Question about Texas Instruments TI-89 Calculator
How do i convert units ex temperatures c->k
How i convert units
Well if your wanting to do for temperatures on your ti 89 all you need to do is type tmpcnv( then 2nd 3
this will bring up your units and you want to go down to temperature
then , then 2nd 3 and pick what unit you want to converte the temp in to. then close)
so looks something like tmpCnv(_F,_C) which will convert fahrenheit to Celsius
if you want to you can also put a number in like tmpCnv(40_C,_F) and it will give you 104.00_F
hope that helps.
ldglance
*btw there is a degree sign between _ and C but don't know how to put it on the computer
Posted on Nov 23, 2009
  • something16 Mar 01, 2011
    ° = Hold the ALT key
  • Texas Instru... Master
  • 8,073 Answers
K for Kelvin, C for Celsius, F for Fahrenheit
T in K =T in C + 273
T in F = 32 F + 9/5(T in C)
T in C = (5/9)*(T in F -32 F)
Hope it helps.
Posted on Sep 30, 2009
1998 honda accord ex 3.0 vtec cluster temp don't work? How can I fix it?
check the temperature sender unit is connected (temperature sender unit not the temperature sensor as there are two separate units doing 2 different jobs).
Jul 25, 2014 | Cars & Trucks
Temperature gauge
check the coolant level as the gauge sender unit will not work unless it is in coolant.
Jan 20, 2014 | 2007 Pontiac G6 GT Convertible
How to convert metric system to SI and how to convert SI to English system
1. You can use google for that. Ex: you want to transform 10 m into an x unit. just type 10 m to x and you'll get the result.
2. You can use this website: http://www.digitaldutch.com/unitconverter/
Jun 16, 2011 | Computers & Internet
How to convert Pressures on a TI-89?
The same way you convert any other units other than temperature, using the Units menu (2ND 3) and the -> operator (2ND MODE).
As an example, to convert 1.1 atmospheres to mm of mercury:
1.1 2ND 3 2ND Down Down Down Down Down  ENTER 2ND MODE 2ND 3 2ND Down Down Down Down Down Right Down Down Down Down Down ENTER ENTER
You should see 836. _mmHg
Feb 17, 2010 | Texas Instruments TI-89 Calculator
I can't find this button on my calculator / this
A fraction is in fact a ratio of two number: a division of a numerator by a denominator. The key used for the division operation is the one above the multiplication sign and below the caret [^], and in thee rightmost column of keys.
Beware that this calculator converts any ratio of two numbers into a decimal value. To keep a fraction in a fraction form you must use the [|=>Frac] or [ToFrac] command. To convert a decimal result to a fraction, use the [|=>Dec] command.
These commands are accessible through the CATALOG or more easily by pressing [MATH] (under the ALPHA key) and selecting [1:|=>Frac], or [2:|=>Dec]
Ex: to keep 27/48 in fraction form you enter
27 [/] 48 [MATH][1:|=>Frac] [ENTER]. Result is 9/16
You will notice that the resulting fraction is reduced to its simplest form.
To convert the above result from fraction to decimal press [MATH][2:|=>Dec]
A fraction can always be approximated by a decimal value but the converse is not always possible.
Jan 23, 2010 | Texas Instruments TI-84 Plus Calculator
How do I find degrees minutes and seconds on my ti 84 plus?
On this family of calculators, you do as follows
  1. Enter the first number (degrees), ex:15
  2. Press [2nd][APPS] (ANGLE) to access the Angle functions
  3. Select [1: degree symbol] [ENTER]
  4. Main screen shows 15 deg
  5. Enter the minutes, ex 25
  6. Press [2nd] [APPS](ANGLE) to access Angle functions
  7. Select [2:' apostrophe] [ENTER]
  8. Screen echoes 15 deg 25'
  9. Enter the seconds number, ex 32
  10. Press [ALPHA][+] (") to access the double quotation mark.
  11. Screen echoes 15 deg 25' 32"
  12. Press [ENTER]
  13. Calculator converts this in decimal degrees 15.42555556
To convert this back to DMS, press [ANGLE][|=>DMS][ENTER] and the calculator displays the original value 15 deg 25' 32"
Jan 11, 2010 | Texas Instruments TI-84 Plus Calculator
If a textbook problem is given in DMS notation, how do I enter the DMS notation into the TI84 to get decimal degrees?
Press [2nd][+] (") to access the double quotation mark
Press [ENTER]
Jan 06, 2010 | Texas Instruments TI-85 Calculator
My TI-89 won't convert temperatures. It handles other types of conversions fine (like pressure _atm to _mmHg) but gives me a "Error: Inconsistent units" message even with _F to _C or _C to _F. What's...
There is nothing wrong. For all units except temperatures you use the [|=>] the arrow operator to convert from one to anther. For temperature conversions however, you must use the tmpCnv( command.
Exemple of syntax. tmpCnv( is accessed through the catalaog or enter using the Alpha_shifted keys (Ti89)
tmpCnv( 100_ deg C,_ deg F) [ENTER] should give 212
You should explicitly enter the underscores, the degree symbols and the C, and F. The last two need not be capital letters).
Hope it helps.
Dec 02, 2009 | Texas Instruments TI-89 Calculator
Indian Rupee format in Excel spreadsheet
Rupees with Paise
[>9999999]"Rs. "##\,##\,##\,##0.00;[>99999]"Rs. "##\,##\,##0.00;"Rs.
"##,##0.00
Rupees without Paise
[>9999999]"Rs. "##\,##\,##\,##0;[>99999]"Rs."##\,##\,##0;"Rs. "##,##0
Rupees without Rs. notation
[>9999999]##\,##\,##\,##0.00;[>99999]##\,##\,##0.00;##,##0.00
Sep 14, 2008 | Microsoft Excel for PC
Texas Instruments TI-89 Calculator Logo
1,549 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
