Question about Microsoft Office Outlook 2003 for PC
Virtual printer driver
Hai...
my problem is that i don't know how to add a dummy virtual printer driver in printer propert sheet (printers and faxes).
Can u help me..
  • 77 Answers
I usually just choose to install one of the listed Apple printers, then after install I open the printer's properties sheet and tick the "print to file" box. When you print to this printer you end up with a postscript file of what you printed.
Posted on Jan 17, 2008
Keyspan's drivers won't work on Win7 . . . Install MS's Virtual PC. Add usbd.sys to windows/system32/drivers (virtual box doesn't think it needs to load the virtual usb drivers, so i
1. instal server utility on Windows 7
2. right click icon choose properties
3. select compatibility tab choose vista sp2
now run it and presto......
regards, dean
Jul 06, 2012 | Keyspan USB Server US-4A (d47710) Print...
How to connect to computer
The unit has a parallel port interface and is supported under Windows 95/98/Me, Windows NT 4.0/2000/XP . The drivers are available here: http://www.usa.canon.com/cusa/support/office/laser_facsimile/laser_class_2050_2050p_2060_2060p/laser_class_2060p?selectedName=Specifications#DriversAndSoftware . For the supported OS versions, download the drivers and then run the exe. If it extracts drivers, note the folder in which they are stored. Then launch the Add a Printer Wizard (Printers and Faxes in XP IIRC). If your computer doesn't have a parallel port, parallel to USB adapters do exist.
Neither Vista or Win7 Compatibility Center have the unit listed. The XP driver may work in Vista 32-bit with the compatibility mode on. For Win7 or Vista 64-bit, I'd suggest a second computer, a dual boot computer or a virtual computer with an older Windows OS. For the most setups, you'll need a licensed version of the Windows OS. (Virtual computer software include: Parallels, VMWare and Virtual PC.)
With Win7 Pro or Ultimate, you can download Virtual PC and XP mode from Microsoft for free, then install them in order. The printer will install normally into the XP virtual computer. However, files from the main computer will need to go onto optical media or an external drive in order to share them with the virtual computer for printing.
I hope this helps.
Jan 14, 2011 | Canon LaserClass 2060P Plain Paper Fax
My deskjet 3550 printed its test sheet and now goes through the motions without printing anything ie ink does not go on paper
make sure that u ink in the cartridges, u did not mention which operating system, if u r using xp then click on start go to controlpanel , and controlpanel click on printer and faxes and if u r using
vista or windos 7 click on start go to controlpanel , and controlpanel click on printer,
1.under printer icon u can there would b a tab "add a printer"
2.u will get a new window select "add a local printer" click on next
3.select the port usb virtual 001 for usb connection and select lpt 1 for wireless, click on next
4.on the next page on the left hand side select HP and on the right hand side select deskjet 990c printer
5.and know that u r not using this printer
6.click next use this printer as a default one
7.it will give u an option to print a test page
8.click on "no" and hit next
9.now try to print and check
Nov 12, 2009 | HP DeskJet 3550 InkJet Printer
My psc 2210xi sends out several blank sheets prior to printed sheets when I'm printing something from the web. Sometimes, it never prints from the web . . . just shoots out 4 blank sheets. Thx.
1.under printer icon u can see there would b a tab "add a printer"
5.and know that u r not using this printer [it is a generic driver fot hp's printer]
Nov 09, 2009 | HP PSC 2210 All-In-One InkJet Printer
My printer will not print.I opened the control panel and there r no drivers i have been trying to download but no luck please help
with out the software cd we can make the scan function work for that we will add the universal hp print driver so click on the start button and go to control panel and then open printers and faxes folder and click on the icon that says add a printer and then select ADD A LOCAL PRNTER in use existing port select USB 001 (virtual port) if its not there then click on creat port and type usb 001 and click next now in the brand coloum select hp and in the model list select deskjet 990c and continue the installation click on finish set the printer as default and now try to print if you have any problem just let us know
Aug 31, 2009 | HP Officejet 4355 All-In-One InkJet...
Adding cover sheet
If you are faxing directly from the flatbed then you can usually send a cover sheet by choosing to start the fax from the office director(on your "computer desktop".
There is a check box for sending with a cover sheet.
May 04, 2009 | HP Officejet J5780 All-In-One InkJet...
Scanning
No, there is no need of installaing any software.
Try to install the printer oce again using the following steps, it will definitely work:
  1. Click Start and then Printers and Faxes .
  2. Follow the steps in the Add Printer Wizard to add the print driver. Select HP from the list of manufacturers and then locate the all-in-one printer driver or fax driver (if your model can send and receive faxes from the computer) from the list of printers. The models will probably be near the bottom of the list.
  3. The printer port should be selected as the USB001 (Virtual printer port for USB) or the DOT4_00[x] HP (all-in-one series) printer port if the first port is not an option.
  4. Select the option to Keep existing driver when that choice displays.
  5. If prompted for a missing file, have the installation search for the file on the All-in-One CD-ROM.
  6. The installation should complete and a Congratulations screen should appear.
This will surely help u.
Thank u.
May 25, 2008 | HP DeskJet F380 All-In-One Printer
How do I like
Stepts to install Printer Software:
Thank u for the question.
Apr 29, 2008 | HP DeskJet F380 All-In-One Printer
Printer won't work
Try to install the printer again on ur computer. Try these steps to install the software on ur computer again. 8 out of 10 times, it works, so try this:
Thank u.
Apr 28, 2008 | HP DeskJet F380 All-In-One Printer
Microsoft Office Outlook 2003 for PC Logo
59 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
