Question about VistaQuest VQ-5015 Digital Camera
I'm missing the camera card. How do I get a
I'm missing the camera card. How do I get a replacement card?
    President:
  • 1,187 Answers
This 5MP (Megapixel) camera has 16MB built-in memory and has an SD card slot.
Your camera uses either MMC of SD memory cards.
Radio Shack, BestBuy, Fry's, Office Depot, Office Max, has them.
Start with a 1GB SD card (Don't use MMC).
A 1GB card will hold almost 500 pictures at maximum resolution (5MP).
(Fry's is lowest cost, then Best Buy)
Posted on Sep 28, 2009
Testimonial: "Thank you. That will save me replacing the camera. So kind of you to respond."
I have a concord camera and the memory card is missing and I am attempting to ascertain if it is possible to purchase a replacement
You didn't specify the model of your Concord camera, but most of them take SD cards. SD cards are getting a little hard to find, but you should still be able to find them at most department, electronics, and office-supply stores. Check the manual to see whether your camera also can take SDHC cards. SD cards are limited to 2GB or smaller, while SDHC cards go from 4GB to 32GB.
Mar 03, 2014 | Concord Cameras
I Purchased a new SDHC card from Argos which was 4 GB as the one that came with my Nikon coolpix 3700 is a 16mb I put this new one into my camera and the camera showed that you couldn't use this card,...
Your camera will accept a maximum SD card capacity of 1GB. It simply isn't capable of handling anything of a larger capacity and in particular is incompatible with the more technically advanced SDHC cards.
Your fix is to either replace your camera with a later model or to stick to using SD cards with a maximum 1GB capacity.
Please take a moment to rate my free answer.
Oct 06, 2010 | Nikon Coolpix 3700 Coolpix 4200 Coolpix...
I have replaced the battery and memory card, the camera keeps saying I need to format the card, but then it says it is formatting, then gives another message saying the card needs to be formatted....
If the memory card replacement is an SDHC model card the Kodak z740 will not work with it. The memory card has to be a standard SD card of 2 gig size or less to properly function. Take card out and turn on camera. See if you get same error. You should get missing card error but otherwise be able to operate camera controls such as zoom, flash, etc. If that is fine find old card you used and place back in camera... or purchase a standard SD card from Walmart for 10 dollars
Jun 11, 2010 | Kodak EasyShare Z740 Digital Camera
I'm looking for a USB connector for my Fuji DX-7.
Your camera is intended for serial connection.
You can get RS-232 to USB adapters, but I'm pretty sure that they wont work with your camera. DX-7 was originally equipped with 5V Smartmedia cards. Newer (!) type cards are 3,3V. You can get a card-reader for 3,3V cards but not for 5V cards.
You can tell the difference between 5V and 3,3V by the missing corner of the card. Seen from the "golden side" 3,3V cards are missing upper right corner, while 5V cards are missing upper left corner.
I don't remember if DX-7 could use both types.
Dec 07, 2009 | Fuji DX-7 Digital Camera
1 pin bent resulting in "Card Error" message. Attempt to straighten pin broke it off! Camera now appears to work well. What other problems might this missing pin create? Should I keep the camera or replace...
Some of the CF card pins don't do anything. It could be one of those that broke. If, when it was bent, it shorted one of the other pins, that may have caused the "Card Error". Removing the pin may have no negative effect.
Jun 07, 2009 | Olympus EVOLT E-500 Digital Camera
Missing pictures
Lets check the SD card first.
Take out the SD card and put it in external card reader connected to computer.
Copy/transfer all the photos from the SD card to computer.
goto My Computer and right-click the 'Removable Disk' (the SD card drive) and click Properties.
click Tools and click Error checking - Check now button
select the option 'automatically fix file-system errors' and click Start button.
if any errors was found and fixed, you can also Format the SD card. And your SD card should not drop photos again.
Now put SD card back in the camera.
Now take 20 test photos and check if something is missing.
if not take 20 more test photos and check if something is missing.
if all is ok then you can delete all test photos and start taking normal photos.
May 31, 2009 | HP Photosmart R817 Digital Camera
Missing pictures
Hey flowernthe,
The error message “card cannot be read" means there was and error when the camera tried to access the memory card. To fix this you should make sure you are using the right kind of memory card, which for this kind of camera is a SD card, and it does not support SDHc cards. Since this camera uses SD cards I would make sure the slider on the side of the card is not set to the locked position. If this doesn't help I would make sure the memory card connecters are clean, and if they're not you can use a rubber eraser to clean them up. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
Jun 11, 2008 | Nikon Coolpix 4600 Digital Camera
The card wont go down its like the spring is missing or something what should I do? its on my camera canon sd1000 power shot
chech your memorycard in computer backup all data into pc. & format your memory card. if the problem presist replace your card
Mar 03, 2008 | Sony Cyber-shot DSC-W55 Digital Camera
"no CF card"
try reformatting the card. otherwise you either have a defect in the card that does not manifest itself while not in the camera, or you have a broken pin in the cf slot. look down it to see if all the pins are upright and none missing. next, you can try another cf card. if you get the same reading then its the camera.
reset the camera by removing the main battery and reinstalling it. if that does not work, then you will likely need to send the camera for repairs. if you have broken or missing pins, it will also occasion a repair shop visit.
good luck
mark
Dec 24, 2007 | Canon Digital Rebel / EOS-300D Digital...
Card not initialised
You can recover the missing pics off your card get, there are some image recovery programs available on the net and most camera shops will offer a card recovery service but dont format before you get pics recovered.
Not formatting a card is bad. They need to be formatted on a regular basis because deleting images from card does not remove them and the next image taken only overwrites the old ones.
Dec 07, 2007 | Fuji FinePix F11 Digital Camera
VistaQuest VQ-5015 Digital Camera Logo
102 people viewed this question
Top VistaQuest Cameras Experts
Tony
Piyal Perera
Piyal Perera
Are you a VistaQuest Camera Expert? Answer questions, earn points and help others
