any ideas?
Try checking that the wires are properly connected to receiver. Maybe the sub speaker is blown
1helpful
My Sanyo DP23845 23 In. LCD Television does not have any options under set up beside color-how do I add channels?
HDTV inherently provides a superior sound quality simply because the sound of HDTV is digitally transmitted. The difference in sound between an HDTV television and an analog television is rather noticeable. In fact, it is directly analogous to the difference between the music on CD's compared to the music on audiocassette tapes.
The difference in sound quality provided by HDTV televisions and programming does not end there. Many HDTV programs are also broadcast in Dolby Digital 5.1 surround sound, but in order to take full advantage of this technology, it is necessary to have the right equipment.
Dolby technology has been created by Dolby Laboratories, Inc. This technology is the most renowned provider of digital audio technology. Also, Dolby Laboratories is known for reliable and superior products. For these reasons, Dolby Digital Surround has become the standard for HDTV. Many television manufacturers substitute their own surround sound systems, but they cannot live up to the reputation and performance of Dolby. Therefore, it important to check the specs on an HDTV television before buying in order to ensure that it uses Dolby Digital Surround.
When using Dolby Digital Surround Sound, there are three options for set up. The first option is to buy a television with high quality center channel speakers, woofers, tweeters, and Dolby technology installed in the television. With this option, it is unnecessary to buy addition equipment to take advantage of Dolby Digital Surround Sound.
Another option for taking advantage of the Dolby Digital Surround Sound with an HDTV is to connect an external set of surround speakers to the television. With this option, the surround sound set up includes a front pair of speakers, a surround pair of speakers, a center channel, and a subwoofer. Sometimes, the front speakers are "powered towers." This means these towers include subwoofers.
The placement of these speakers is very important for the quality of the surround sound. The Center Channel Speaker should be centered either above or below the television. The Front Left and Right Speakers should be placed in an arc formation in line with the Center Channel Speaker. The Surround Left and Right Speakers, on the other hand, should be placed to the left and right sides behind the listening position. Many people choose to wall mount these speakers.
The third option for taking advantage of the Dolby Digital Surround System included in an HDTV television is to use an external set of front speakers can be connected to the HDTV television. This configuration is useful if there is not enough room to set up the external surround sound system and the HDTV does not come with Dolby Digital Surround installed. This isn't true surround sound, but it is a viable alternative to those who can't take advantage of the first two formats.
The audio and video outputs of the DVD or VCR can be connected to the AV receiver's video outputs. If a separate DVD and VCR need to be connected, one can be connected to the VCR1 connection and the other can be connected to the VCR2 connection. The AV receiver's VCR video and audio outputs should then be connected to the audio and video inputs of the DVD and/or VCR. In this way, the DVD and/or VCR will be able to record video signals that come through the AV receiver and the VHS tapes and/or DVD's will be able to be viewed on the HDTV.
To take full advantage of the Dolby Digital Surround Sound technology, one of the video outputs of the DVD player and/or VCR needs to be connected to the AV receiver. The digital coaxial audio or digital optical connection must also be connected to the AV receiver.
How do I connect my CD player?
A CD player can be connected to an AV receiver. The CD player's digital audio outputs can be used to connect the CD player to the AV receiver. A CD-Recorder can also be connected the AV receiver by using the Audio Tape Record/Playback input/output loop connections. In this way, the CD-Recorder will be able to function much like a standard audiocassette deck.
What else will I need?
Besides the basic electronic equipment needed to set up Dolby Digital Surround Sound, it is necessary to have connection cables. This includes video, audio, and loudspeaker connection cables. These cables need to be at an appropriate length in order to set the speakers in the proper position for optimal surround sound quality.
Just bought lg ht44s home cinema to go with my lg tv connected hdmi lead can get radio and dvd surrond sound but not through my tv
Try going into menu-sound and enabling external speakers. I am not sure if this option is available. How is tv connected to your surround sound receiver? If it is component cable, try plugging them into the back of your surround sound receiver where the tv input is labeled. Then turn on your receiver and select tv from the mode button.
I cannot get sound from the tv through the surround sound, speakers all tested and work ok and dvd sound comes through ok when playing dvd, radio works fine also, worked fine 2 days ago with sharp tv, have...
Hi, You have to make sure you are using the "audio out" from the dvd/surround into the "audio in" on your TV also in some case TVs will need to change the "input" with your remote to see where you connected your dvd/sur also some TVs have a switch for "n" or "off" for internal speakers and also you could have that option in your audio menu on your TV, Hope it help, good luck. Mike
1helpful
PS3 surround sound
You will need the optical cable. My receiver only passes video through the hdmi. So I hooked up the HDMI cable to the tv, and the optical cable to the receiver. Once that is done you have to go to the audio settings for the PS3 and chose audio through the optical.
Surround sound speakers distort when playing blue ray dvd.
what you have to do is turn off your system then turn it on until you get 2 beeps. then go through the on screen instr.
Unable to get surround in dvd mode but can hear thru tv speakers?
Is your DVD player hooked up to a surround sound receiver, or directly to your television?
No sound through tv speakers
Well the problem is that the PS3 only allows output on one channel. So, this is only going to be optical out, or hdmi, or even AV. You only get one option for the output.
Now, if your TV has the capability.. Run the sound through the HDMI to the TV and then let the TV output the digital sound to the surround system. This will give you the option of turning off the surround and re-enabling the TV's stereo speakers.
I hope this gives you an idea of what the problem is. If I were you, I'd just do as I said. This is exactly how I have mine setup. I have a 600w sub on the surround, so late night movies can't be played on it without the neighbors being woke up. So, I simply disable the TV's output and use it's speakers. :)
3answers
Tv sound & surround sound
Go to Settings/SoundSettings/AudioOutputSettings/AudioInputConnector or DigitalOut depending on type of input you are using for surround.
6answers
Connect PS3 for playing/viewing blue-ray thru surround sound
Connect the PS3 to your TV with the hdmi cable and to the surround sound system with a digital optical cable, then set your PS3 to output sound through the optical port (through the sound options menu) and you're good to go!
Top Philips Audio Players & Recorders Experts
 Grubhead
Grubhead
SmartAviator
SmartAviator
ZJ Limited
ZJ Limited
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
