Question about Gateway GT4023E (6886) PC Desktop
No video signal. What type of video card should I
No video signal. What type of video card should I buy?
  • joecoolvette
    joecoolvette May 11, 2010
    I would like to know what you have based your diagnoses on first, before I give a solution. Why? When your monitor shows No Video Signal, it could be several things, and not just faulty Integrated Graphics. (If you have a Gateway GT4023E Desktop computer, it has an Nvidia GeForce 6100 GPU for graphics. {GPU. Graphics Processing Unit) 1.Could be a bad video cable from monitor to computer. 2.Could be a bad power supply. If the power supply has a bad voltage power rail, it isn't providing enough Wattage for the processor. Lights will light up, fans will spin, and harddrive sounds like it's running. ALL the lights for your computer use less than 1 Watt. EACH fan uses 2 to 3 Watts. Your AMD Athlon 64 4000+ processor uses 89 Watts. If there isn't enough wattage for the processor to run, the computer will not work. This = No Signal to the monitor. (Volts X Amp's = Watts)
    Sergeant:
    Champion:
  • 269 Answers
First check the connection cable to the monitor from the CPU
Posted on Sep 28, 2009
My Acer emachine EL1800 was damaged by suspected lighting. The Lan connect is out and video output sometime shows no signal on the monitor. Can video graphic & Lan can be replaced ? OR I have to...
First, I suggest that you get the PC checked by a professional for possible damage.
As far as LAN and Video Card are concerned, and if this appears to be the issue, you can buy and add additional LAN and video Card, which would be cheaper.
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Jul 01, 2011 | Acer (ACERMOTHERBOARD)
What is a capture card and where do I get it?
A Video Capture Card and TV Capture Card allow you to send a Video or TV signal to your Computer. The signal can then be recorded to the Computers Hard Drive with TV or Video Capture Software.
There are several different kinds of Capture Cards on the market, with varying functions. This article will focus on what to look for when buying a Capture Card, depending on the use of the card.
You will be able to pick a card up from the likes of PC World, Radioshack etc....
Regards.
Dec 09, 2010 | Sharp Viewcam VL-AH150U Camcorder
How do i connect to an hdtv ?
You're going to need to connect a cable supported by BOTH the PC and HDTV. Check your HDTV's jack panel or manual. List the types of Input jacks it offers. The HDTV will likely have Component, Composite, DVI, HDMI and maybe even VGA jacks. Do the same for your PC. It likely has one or two Video Output jacks. Typical Video Outputs are DVI and VGA. The VGA type has been standard for years. It consists of a total 15 pins in 3 rows. The DVI has a number of pins, but most noticeable is a wide tab at one end of the jack.
If your HDTV has a jack that matches one of those found on the PC, you're in luck. Purchase a cable that will connect them - this would be either a VGA cable or and DVI cable. Nearly any inexpensive VGA or DVI (Digital Video Interface) cable 6 ft or less will do, but the better cables cost a bit more and when the distance is increased, the quality (or lack thereof) really becomes visible - especially on the lager HDTV screens.
If you want the sound to go to the TV speakers or elsewhere, you'll need to get a cable with a 3.5mm stereo plug (or whichever type your PC has - but that's the most common) to RCA or whatever the audio input jack type is that is associated with the video input you chose. The audio input must be the one associated with the video input - other wise you will not hear the audio on input 4 while watching input 3. The PC audio out is analog, so do try to put the signal into a digital input.
If you don't have a matching video input jack, you'll have to purchase an adapter or new video card with jacks that match your TV. Do not buy simple adapters that change VGA to DVI as they will not convert the actual analog VGA signals to Digital Video signals expected by the HDTV's DVI jack. The best bet is to buy a modern video card supported by your computer's mother board and OS that has a fair amount of memory (512 MB is a good start). If your HDTV has HDMI jacks and you wish to play the sound from the HDTV's speakers, get a card with HDMI output and buy an HDMI cable. It will send both the sound and video to the HDTV for you.
You can read a nearly endless list of articles about HTPCs aka "Home Theater Personal Computers" for ideas and deep discussions about everything from soup to nuts to implement, design and set up on google.
