Question about Kitchen Appliances - Others
No water coming out of water filter
The water is not going from the plastic water tank reservoir into the internal chilling tank. Therefore the internal tank is empty. I have changed the filter to no avail. When I put the resevoir in position 1 bubble comes up but water does not continue to flow into the internal tank. If I remove the reservoir I can push up the valve and the water runs fine. The motor still runs when i push the button.
I put this under electric kettles as i could not find water filters.
    Problem Solver:
  • 17 Answers
Check to see if the filter is in backwards! most inline filters flow only one way!
Posted on Dec 21, 2007
Where is the filter
The filter is located in the water tank. There is a plastic insert that will hold the water filter in the tank.
Dec 28, 2014 | Keurig 2.0 K550 Brewing System
Why water comes out slowly?
This can be caused by several problems. The most likely is that your filter needs to be changed. Another potential problem could be that your fresh food side is too cold. There is a water reservoir in the back of the fresh food side to chill the water, if it gets too cold ice could be forming inside it, slowing down the water flow.
Other things to check is water pressure going to the refrigerator, and finally the water valves located in the back of the refrigerator could be starting to fail.
May 30, 2014 | Refrigerators
My Amana french door/bottom freezer is leaking water. Did the procedure with hot water the drain in back of the freezer, although it seemed clear of ice. That didn't help. The leaking stops when I...
Two possibilities:
1. A cracked plastic tube. These will leak whenever there's a call for water - either the chilled water dispenser, or re-filling the icemaker tray (two seperate tubes). Pay particular attention to anywhere the tubes are clamped to the chassis; anywhere they're routed near or under the refrigeration unit; and near the solenoid valve - especially if there's a tight loop in the tube there.
2. A bad (leaking) connection where one of the tubes exits the water valve. Again, these will leak whenever the valve is activated.
Those plastic tubes don't last forever. I've replaced many of them for the same symptoms. They're known to simply deteriorate with age.
Manuf's make good money selling replacement tubing kits.
Aug 15, 2011 | Amana AFB2534DE Bottom Freezer French Door...
Water dispenser does not dispence water
need to replace the water inlet valve. the part number for this model is 4389178
Jun 18, 2010 | KitchenAid Superba KSRG25FK Side by Side...
No cold water
Most refrigerators with a water dispenser have a reservoir (tank) to chill the water before it gets to the dispenser. This tank is typically behind the crisper bins so the water should be the same temperature as the refrigerator. The water may start out room temperature but should be cold by the time you have filled 1/2 a glass or so.
Saying all that, there are a few newer models out there that have reduced the cost of the refrigerator by eliminating the reservoir. If you take the crisper drawers out and look behind them and do not see a tank or coil of tubing then you do not have chilled water.
I hope this helps clarify.
Jun 14, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Filtered water not dispensing - ice is still coming through okay - when pressing the water dispenser button all you hear is a noise as if water should be flowing
Your water line is probably froze. Look in the back of the refrig section behind the shelves and see if there is a plastic tank, or a coil of plastic wire. That is where your water runs, so it will be chilled. If you are hearing a noise when you push the lever then that is your water valve, and that is good. You need to defrost that line.
Sep 08, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Amana side by side
Undissolved minerals can appear when ice cubes are added to chilled drinking water. Freezing tap water causes dissolved minerals to solidify and scatter, giving a cloudy appearance. When ice cubes melt, any undissolved minerals settle to the bottom. These mineral compounds in our drinking water are naturally occurring and safe.
Sometimes we see black particles which can be the non-stick surface of the ice mold flaking off.
Sep 07, 2009 | Frigidaire FRS23R4A Side by Side...
I would like to know something.I have a big plastic corel in the back of the crisper pan and I do not know where it go.I have a plastic tube which go from the water valve inlet to the drinking water line...
The coil of plastic tubing behind the crisper is your chilled water reservoir for the water dispenser. They use a coil instead of a tank because it chills the water more quickly and ensures good turnover of the water with less chance of stagnation.
Jul 27, 2008 | Frigidaire Refrigerators
Back reservoir
Kiwy, your part number for this reservour is 4838jj1003a. Since they had a lot of problems with this tank they replaced it with coiled plastic tubing. You can find the replacement part at, it will show you a picture of it. Or you can go down to your local hardware store, buy some 1/4 inch plastic tubing for water and 2 quarter inch John guest fittings to hook it up. That's all it is now, is coiled plastic tubing to chill the water. Catriver.
Dec 28, 2007 | LG LRBC22544 Bottom Freezer Refrigerator
Kitchen Appliances - Others Logo
205 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
