Question about Gateway GM5084 PC Desktop
The cd-rom drive in my computer has stopped working all of a sudden. The cables inside the tower are all connected however it does not recognize a disc being in the cd-rom drive! I also get a warning that the drive or device is not ready and I can only close out of the window. Can someone please help me understand what is going on and what I need to do?
    Problem Solver:
  • 14 Answers
Try to read another cd, maybe the cd is broken.. if not, try the cd to another cd rom, if it works, replace your cd rom drive, maybe its broken.. =)
Posted on Sep 28, 2009
    Genius:
  • 1,112 Answers
Replace the Cd-rom drive, sounds like you may have a bad spindle motor and or Laser assembly. Cd-roms are very cheap these days, and you might consider replacing it with a DVD drive instead, which is downward compatiable.
Testimonial: "I was surprised at how fast I got a solution to my problem and I was very happy with the solution that I recieved!"
Computer does not recognize CD/DVD disks in drive. My Windows XP PC has suddenly stopped recognizing disks in my CD/DVD drive. Device Manager shows that both of the listed drives (TST Corp. DVD +RW...
Most likely a problem with the reader on the CD/DVD Drive.
Very easy to swap out a different CD/DVD Drive. Add the new device and see if that resolves the issue.
May 02, 2017 | Computers & Internet
The cd burner in my computer just stopped working
if nothing working try to uninstall the driver and reintall it and see if that work if not need to change it...go to device manager and delete the device and restart the computer and see if it will load new one.
Nov 08, 2009 | Dell HP Pavilion ZE5000 ZE4000 NX9000...
I have brought a new computer that dosnt have a cd rom. I have tried putting in two different cd-roms but they wont show up on my computer. i have tried downloading drivers to help but it still wont work.
Hello !
Your CD-ROM should have at least two cables connected to it: a power cable and IDE cable that should also be connected to your motherboard. Disconnect and reconnect the cables and be certain that they are snug.
Some computers will also have a small third cable used to interface the CD-ROM with the sound card. If the audio for your CD audio CDs is not working properly verify that this cable is not disconnected from the back of the CD-ROM.
Hope this helps.
Sep 19, 2009 | Dell OptiPlex GX270 PC Desktop
Hoew to install CD Drive
You want to install a CD Drive. Ok you are Following these steps....
  1. Unplug the power cable from your power supply and open your Computer case.
  2. Determine which drive bay you are going to install a CD-ROM into. You should pick on of the uppermost drive bays
  3. Before you install a CD-ROM, make sure you have the proper jumper settings. You are only installing a single CD-ROM, set the jumpers as MASTER. The jumper settings are different for each CD-ROM drive, so consult your owner's manual so you know which pins to cover up.
  4. Once you have the jumpers set, install your CD-ROM in the computer's case. How you secure the CD-ROM in one of the uppermost drive bays depends on your case. Some CD-ROM drives have to be screwed into the drive bay.
  5. Connect the power to the back of the CD-ROM drive, then connect the ribbon cable to the back of the CD-ROM drive. Your ribbon cable has three connectors, one in the middle and one on each end. The middle connector is a SLAVE connector that is used if you would install an additional CD-ROM or DVD-ROM drive.
  6. Connect one of the end connectors to the CD-ROM drive, and connect the other end connector to the appropriate spot on your motherboard. Note, hard drives and CD-ROM drives have the same style of connector on the motherboard. You want to connect your CD-ROM drive to the motherboard slot that isn't red or is the highest numbered of all the IDE slots.
  7. Power on your computer after you plug it in. Your computer should recognize the new CD-ROM. If it doesn't, go into your motherboards BIOS and search around for the IDE channels, they need to be set to automatically.
Thank U
Aug 28, 2009 | LG Computers & Internet
Computer not reading the hard drives or cd rom drives
You first need to make sure that inside, the hard drives and cd roms' connectors are all firmly seated.
When you first turn on your PC, you can normally enter the BIOS mode, (before windows) by pressing the del key or f2 key. Once there you can make sure that the drives are being recognized. If they are, you would need to go to the boot section and enable hard drives and cdroms.
