Question about Riccar R1570 Mechanical Sewing Machine
My 40 year old sewing machine doesn't hold stitches. Is it worth it to try to fix?
  • 10 Answers
Old is gold try to remodel it......... don't sell it...........
Posted on Sep 28, 2009
My kenmore 22 stitch sewing machine I bought in 1990; it doesn’t reverse anymore. How do I fix it
Those older machines do need regular cleaning and oiling. I suspect the oil has dried and caused the switch mechanism to seize. As time goes on, more parts may seize, so it's probably important to get it addressed soon. It could eventually damage the motor if the motor is trying to move seized parts. Well worth the expense if you value your machine.
Mar 19, 2018 | Kenmore Sewing Machines
Do you have experience with a Nelco Sierra 234F Serger? How is the quality of stitching, how easy is it to use and problem free is this machine? Are you still able to get parts for the machine?
As far as I am aware, Nelco hasn't been made for quite a few years--probably since sometime in the 1970's is my guess. I have an old Nelco sewing machine that is a tank of a machine and sews nearly anything I throw at it. But for finer work, I prefer my Bernina--probably because it has more stitch selections, sews a straighter stitch, and I know it better.
If you aren't able to have the machine demonstrated to you and you can test it to your satisfaction, I'd be reluctant (Actually, that goes for any used machine, not just Nelco!) The following may be helpful:
Thread Anybody heard of Nelco sewing machine Worth fixing up
Jan 25, 2017 | Sewing Machines
Value of a 100+ year old Singer Treadle sewing machine
Singer made hundreds of thousands of sewing machines over approximately 150 years, so unless yours is a rare or special "design" model (ie Red Eye), it is probably worth what someone is willing to pay. Unfortunately, most older machines are sought for collectability, not for their actual sewing use. Machines improved over the years and most sewists would prefer machines with added conveniences, ie zig-zag stitch, decorative stitches, needle threaders, presser feet & accessories. Frequently, the accessories that came with the older machines are large and not as refined for doing intricate work.
If you like the machine, then perhaps you should keep it to use for your own projects.
Jun 05, 2016 | Singer Sewing Machines
Pfaff 1222e
Hmm, be sure when you thread your top thread that you ALWAYS RAISE the presser foot. That allows the thread to seat completely in the tension disk. However, in your case, the tension mechanism may need repair or replacement. Most often, there is a spring involved that will wear or be damaged over time. May be time to take it for service.
In my opinion, those older mechanicals are keepers. Consider that it has lasted you 40 years---can't beat that! And it's still worth fixing.
Nov 17, 2017 | Sewing Machines
When trying to change to the other sewing stitches the cams will not the the selector pass
doesn't sound like he tried real hard, my suggestion is to find a sewing machine shop that will take the machine apart & find out why the selector doesn't move, it's possibly a worn or loose or broken part, & the repair man is suppose to open the machine & find out what's wrong.
Mar 01, 2012 | Bernina Sewing Machines
My Activa 130 makes a clacking sound when I sew. It is 10 years old. What do you think is wrong? Can I repair this or do I need to take it to be serviced?
I would take it to a Bernina repairman, nice machine and well worth getting it serviced by a qualified technician.
I presume that you've tried the obvious things like a new needle and checking the bobbin case is in correctly.
Sep 03, 2011 | Bernina Activa 130
My sewing machine won't hold a stitch.
you need to make sure your bobbin is still feeding when you are sewing this model has a issue with dropping (ripping) the bobbin thread and then the stitch doesn't hold. you may also need to adjust the thread tightness it may be to tight or to loose
May 04, 2011 | Brother XL-5130 Mechanical Sewing Machine
My Bernina 730 record can only run the zig-zag stitch. The tech said the motor was "weak". Will replacing the brushes in the motor fix the stitch problem?
Sewing machines needs full service now and then (every 10 years will often do). The motor on the 730 series is actually as powerful as they get on domestic machines, and handles just about everything that fits under the pressure foot. Only if the machine has been used a lot over the years are the brushes worn down, but it might need new grease not matter how little it has been used.
However, the stitch applications can sort of gum or clog up if the machine has not been used for ages. Take a look in the manual and oil ever point suggested every time you take out the machine. Try them now and then on slow speed, that might get every function to run smoothly again.
This is as good a machine as any out there, favorably compared to any new machine under 500£. It sews perfect stitches on just about any material, and is well worth a full professional service (At a shop they will always recommend a new machine they want to sell you). All kinds of pressure feet and accessories are available in regular sewing shops and online.
Check with different shops for price on full service. This is a great machine what ever they tell you.
Nov 20, 2009 | Bernina Bernette 75
Sewing Machines Logo
138 people viewed this question
Top Riccar Sewing Machines Experts
Tally Girl
Tally Girl
Joseph Mueller
Joseph Mueller
Are you a Riccar Sewing Machine Expert? Answer questions, earn points and help others
