Question about Philips 27PT81S 27" TV
Assistant TV shuts itself off. TV will be on for an undertermined time and Red LED power light on front will flash then TV turns off. TV will turn back on either by remote or power button on set and the majority of the time will continue to shut itself off immediately after being turned on. If TV is left off for a long time TV will stay on for about an hour then start shutting itself off again.
    Filmmaker:
    Uploaded 5 video answers.
  • 152 Answers
Check your sleep timer settings thats the most comman prob
Posted on Dec 18, 2007
3 Suggested Answers
SOURCE: TV LED Flashes then TV shuts itself off
capacitor problems in power supply or a regulater isolate the power suppley by disconecting the line output stage/unplug scan coils for example and run a 60w bulb as a dummy load one wire to earth and the other to rail voltage colecter of line output transister if the bulb glows steady the power supplys fine
Posted on Jun 25, 2007
  • 6 Answers
SOURCE: assistant
is this electricity pocket plugged up to a timer ? or take the tv back to the shop... lost the receit just look for the same tv on computer
Posted on Dec 05, 2008
My TV randomly switches itself off and the red light flashes continously and i have to pull out the plug. its getting more frequent
Samsung TV Keeps Shutting Down - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - When I turn the TV on for the first time each day it shuts itself off within 30 seconds. ... green light flashing red light is [standby term] green light is [lamp]flashing. samsung plasma 850 picks up other remote signals?
Jun 12, 2015
Samsung LED UN55B7100 turns off on its own.
Jun 11, 2015
Volume goes automatically to 0 on my Samsung LCD TV
Jun 10, 2015
Why TV turns off by itself?
Jul 12, 2012
More results from www.cnet.com
Easy fix for new Samsung TV switching on and off power ...
? 4:41
https://www.youtube.com/watch?v=H0cG3lzjuw8
Sep 15, 2012 - Uploaded by alwaysafix
My tv turns on and off by itself the minute I plug in the cable. .... Samsung E6030 led tv hv blinkin red light ...
Dec 25, 2015 | Televison & Video
TV turns itself off, then on automaticlly
The fan should run for a few minutes after shut off to cool the lamp down.
If I read and understand correctly somewhere in the cycle you are getting 5 red blinks? that is an error code........
Either you or I can Google the model number of the set with 5 blinks.....or visit the Sony site to see what it means.....
Apr 24, 2012 | Sony KF-42WE620
I recently purchased a used 50' Hitachi 50V500a Ultravision HDTV. I've had it for about a week. Was watching it. Turned it off to run an errand. Came back. Tried to turn it on. There is power. No...
The "LAMP" LED light indication still light up,after all the other LED lights indications turn off?The tv projection lamp is dead.Require a new tv projection lamp.
Oct 15, 2010 | Televison & Video
I have been given a used Samsung TV without manual and have no idea how old it is or the exact size of this particular TV however, it is bigger than a 42''. I have written down the model code, serial...
The front panel LED light indication "LAMP" flashes?Change the the tv projection lamp or LED lamp first,see what happen?Than go from there?Tvs with "LAMP" LED indication light flashes,tv 1 1/2 or 2 years old use like 4 or 5 hours a day.The projection or LED lamp or bulb,inside life span is over.Require changing LED lamp or projection bulb.
Sep 10, 2010 | Samsung Televison & Video
Green flashes then tv turns off
or a new lamp. you could first replace the lamp.
the screen might work fine for a couple of seconds, but then it fades away or deteriorates. This means the lamp is going bad.
Aug 23, 2008 | Sony KP-51HW40 51" Rear Projection...
Assistant
Feb 20, 2008 | Toshiba 28N33 28" TV
Screen Turns Red and then TV shuts off
you red crt is shorting out.tap the neck of the red crt lightly to try to remove the short.if no go also inspect the neck board.
Oct 22, 2007 | Sony KP-51HW40 51" Rear Projection...
Panasonic Viera TH-42PV7HS Plasma keeps shutting down
Hi to all, My 42" Panasonic plasma have the same problem. It turned itself off and now red light flashes 7 times, than after short pause 7 times again. And so on. Any ideas what is wrong??
Oct 07, 2007 | Televison & Video
Jun 25, 2007 | Philips 27PT81S 27" TV
Philips 27PT81S 27" TV Logo
1,000 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