I hope this helps - good luck!
Nov 12, 2010 | Gateway GT5228 PC Desktop
Why is my computer saying that there is no signal input on the monitor??
Well, if you have an extra cable try using that. If its not the cable then its probably your video card. Since you didn't list what type of computer you have I can only assume its a regular desktop type. If you have an integrated graphics card, check your computers motherboard specs and see if it has pci slots, preferably pci express x16. Go to your favorite online computer parts store and buy you a cheap video card and plug it in. Connect your cable to the new video card and the bios should auto detect it and use it. When you get into windows, install the drivers for it, then go download the latest drivers from the manufacturers website. Cheap $30 fix.
Oct 23, 2010 | Computers & Internet
Monitor goes to sleep immediatly and no input signal and recommended setting 1280 x1024 sign comes up
FIRST DONT PANIC. turn the computer of check the connections are secure. Then try it again if no change if possible try another monitor. If the fault still continues you need tools. You need to find out if the video card is part of the system board if so you might try resetting the bios on the board it sometimes resets everything (not the OS). if this does not help then it might need a new video card check *********** board for the type of connector for vieo cards and buy a new one. The better thr video the quicker your pc will run. A on boatd video card can use a lot of the computers resoarses for its needs.
hope it helps
Sep 03, 2010 | HP Pavilion a1610n PC Desktop
No signal from desktop to monitor
Hi thanks for asking,the reason you are not having any signal is because of one of the following: your monitor may not be connected properly,please check all connections for your monitor.If you still have the problem this mean the video card in your computer is bad and you need to buy a new one of the same kind and put it in your computer.There are there are two types of video cards (1) AGP which is use by older computers and fit in a short brown slot on the motherboard and (2) PCIe which is use in new version computers. I advise you open your computer and look for the slot on the motherboard it is separate from the other slots and if its brown this mean you need a video card for AGP slot.
Jun 13, 2010 | E-Machines eMachines Desktop PC
Connecting and recording camera with s video output on 1221 tx
Your laptop has Tv Tuner card and if it takes TV input via cable , you get a S-Video / DVD cable to regular cable converter and use the laptop as a video recorder - if you are in US , any Radio Shack will be able to help you with the cables
May 17, 2009 | HP Pavilion dv6000z Notebook
The monitor leaves a message no input signal, then " going to sle
That signal means the monitor is not getting any signal from the computer. It probably means your video card or connection is bad. You can buy a pretty cheap ($35-$100) video card from a local store (Best Buy, Circuit City, Radio Shack) or online. Since it is a newer computer you can probably buy the graphics card with the PCIe card. If you want to do it yourself you will need to open up the computer (the side) and check for the correct connection. Here is a picture to help identify the ports. http://upload.wikimedia.org/wikipedia/commons/0/0c/PCI_und_PCIe_Slots.jpg
find the one that looks like yours and get that one. You will be able to slide off the back cover and install it. If you feel uncomfortable doing this, any local computer shop or guy should be able to help. Good Luck!
Apr 28, 2009 | Compaq fs740 17" CRT Monitor
RESTORE DISC
The 'test screen' of the monitor means only that the monitor would display if it receives an input signal.
Make sure it isn't something simple like dislodged video connector on the back of your system box.
You may even want to removed the plug and reinsert it several times in case a sync signal contact hasn't taken a hike.
If this doesn't help, your restore CD won't help either; it means that the video signal (there are several: Red, Green, Blue plus two synchronization signals) is incomplete or missing altogether.
If the video connector is attached to the strip with many others, then the video is on the main board (common on lower end systems) and the chip supplying video has failed.
This doesn't make the system worthless as you can buy dozens of different video cards to plug in to the main board and disable the on-board chip.
I don't know how old your system is but you will likely need a PCI video card (check your manual for the types of buss available for 'add-on' cards) to install and then possibly new drivers from a supplied CD.
This is a pretty simple procedure and even the Chinglish instructions are normally enough to guide you.
Until you can see your system's boot sequence appearing on screen again, you won't be able to restore anything.
May 05, 2008 | E-Machines eMachines Desktop PC
Gateway GT4023E (6886) PC Desktop Logo
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
