Question about Canon PowerShot SD400 / IXUS 50 Digital Camera
Camera rapidly beeps 6 times when powered up and immediately turns off!
Camera rapidly beeps 6 times when powered up and immediately turns off and shuts down! Its a great camera. Is it worth repairing?
  • 14 more comments
  • kenokev Dec 18, 2007
    Its just six beeps with no lens movement during powerup and LCD just displays Canon logo for about 3 seconds and then shutdown.
  • jturi Dec 22, 2007
    Exact same problem with my SD400. Beeps 6 times when powered up in picture mode, displaying the Canon screen, then shuts off.
    The lens is stuck in the extended position. Won't move.
    I disassembled only to the point of the front/back covers off, and was afraid to go further. THere was a little sand here and there around the edges of the cover, so I'm thinking that some sand has infiltrated the lens mechanism or something.
    Any ideas?
  • mduvall216 Dec 27, 2007
    Yes my trusty little camera of three years is doing the same thing. Beeps six times, no screen, no error code. The lens does retract but will remain in extended position. I too took the cover off and blew some compressed air in there, no help. Any ideas?
  • kenokev Dec 27, 2007
    The lens does not extract or retract!
    1.Turn on camera 2.CANON LOGO on screen 3. Black flash on screen. 4.CANON LOGO and six beeps. 5. camera screen stays on six seconds 6.complete shutdown
    Whats the solution?????????????
  • Phillip Peters
    Phillip Peters Dec 28, 2007
    I'm having the exact same experience... can anyone assist me?
  • padgela Mar 08, 2008
    Hit power and lens protrudes, then makes a mechanically grinding sound followed by six beeps. Canon screen on LCD display flashes and turns off. This camera has been so trustworthy--how can I fix this?
  • Anonymous Mar 14, 2008
    beeps 6 times and turns off
  • wendino Apr 29, 2008
    same problem.
    first, it turned on as normal but i noticed it was foggy as if the autofocus wasn't working, and there was no green square like normal. i played with all the funcitons but couldn't get it to work.
    then i thumped it a bit and it did the beeping thing and the lens wouldn't retract.
    after leaving it off for a bit, i thumped it a few times on a tabletop and it got the lens on/off thing working and the green square worked a little bit, but after taking a few test shots, the autofocus stopped working again.
    stupid thing.
  • nullptr May 03, 2008
    I have the exact same problem with my Canon SD400. Does anyone have a solution?
  • evillin May 03, 2008
    Same here, but mine was dropped and battery compartment door broke off
  • MaiduMan May 19, 2008
    Having the same problem.  6 beeps and off.
  • akhunter16 Jun 30, 2008
    when i turn it on in the picture and video mode it beeps and shuts off, but when i turn it on in the view mode it works just fine unless i switch the mode. why?
  • ericdecant Jul 17, 2008
    same problem beeps a few times thn turns itself off
  • Anonymous Nov 04, 2008
    Have the same problem and took it apart like excitebike said. Played with the gears a bit and now it opens and closes. It's noisy now though.
  • linezero Nov 28, 2008
    Just follow Excitebiker above.. (As said before). Fixed It!
    A word of warning - don't touch any metal connections near the flash unit while trying to clean out any sand or dust - it will bite back with a few thousand volts!
  • jeanice21 Dec 28, 2008
    I am having the same problem as the other comments posted...beeps repeatedly and lense will not retract and will not take pics?
I HAVE SOLVED THIS!
I Totally fixed my CAMERA!
If you turn on your camera, the lens does not come out, and it just beeps then turns off, then listen to me.
You need to unscrew the outer casing and take off the metal shell.
Hold the camera in one hand, palming it, looking down at the LCD (ie the lens is pointing into your palm). This is to orient you.
If you look at the left SIDE of the camera, near the upper left corner of the LCD, you can peek through some of the windows of the black plastic casing and see 2 PLASTIC GEARS. The top one is white, the other is black. These are the gears that actually move the lens in and out. All I did was give the white gear a good jiggle with the tip of a pen and evidently it made the teeth of the gears mesh together like its supposed to and .... VOILA .... the lens came out when I powered it on and all is well! I know this is gonna help someone!
Posted on May 24, 2008
Does the camera extract/retract the lens during powerup?
