Question about Akai PDP4273M Television
HDMI Died on Me too
Randomly today when I went to turn the TV on, there is no picture available. I also have everything go through the HDMI. I don't understand why it is doing this. I have been trying to figure it out all day.
  • scopatz Sep 30, 2009
    The HDMI is what has died. Some of the other (non-digital) inputs seem to work. But why have the TV if it can't get an HD signal in? I am going to have someone come by and look at it.
  • Akai Master
  • 8,457 Answers
Take the HDMI out tries the tv work at all,don't have to change the whole board.
Posted on Sep 28, 2009
How do i connect my computer to my rca tv
Hi, You will need to provide the TV model and Laptop model.
This will allow us to determine what type of input/output ports is available for the TV & laptop.
Commonly, today's devices simply connects together through a HDMI cable, which functions as both your audio and video connection.
Does your computer have an HDMI port?
It should look like the the middle port in the picture below.
Does your TV have an HDMI input?
Feb 05, 2015 | Acer Computers & Internet
I am unable to get a picture on hdmi when i connect my ps3, but am able to get sound when i use ps3 controller. any ideas ?
Steps
  1. Step 1 Check for an HDMI port Check the back of your television for an HDMI port and refer to your owner's manual for your television's resolution. A resolution of 1080p offers the highest quality.
  2. Most PS3 systems support 1.3 HDMI, but older systems may need a software update from the 1.1 or 1.2 version.
  3. Step 2 Disconnect cables Disconnect all the cables and adapters from the back of your PS3, and then unplug your TV to reduce the risk of shock as you work.
  4. Step 3 Connect HDMI cable Connect the HDMI cable. Reconnect the power cables on both the TV and the PS3 system.
  5. Step 4 Hold power button Hold down the power button until the PS3 beeps and continue holding it for an additional five seconds until the system makes a second beep.
  6. The Playstation 3 should detect the high definition cable and automatically adjust the settings to give you the best picture and sound possible.
  7. Step 5 Test the connection Test the connection. If the HDMI cable isn't working, turn everything off and reconnect the original cables to manually change the settings.
  8. Step 6 Adjust the settings Turn the system back on, select Settings, Display Settings, Video Output Settings, and then HDMI. Repeat the process for your Audio Settings. You can now experience your games with the highest video and audio quality available.
Dec 01, 2014 | Sony KDF-E50A12U 50" LCD HDTV
Why does disc tray open randomly Samsung ht-em54c
I had the problem of the disk tray opening and closing randomly but finally fixed it. I went thru a number of steps so I don't know which combination or individual step fixed it but I think it was changing the HDMI cable from the TV to the Blu ray player that finally fixed the problem. Previous to that I had removed the disk player and got the audio to work with only the TV and used one of the HDMI inputs as the output from my PC. That way I could play DVDs on my PC and run it thru the player to get audio in the speakers and video on the TV. Every once in a while the tray would try to eject (even though the player was not there). Finally I changed the HDMI cable to an older cable, the one between the TV and the player and it started working! I then put the disk player back in the unit and it all worked, everything!! Good luck!
Jul 22, 2014 | Samsung HT-X50 System
No Signal when HDMI connected with TV and cable box
Replace HDMI cable first, then check whether your box works on HDMI out. Try connecting box using other out (USB, VGA, DVI, DP, cable)
Apr 25, 2017 | Sony BRAVIA Televison & Video
Magnavox tv turns off by itself
hello, i don't where you live but there are no analogue signals being broadcasted any more. if your in england you will need a freeview box, some tv will switch off if they are not receiving a signal
regardsshaun
May 11, 2012 | Toymax Magnavox 37MF337B 37 in. LCD TV
My Samsung HP-T4234 is not turning on. It "clicks" constantly as though it was trying to turn on but doesn't. If it should turn on, after a few minutes it turns off the picture and continues to "click". I...
I found it was the HDMI plug-in on the tv that my dvr plugs into went bad. There are two HDMI ports. I plugged the dvr into the other HDMI port and I no longer have any problems.
Apr 16, 2010 | Samsung HP-T4234 TV
I have a dell studio 1537 and i am not able to get picture when i connect my laptop to tv using a HDMI. i have tried everything possible but i cant seem to get the picture
make sure your pc is powered completely off(not a restart but a shutdown). hdmi cable should be unplugged. plug cable to tv first, then turn on tv. Now power up pc and it should recognize the tv. Use projector mode if available on your pc. do not unplug hdmi cable while pc is on or you may have to repeat process.
Mar 17, 2010 | Dell Studio 1537 Laptop
51" no picture, no sound, boutht 12/2006
j ai le probleme sur la mienne , cest qu oi la solution
Sep 23, 2009 | Hitachi 51F59 51" HDTV Projection...
HDMI port not working
I have the same problem - its a HDCP handshake issue. Sony says the firmware in the Westinghouse TV needs to be updated - Westinghouse says that they have firmware updates for some models depending on your TV's serial number, otherwise they are working on firmware updates for the rest of us that should fix the problem. Call Westinghouse to see if you can get updated.
Jul 13, 2009 | Westinghouse SK-19H210S Television
Televison & Video Logo
137 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Radames Pagan
Radames Pagan
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
