Question about Dryers
Maytag neptune model mdg3000aww gas electric. just quit getting hot at all.What should i look for?
    President:
  • 1,776 Answers
First, check to make sure that the ignitor is working properly. It should glow visibly if it is functioning properly. If the ignitor is working alright, and the burner won't light, then consider the gas valve coils. These electrical coils are above the gas valves and when energized, these coils open the gas valves and permit gas flow to the burner. If the coils are bad the burner cannot light. It is recommended that if any coils are suspected of being faulty, that both (all) be replaced at the same time and they will most likely come from the parts supplier as a set. Really sorry for your trouble and I hope this helped. Best wishes.
Posted on Sep 28, 2009
Maytag Neptune dryer not getting hot
gas or electric and the model number would help and i'll be able to help you.
Oct 21, 2014 | Maytag Dryers
Mdg3000aww gas dryer. drum turns. ignitor glows and goes off but no flame.
I suppose you made sure the gas is on. The valve probably has two valve coils sitting on top; one is a dual coil. My guess is that one coil is "open" (no continuity).
Sep 07, 2011 | Maytag Neptune MDE5500AY Electric Dryer
MDG3000AWW Maytag Neptune Dryer. Not heating correctly
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Jun 02, 2010 | Dryers
I have a maytag dryer model number is mce8000ay
heatman101
Dec 23, 2009 | Maytag Neptune MCE8000AY Electric Dryer
Maytag neptune model mdg3000aww heats for 20 - 30 second then the burner stops.
The most common failure item is the gas valve coil(s)
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
Below are some links provided by, www.repairclinic.com. This can assist you with diagnosis, parts ordering and replacement.
Dryer parts breakdown link:
http://www.repairclinic.com/Dryer-Gas-Maytag-Style-Appliance-Diagram
Coil illustration link:
http://www.repairclinic.com/SSPartDetail.aspx?s=t-mdg3000aww-%3d%3di686303&PartID=686303
If your dryer doesn't heat, check these:
Igniter
Gas valve coils
Igniter Modern gas dryers use an electric igniter to ignite the gas from the gas valve. When it's working properly, the igniter glows bright orange. When it burns out, the dryer tumbles but there's no heat because the gas can't ignite. When the igniter burns out, you need to replace it. If the igniter is held by a tension bracket, you very well may need to replace the bracket too.
The igniter is inside the dryer housing, near the bottom front, usually in a cone-shaped metal tube (the force cone). It's about 2 inches long. It's mounted to the far end of the burner tube, and it has two wires attached to it--or to the tension bracket, if there is one.
Gas valve coils Watch the igniter. Does it glow bright orange, then shut off without igniting the gas? (When the gas ignites there's a large blue flame.) If so, there may be defective coils on the gas valve. Mounted on the top of modern gas valves, there are black electrical coils. The coils, when energized, open the gas valve. If one or more of the coils are defective, the valve doesn't open and the gas cannot ignite. Because it's often difficult to properly test the coils, it's usually best to replace both (all) of them at the same time.
Aug 15, 2009 | Maytag Dryers
Neptune mdg3000aww starts heating and runs fine but stops heating shortly after start up can restart heater starts again and shuts down
If the machine keeps running but just not heating you have a thermostat issue. It could be the operating therm. or the high temp limit therm malfunctioning, shutting off the element.
If the machine stops running completely, check the door switch.
Jul 09, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Dryer will not start after running the 1st load through
HI, Your motor is going bad. It is overheating and the overload safety will not let it start. The motor cost is about $140.00
Please let me know if I can assist you further.
Thanks
Vic
Please feel free to rate my response to you so that others as well as myself will know how I am doing
May 31, 2009 | Dryers
My maytag neptune gas dryer model #MDG3000AWW When I push the start button on my maytag neptune dryer it sounds like it wants to start but doesn't and then it gets this smell like something is burning?...
It sounds like the drum bearings are seizing up preventing the drum from rolling easily, and when the motor runs, it can't pull the drum belt around the drum that won't turn, so starts squealing and burning the belt.
You need to lubricate/replace the drum bearings, and replace the belt.
Jan 29, 2009 | Dryers
Maytag gas dryer runs, doesn't dry
Check in the hole where the screen goes for blockage. Many times debries falls in there when removing screen. It cant make it out of the vent so it builds up and clogs the vent.
Dec 01, 2008 | Maytag Neptune MCG8000AW Gas Dryer
Dryers Logo
171 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