Yes
Does the LCD display any indication of what is wrong?
No, Canon screen, then goes black, no error code like E18.
Is it just 6 beeps and then nothing with no other indication of what is wrong?
Yes
Posted on Dec 27, 2007
FIXED!
Back to nearly normal.. a bit noisy on the gears now.. but working fine.. and it had been dropped
Posted on Jun 29, 2008
  • 48 Answers
A couple things -
Posted on Dec 18, 2007
Lens stuck open
hey, I had the same problem when I accidentally droped my camera, some parts in the mechanism are probably broken or jammed.
Most likely repairs required.
Apr 13, 2008 | Samsung Digimax S600 Digital Camera
Bread does not rise enough I have carefully measured ingredients use rapid bake setting fleichmans rapid rise yeast checked water temp still having problems I have tried 4 times regular and rapid rise and...
A few tips.
The yeast must be absolutely fresh, use sachets instead of packets.
Keep yeast well away from the fats and liquids.
The fast rise setting will produce less rise than the full program.
You must only use strong bread flour.
Open lid immediately beep sounds.
Jan 10, 2011 | Panasonic SD-YD250 Bread Maker
All lights are blinking rapidly when trying to turn on and nothing works Thank you
DBowers check to make sure that your chair's motors are not in freewheel. If they are not check to make sure the charger is not still plugged in. If both of those are correct the chair might be in sleep mode. Check your owners manual to see if they tell you how to get it out of sleep mode. I think that on the Jet you turn on the chair and within 10 seconds push the joystick forward and hold it there until you hear a beep then immediately push it to the rear until you hear another beep then immediately release the joystick to the center. If you were in sleep mode the joystick should operate normally. Now I have had to try to get it out of sleep a couple of times until it returns to normal. Hope this helps
Sep 20, 2010 | Jet 3 Ultra Power Chair
Camera beeps and turns off and lens won't retract
Lens error / Battery expire.
1. Use a new battery will fully charged and then use it. Hope you get good result.
2. Some time lens zooming gear getting damaged by dust. if that gear is scrached by dust then your lens can't work and it will stucked. Your camera automatically turn off.
Of those 2 85% chance of poor/ long time used Battery & 15% chance of lens zooming gear damaged.
Thanks, i am waiting for your feed back & if you satisfied then thumps me please.
Jan 31, 2010 | Cameras
When I power up computer, I get 2 very rapid beeps, pause, 6 beep
it depends on the beeping
but i guess it's ur graphic card
make sure that the card is firmly in place and also check the memory modules.
Sep 14, 2009 | Sony VAIO RB30C (VGCRB30) PC Desktop
Camera will not turn on. Tried several new batteries.
I had (and continue to have - from time to time) the same problem. Each time I replace the batteries and try to turn the camera on, it will not go. I have found a simple "fix" with my own camera: that is to flip the on/off switch several times rapidly, and then, you will eventually hear the beep indicating the unit has powered on. Not really sure why this works, but it is the only way I can get mine to work. It has been a persistent problem since I have owned it.
Jun 09, 2009 | Panasonic Lumix DMC-LC33 Digital Camera
Lens problems
Try opening your camera, check the lens gear if its teeth are complete. If so, check if something stucks on it. Its much better to bring your camera to an authorized service center to re timing your lens track... ^_^
Jan 16, 2008 | Canon PowerShot A530 Digital Camera
Beep
The Polaroid Fun! Digital 320 camera is programmed to shut off automatically after a few minutes if it is not being used. This helps to conserve battery power. When the camera shuts itself off, it will make a continual beeping sound. To use the camera after it has shut off, simply push the shutter button or self-timer button to take a picture. If you are not going to use your camera, turn the power switch to OFF. The camera will also beep in rapid sequence after you press the self-timer button. The camera will continue to beep in faster sequence until a picture is taken (approximately 10 seconds). A final long beep signals that a picture has been taken. NOTE: It is normal for the camera to beep while downloading photos to a computer.
Sep 14, 2005 | Polaroid PhotoMax Fun 320 Digital Camera
Canon PowerShot SD400 / IXUS 50 Digital Camera Logo
933 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Doberman
Are you a Canon Camera Expert? Answer questions, earn points and help others
