Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Motor humms but door doesn't go up or down!
My Craftsman 1/2 hp garage door opener model #13953920D isn't working. It's giving me 5 flashes from the green diagnostic light & makes a humming sound but doesn't move. It worked fine before I crosswired the opener/clicker button between red & white. Did this do something to the motor unit or logic board that is irreversible? Please advise.
Thanks,
Tyler
    President:
  • 3,197 Answers
5 flashes is the code for "RPM sensor board or motor overload." If your door is stuck in the open position the trolley may be jammed against a bolt just in front of the motor unit. Remove the bolt and run the opener until the door is closed. Now locate the 'up limit' control on the side of the motor unit and turn it a couple turns in the opposite direction of the arrow printed on the cover. Be sure to replace the bolt.
Posted on Sep 28, 2009
I have a Craftsman/Chamberlain 1/2 hp 315mhz Garage door opener model 139.1845.DM just stopped working. The motor runs the chain moves, the door doesn't open. Whether I use the remote or pad still n
All garage door openers have a quick release. Have you checked to make sure that is locked in place? Most have a cord hangin from it and you pull it which releases it from the chain. Make sure that is engaged and it should work.
Dec 02, 2011 | Home Security
The garage door opener inside the garage doesn't open or close the garage door. How do I diagnose? The model # is: 41A5389-1B
The model number you give is a part number for the logic board. Does your remotes work? Is it only the wall control that isn't working?
Sep 11, 2011 | Sears Craftsman LiftMaster Chamberlain...
Sears craftsman 1/2 hp. Door goes up with remote, but when button pushed to go down the light flashes and door doesn't move. If you push the wall mounted switch, the door goes down like normal. Works...
Check the sensors in the doorway. They should both have a small light that is lit and not flickering. Tweak them a little. If you cannot get both lights to come on you have bad sensors.
Sep 07, 2011 | Sears Craftsman LiftMaster Chamberlain...
Craftsman 1/2 HP garage door opener Model 139.53962SRT1 and am getting 5 error code flashes.
That code is for "RPM sensor or motor overload." Check to see if the trolley is jammed against the bolt just in front of the motor. If it is, loosen the chain enough to take off the stress and then run the opener until the door closes. While the door is closed locate the 'up limit' control on the side of the motor unit. Turn this control 2 full turns in the opposite direction of the arrow printed on the cover. Tighten the chain.
Jul 15, 2011 | Sears Craftsman LiftMaster Chamberlain...
My Craftsman 1/2 hp garage door opener will go up fine with the push of any button but it starts then stops when I try to push the button for it to go down. It acts like there is something in front of the...
If the main light flashes 10 times when the door stops it is a door sensor problem. Make sure the small light on each one is lit and not flickering. If the main light doesn't flash you have either a bad IR sensor which is a small printed circuit board just in front of the motor or you need to increase the down force which is a control on the rear of the motor unit.
May 10, 2010 | Sears Craftsman LiftMaster Chamberlain...
I have a liftmaster 102-1499A 03/2006 and yesterday it stopped working.. it attempts to move but does not, then motor humms and light flashes 5 times.. i've removed the chain, looked at the gears.. all...
The code for the LED flashing 5 times is " Motor overheated or possible RPM sensor failure. Unplug to reset".
The RPM sensor is a small printed circuit just in front of the motor.
If the flashing is the main light and it is flashing 10 times then it is a door sensor problem. Make sure the are pointed at one another.
Nov 22, 2009 | Sears Craftsman LiftMaster Chamberlain...
Our Sear Craftman 1/2 hp, clicks and humms but does not move. The light on back blinks 5 times. Any help is appreciated.
The code for the 5 blinks is "RPM sensor or motor overload". Make sure the door is free to move and the trolley isn't jammed against anything.
Oct 13, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door opener motor doesn't work.
2 flashes is a safety eye issue, but you problen is most likely that the chain is not sync with the limit setting. Take the bottom off the gear and sprocket assemble and rotate center limit srew until it is in the same position as the trolley.
Jan 26, 2009 | Sears Craftsman LiftMaster Chamberlain...
Red supmart button
The safety interlock sensor is blocked or not working - those are the sensors at the bottom of the door that check for blockages.
Jul 21, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
249 people viewed this question
Top Sears Building Materials Experts
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
