Question about Samsung BP59-00016A Remote Control
My samsung BN59-00598A remote control is frozen and will not work, but has been fine , can you help me
I cannot get the battery compartment open on remote. Samsung UN50jU7100F
Samsung cannot open battery cover Remote Controls ...
www.fixya.com > ... > cannot open battery cover > Remote Controls
Samsung remote controls cannot open battery cover related questions and answers. Ask your Samsung questions. Get free help from remote control experts.
How can I solve if the remote control is not ... - Samsung
www.samsung.com/sa_en/support/skp/faq/239888
Samsung ElectronicsDec 11, 2014 - 1) Open the battery compartment on the back of the remote and ... If you have any digital camera (including a camera phone), you can test any ...
Remote Control Issues - samsung product support network
Jan 12, 2016 | Samsung Televison & Video
Need Samsung code that works
Try this link http://downloadcenter.samsung.com/c...984_BN68-00998A-01.pdf
Dec 07, 2007 | Samsung AH5900092W Remote Control
Any suggestions why my pro24z remote has frozen it is fully charged
sure your remote has frozen? you can check if it is still working, by pointing it to a digital camera (camera in a phone is fine) Then press one or a few buttons on the remote and look on the mnitor screen of the camera if you see a light flickering.
If you see a light, the remote is still working.
If some buttons don't work anymore, check if somebody poured in some soda or coffee.If so, you could try cleaning it. but the best thing to do is buy a new remote. Read how manny questions are here about "universal" remote controllers and all their problems and you might decide to buy the original.
Don't forget to replace batteries so now and then.
Jul 12, 2014 | Televison & Video
Frozen display
hi on the remote control press the i button this should remove the caption, go into the menu on the tv select display setting check the time out hope it helps
regards
shaun
Apr 02, 2014 | Samsung Televison & Video
Ah59-02342a doesn't control tv anymore
Hi I had exactly the same problem with mine it worked the DVD player fine but not the TV even though previously it had worked both .......... Manual Guide In the manual guide I managed to dig out it says to do the following to set up the remote to work the TV
Press the TV button on the remote
Then whilst holding down the power button you need to enter in the samsung TV codes until your TV turns off (I only got to the first and it did it)
The numbers are 00, 15, 16, 17, 40, 43, 46, 47, 48, 49, 59, 60, 98
Hope this helps
Feb 24, 2012 | Samsung TV Remote Control
Tv won't operate off remote control
Unless you had the remote tested by Samsung, the test isn't comprehensive; it will only tell if the remote is putting out infra-red of some kind, that type of tester cannot determine if the codes are correct or complete. The only true test would be one in which you had a second TV or a second, known working remote. Even using an oscilloscope with an infra-red detector wouldn't help unless one had the specific code sequences available, it would only appear as a pulse train.
Aug 18, 2008 | Samsung Remote Control
Samsung BP59-00016A Remote Control Logo
483 people viewed this question
Jerry Greenberg
Jerry Greenberg
