Question about HP Computers & Internet
Hi my problem with HP g5000 is when run widows xp in normal startup its shutdown automaticly but when i run in safe mode its work fine could you please help me to solve this problem my emil is ameeryd@live.com
    Sergeant:
  • 155 Answers
Try to cleen boot ur pc and uninstall recently instaled h/w or s/w.
for clean boot go to this link and follow the steps:
http://support.microsoft.com/kb/310353
Posted on Sep 28, 2009
HP xw8200 overheating
Overheating is more likely to cause a shutdown. You need to do some troubleshooting. Remove all USB attached devices. Roll back system with System Restore under Safe Mode (press F8 during boot and choose Safe Mode). For Win 7 - Start > Start > Search type System Restore. For XP - Is Start > All Programs > Accessories > System Restore. Now choose a date prior to problem starting. You may have to try a few dates.
Uninstall last program(s) that was installed, again in safe mode.
Disable startup programs. Go to Start > Run (search in Win 7) and type MSConfig. In Startup tab, uncheck anything that you don't want Windows to load automatically. It will make Windows boot faster and use less resources while running. This just disables them in startup. Programs will still load, but when only you initiate. In fact, in your case uncheck all. TEST.
Oct 11, 2012 | HP xw8200 PC Desktop
Hi, i got a problem with my laptop HP brand with XP OS..every time i turn on it keeps on rebooting even its starting up..i enter start up windows normally but it keeps on rebooting..it goes only until the...
Hi d_gallos,
you may wanna try to go to safe mode (turn off pc then turn it on again while pressing F8) then find there disable automatic restart when system failure then reboot your computer.it should work fine
hope this helps :D
Apr 05, 2011 | HP Computers & Internet
My computer won't boot.
This would be a good time to recover or roll back what you did, There must have been a change in your configeration.
Jun 09, 2009 | HP Pavilion dv4000 Notebook
Cant acess safe mode in windows xp, just cycles startup screens
Here are some steps to use MSCONFIG to force your computer into SAFE MODE
  1. Click on Start and then Run.
  2. In the text box in the Run window, type msconfig and click OK. This will open the System Configuration Utility program.
    Note: Do not make changes in the System Configuration Utility other than those outlined here to avoid causing serious system issues. This utility controls a number of startup activities other than those involved with Safe Mode.
  3. Click on the BOOT.INI tab located at the top of the System Configuration Utility window.
  4. Check the checkbox next to /SAFEBOOT and click OK.
  5. You will then be prompted to either Restart, which will restart the PC immediately, or Exit Without Restart, which will close the window and allow you to restart the PC manually.
  6. After the restart, the PC will automatically boot into Windows XP Safe Mode.
    Note: Windows XP will continue to boot into Safe Mode until the System Configuration Utility is configured to again boot normally.
  7. When your work in Safe Mode is complete, click on Start and then Run. Type msconfig in the text box and click OK.
    This will again open the System Configuration Utility program.
  8. Choose the Normal Startup radio button and click OK.
  9. You will then be prompted to either Restart, which will restart the PC immediately, or Exit Without Restart, which will close the window and allow you to restart the PC manually.
  10. After the restart, the PC will boot into Windows XP normally and will continue to do so.
    These instructions were written by About.com
    http://pcsupport.about.com/od/tipstricks/ht/smsysconfig.htm
May 24, 2009 | Microsoft Windows XP Media Center Edition...
Windows xp log on screen
tap F8 during startup and select safe mode,
log on to administrator then do the following:-
Start -> Control Panel --> User Accounts
Select the HP Administrator User and change its password
Shutdown then log on normally
Mar 02, 2009 | Tablets & eReaders
Toshiba laptop, xp, wont start up.
Perhaps the shutdown corrupted a critical Windows startup file. Have you tried a Windows repair? You'll need the Windows XP CD to do it. An explanation is here: http://www.michaelstevenstech.com/XPrepairinstall.htm#RI
Jan 31, 2009 | Computers & Internet
Help :( i can't start up my laptop it wont let me :(
what i can help this...
you select safe mode and remove video driver and reboot your laptop...if it inside the windows normally,try to remove some unused toolbar in add and remove programs..and check also for virus scan..and reboot computer..
Dec 16, 2008 | HP Pavilion ZV5000, ZV6000, ZX5000 Series...
HP a1620n- Will not startup properly
try starting in safe mode then when it windows starts/full loads shutdown the computer. Then restart the computer-it should start normally.
Dec 01, 2008 | Computers & Internet
Plz help me with my problem in my computer
Hi, Hardware wise this could be a memory issue. However, more often than not, it would be similar to a video problem that it either freezes or BSOD. Try reseating your mem sticks; OS wise, it may be corrupt drivers or XP startup files. Try to run in Safe Mode and check it if will load fully. If yes, you can start finding out anything out of the ordinary. If no also, then you may have to repair Windows; Virus wise, it may be that you have a virus or malicious software running at startup instructing your PC to shutdown. Try running in Safe Mode. If it will load, go to Start, Run, type "msconfig", Startup. Check all the programs that run at start up and uncheck those that you do not recognize. Reboot. If it will not run even in Safe Mode, you may need to reinstall/repair your Windows XP. Good luck and hope this be of some help to you.
Aug 20, 2007 | Microsoft Windows XP Professional With...
Computers & Internet Logo
174 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
