Question about Philips MX3600 System
Disc load error
Lens clean what speed does dvds spin at
  • 979 Answers
DVDs spin at constant linear velocity. This means that the disc can be spinning slowly or relatively fast, depending on where the laser is positioned on the disc and what function is being used at the time....accordianman
Posted on Dec 19, 2007
"Loading" error. RCA DCR69702 DVD can't read discs anymore.
Replace unit - the laser assembly has lost the ability to focus on surface of disk.
May 04, 2017 | RCA Televison & Video
All the dvds stop or freeze and then I have to skip forward...the dvds are clean and look to be scratch free....is there anyway to clean it?
how long have you been using this player and when did this begin?
Remove the disc and try another. If the player refuses to eject the disc, remove it from the wall and fix it back and fix it back again. Then turn the player on.
If the player still gets stuck on "loading" mode for other disc, then it means the laser is weak.
The lens is weak such that it cannot load data on discs. Its spinning, trying to load, but can't because of the weak laser.
Get a lens cleaner, use it to clean the lens. If that doesn't solve the problem, get a screw driver, open the player's cover so that you can gain access to the lens, use a cotton board to clean the surface of the lens. This should clean dust or dirt that might be on the lens.
If non of the above solves the problem, then know that you need to replace the laser to a brand new one.
To replace the lens, remove the bad laser, use it as a sample to get exactly the same type and do the replacement. Note that replacing a laser (lens) needs a professional touch, so if you cannot replace the laser, get it to a repairman to fix it for you.
Once this us done, your player will play all discs again.
Good luck.
Jun 12, 2011 | Televison & Video
My player won't load any DVDs; it keeps coming back with Error on the player and a bad disc message on the screen. I've turned it off to try and clear it, but that didn't help. Any ideas?
Hi zorak7824,
If you have necessary tools and test instruments, know safety precaution in basic troubleshooting try the steps below to solve your problem.
Assuming that the disc is good.
1.Clean the lens. - Sometimes because of dust the lens can't read any disc. Try clean the lens by soft cotton buds. Be careful while doing this.
2.Replace the ribbon - Check the ribbon connected to the lens from the main board for scratch, damage. Once it has an open line then of course the lens can't read the disc. Also try to erase the contact by pencil eraser. If you've done the steps above and the symptoms still there then the next step requires you a little knowledge in soldering technique and reading the ohmmeter.
3.Check the motor - Check the motor that spin the disc with an ohmmeter. You can test it using the ohmmeter (x1) even it is connected on the lens assembly.Good motor - reading should be fairly high and it will spin. Bad motor- reading will drop to low resistance and will not spin.
Hint : 50% of my repaired unit the above parts are commonly caused of the problem.
If you confirmed that you have a defective motor then replace it with a new one. Before replacing the new motor you have to check the clearance of the disc holder with the old one. The clearance should be the same as the old because if not the lens will not read the disc if it is too far or too close.
If the above steps didn't cure the problem, high chance that your optical lens was faulty.
If you can
Mar 06, 2011 | Televison & Video
Put disc in player spins it, and says ERROR and
how long have you been using this player? The problem should be from the lens (laser).
The lens is weak and that's why it cannot read/load Cd's. The weak lens is also what's making it say error and no disc.
Get a lens cleaner and use it to clean the lens, but if the lens still does the same thing even after using the lens cleaner, then it means you would have to change the whole lens completely to a brand new one.
By so doing your player would play all Cd's with no problem at all.
Good luck.
May 13, 2010 | RCA RS2650 Shelf System
My dvd player will not play any dvds or cds... It says disc error
The lens is weak and that's why it cannot read/load Cd's. The weak lens is also what's making it say disc error.
Good luck.
May 13, 2010 | Audio Players & Recorders
I HAVE MY DVD PLAYER FOR ONE YEAR WITH NO PROBLEMS. NOW SOME DISCS WONT LOAD, AND THOSE THAT DO LOAD ONLY PLAY FOR A FEW MINUTES THEN STOP.
You may need to clean the DVD player's lens because it hardly reads the discs that is why you are experiencing that problem. If you have a disc cleaner, try playing it; having it spin for like 30 seconds will clean the lens. If this does not work, then you may have to manually clean the lens by opening the DVD's casing and unscrewing the plastic cover that protects the lens inside. Get a q tip or a cotton bud and damp it in an alcohol. Gently wipe the surface of your lens and let it dry for a few seconds. The return everything back and play those DVDs again.
Good luck and hope this helps.
Dec 12, 2009 | Sony SLV-D380P DVD Player/VCR
The dvds are not detected - No Disc or Disc Error
Hi. These steps should help.
  1. Check the disc you're using for scratches and dirt. If the disc is damaged it won’t play properly, regardless of the DVD player’s ability to function. You can use a DVD repair device like the "Disc Doctor" to repair the DVD or purchase a new DVD.
  2. Make sure the discs you're using fit the correct format specified by your DVD player. For example, if your DVD player doesn’t support home-burned DVD-R's, then you can’t use a DVD that you made at home. You may need to upgrade to a newer model, most of which accept the latest DVD formats.
  3. Clean the laser lens with a DVD laser lens cleaning disc. DVD laser lens cleaning discs can be purchased at most electronics retailers or online. Insert the laser lens cleaning disc and follow the instructions.
  4. Insert a correctly-formatted, undamaged disc into your player. Listen to see if it begins to read the disc. If it continues to make no sound and gives you the same message, then the problem is probably that your disc is not spinning in the device.
  5. Turn the device off and unplug it. Take off the outer casing by removing the three or four screws and lifting the top piece off. This will allow you to see if anything is simply stuck or jammed. If this is the case, a simple nudge back to the correct position will fix the problem.
  6. Clean the lens while the DVD player is open. A dirty lens is most likely the cause of your no-disc error. The lens should be cleaned with isopropyl alcohol and a cotton swab.
  7. Take your DVD player to have it professionally fixed only when none of these other solutions solves the problem. A professional repair technician will be able to tell you if fixing your DVD player is worth the money.
Nov 22, 2009 | Aiwa HT-DV90 System
No disc error only for DVDs
This is problem laser unite replace it
Sep 05, 2009 | Sony DVP-NS575P DVD Player
FAT PS2 with Flip Top and Swap Magic 3.6 not loading backups
1. when you're burning your dvds, burn at the lowest speed possible, and use high quality media like sony
2. clean your lens
3. if that doesn't work, clean out the whole ps2
i use swap magic on the same model ps2, and occasionally get this message on lower quality media
Jan 14, 2009 | Sony PlayStation 2 (PS2) Console
Denon 3910 won't load some dvds/cds and vibrates while trying.."disc error"!
I have the Denon 2900 (about 4 years of use) and until recently, suffered from the same (growing) problem. CD's were very difficult to start/read. I recently found advice which I tried and was succesful with. It was manually cleaning the laserlens. I took away the outer housing by unscrewing all off the on top (6), side (4) and the back (2) bolts. After that I took out the top plate of the laserunit which took two very little screws taking out. Now you are looking at the cd-tray with the lens. Take a very soft and clean cloth and moisten it a little bit with clean water (be very carefull with the moistening, don't allow any waterdrop to come out of the cloth into the laserlens while cleaning! Carefully clean the lens and dry it with a dry part of the same cloth. Replace the top plate and the outer housing and the player will recognize the discs like it's new again. Good luck! Robert Jan, The Hague the Netherlands
Dec 25, 2007 | Denon DVD-3910 DVD Player
Philips MX3600 System Logo
194 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