If they are not recognized,
Old IDE hard-drives (the ones with lots of pins on the back) (newer ones are called SATA and have plastic connectors) .. Old ide hard drives had a special jumper (little plastic rectangle on two pins) to indicate if it would run as a master or a slave drive. So your two drives should be connected accordingly.
If all the above sounds too complicated you would need to contact a friend savvy in the area.
Aug 11, 2009 | Dell OptiPlex GX260 PC Desktop
Dell Dimension 5150 cd-rom stopped working
Open your tower and reseat all the cables that are running to the CD ROM (generally a flat white cable). Also reseat the other end of the cable to the motherboard too.
Ensure that CD Drive is enabled in BIOS (Press F2 as the system boots up to enter into BIOS) Please get back if you need any further help.
Jan 09, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Dvd / cd rom not recognized on my computer list
1) Go to Control Panel. Open the System Icon.
2( Click on Hardware Tab, then click on Device Manager.
3) The device manager will list all of your hardware that is on your computer.If you see a yellow? mark oryellow ! mark next to your DVD/CD rom drive,simply click on it then click Repair. It also may tell you that it is not recognozied. Follow the directions.
4) If you do not see this in your Device Manager go to Add Hardware in your Control Panel which is next to your Add/Remove Programs icon. Click on Add Hardware and it will scan for all hardware.
** This should take care of your problem.If not then somehow the actual connection in your tower has come loose. If so you must open your tower and look for a loose wire going to your DVD/CD rom drive.
*** Please let me know if this corrects your problem.Simply email me(Phil) at: philw19642002@yahoo.com
Jan 01, 2009 | Gateway GT5468 Desktop PC
Replacement DVD-Rom has video but no audio
You should be able to get sound thru the IDE cable (this is the same type of cable also referred to as a ribbon cable, your hard drive connects in the same way) that is connecting your drive to the motherboard. turn the pc off and unplug power and reseat this cable on both ends be careful as the pins are fragile and will break
if this doesn't fix your problem let me know and we will try anotherr solution
Sep 01, 2008 | Dell DVD-ROM for Dimension (6t903)...
Toshiba A105-S4344 DVD-ROM not working
possible a loose connection, check to ensure you close the drive until a check is heard.check device manager to ensure device is listed and then go to its 'properties' ensure the current devis is recognized.you could also do a remove device,reboot, and have OS recognize a new device.clean the device with a lens cleaner.
Jun 22, 2008 | Toshiba Satellite A105 Notebook
Open Questions:
can you please help ms drunel broussard who just received custody of 2 of her abused grandchildren in nov 2017 have a great xmas not having a home with furnishings..she no longer have stable housing ms drunels daughter and boyfriend had been abusing her children..shes a great person with such agood heart and shes struggling to keep the kids..while in moms care the kids was sleeping on the ..have very min clothing..ms drunel took her car notes monies to get the kids basic clothing and hygiene needs..shes help so many7 ppl and always been an strong person..not knowing where they would lay their heads at..i watch her go and visit ,pray for ppl in the hospital..when you ask herhow is things going shell say all will be well..but today i seen her breakdown and crying..letting the kids know she might have to let them go to foster care because she cant provide them with a stable place..to know her is to truly love her..and to see her not be able to care for them the way she cared for hewr children and other ppl children is taking a toll on her.but she keeps smiling..she really need help and an agency in jax fl where she lives told her to give them up or go to a shelter...she replied ok ..and left..doors is not opening and due to the NATURE OF THE abuse..and physical abuse these babies been through she said no..they have nothing i mean nothing for xmas...less alone shes facing losing her means of transportation to get them to and from school...counseling ...and dr.appt...PLEASE PLEASE I BEG OF YOU HELP THIS FAMILY...THANK YOU FOR YOUR TIME
Dec 14, 2017 | The Computers & Internet
See all Gateway GM5084 PC Desktop Questions
Gateway GM5084 PC Desktop Logo
171 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
