Question about Compaq Presario 700 470024-192 Notebook
Wifi not connecting correctly
It will connect but with liited or local access only i've put in all the codes needed and still not completly connecting.
    President:
  • 1,187 Answers
There is interference between the WiFi router and the computer, such as a metal file cabinet, refrigerator, distance (too many walls), stucco, etc.
Move the router if you can or re-orient the way it is "pointing".
To test this, move the laptop into the same area as the router, temporarily.
Does it work OK when close-by? If problem persists, consider obtaining a WiFi router that supports "N" wireless, even tho your laptop is "G", the "N" router can get around interference.
Posted on Sep 28, 2009
    President:
  • 2,600 Answers
Windows WiFi Fix,
Windows Zero Wireless Configuration is one of the best programs to run a WiFi in Windows XP or Vista. Most of the other software packages that come with the different adapters have been poor at best in keeping a connection through Windows. Here is the best guide to get you back up and connected.
Windows XP:
Click Start
Right click on My Computer
When a window pops up click on properties
Click on the Hardware tab
Click Device Manager
Click the [+] next to Network Adapters
Find your wireless card and right click on it.
Click Disable
Windows may warn you that disabling the device may make it stop functioning.
Continue disabling the device.
Wait 30 seconds or so.
Right click on your wireless again and click Enable.
Exit the device manager.
Reconnect to your router.
You should now be able to connect to the internet.
Windows Vista:
Click Start Logo
Right Click Computer
Windows will ask you about opening Device Manager Click Continue
Click Disable
Where do I find my SSID#
The SSID is the identifier for the wireless access point (AP) you are trying to connect to. If the AP is broadcasting, the SSID should appear in a list of available WiFi connections when you enable WiFi in proximity to the AP. The SSID is not necessarily a number, it can be ASCII text, such as "MyAP1234" or "Linksys". You click on the displayed SSID you want to connect to and if it is encrypted, you will be asked to put in the password or access code. Some AP/routers have the SSID and access codes printed on a label on the bottom of the router. Otherwise you have to get them from the provider of the WiFi access. Some AP's don't broadcast their SSID's and you have to get both items from the WiFi provider and use your phone's connect process to enter the SSID and access code.
Apr 25, 2015 | Kyocera Cell Phones
I have a problem too involving the wifi. My wifi win't turn on. It will just say wifi turning on, but then it will go back to wifi off. And I don't have a cellular data plan. Can anyon
Hi
If you don't have a cellular data plan as you call it you will only be able to use WiFi to connect to the Internet.
To connect to a WiFi system, you may need 3 pieces of information:
A username
A password
An encryption key
Once you have successfully linked to a WiFi access point then your tablet/phone will remember the settings until told to forget them.
A lot of the time you may only need the encryption key, and if the tablet detects a WiFi access point then if you tap on that in wireless settings then it will either connect automatically or ask you for some sort of code - the encryption key. If this is not entered correctly then it will return an authentication problem/error. In order to connect you have to have this code.
Cheers
Jan 31, 2015 | cellular Cell Phones
How do I get wi-fi connection. I have inputted information for the wi-fi it says saved, then when you go to connect it says authentication problem and cannot complete registration.
Hi
A username
A password
An encryption key
Once you have successfully linked to a WiFi access point then your tablet will remember the settings until told to forget them.
A lot of the time you may only need the encryption key, and if the tablet detects a WiFi access point then if you tap on that in wireless settings then it will either connect automatically or ask you for some sort of code - the encryption key. If this is not entered correctly then it will return an authentication problem/error. In order to connect you have to have this code. Also bear n mind that the code may or may not be case sensitive, and that the authentication type for both router and tablet needs to be the same. It is possible that you will only be able to change the authentication type on the Aceess Point / router and not on the tablet.
Cheers
Dec 25, 2014 | Tablets & eReaders
Why wont my huawei y530 connect to any wifi
Hi
First, make sure your WiFi is turned by going to settings> Wireless & Networks" If it is on then you will see a list of networks within range, each of which you can tap on to connect to it.
To connect to a WiFi network, you may need 3 pieces of information:
A username
A password
An encryption key
Once you have successfully linked to a WiFi access point then your phone will remember the settings until told to forget them.
Cheers
Nov 27, 2014 | Ascend Huawei Y530 - Unlocked, Black, 3G,...
How do I connect to my wifi
Hi
A username
A password
An encryption key
Cheers
Nov 17, 2014 | Polaroid 7" Internet Tablet Android 4.0...
Netgear wifi router
1) does it lock up completely or will it work hard lined when wifi fails?
2) do all devices wireless fail or just a single device?
3) do you lose connection to the wireless completely or keep the connection but lose access to the internet? (confusing but very different to me)
in the end you could narrow down the problem but if you have already reset to factory defaults and set back up again and again then it may be time to retire that old router.
Dec 28, 2012 | NetGear DG834G Router
Is there a fix to wii error code 50300 ?
The Wii console's internet connection settings are not correct. This could include your network name (SSID), WEP or WPA keys, or any manual settings you may have entered.
It's possible something has changed since you last connected online with your Wii console. Try setting up a new connection file, using your router's settings.
While "Search for an Access Point" is the easiest and recommended connection type, your network may require you to use the "Manual Setup" option.
If the problem persists, try our general troubleshooting for tips.
If you are still getting this error code, please call 1-800-255-3700 for further assistance.
For more help visit cbrtechsolutions
Mar 27, 2012 | Belkin Surf N300 Wireless N Router
How do i set up my daughters connection for er dsi? error codes 051099-1 comes up and the dsi says: no access point in range. check your ssid settings or move closer to an access point. what do i need to...
This probably means your not connected to any wifi.
You can check for a wifi access point by following these steps
  1. Go to your dsi settings (the wrench icon)
  2. Scroll over to the third page, and select "Internet."
  3. now choose "connection settings"
  4. click on one of the them that says "none"
  5. Click on "Search for an Access Point."
  6. a list of wifi access points should pop up
  • The wifi connection you are connecting to must have No Security or WEP
  • If the wifi connection is WPA you will not be able to go online for games
7. Choose one of those access points to connect to and if it is secured by WEP you must put in the password for that access point.
Good luck :)
Jul 21, 2011 | Nintendo Video Game Consoles & Games
Hi I'm trying to use my desktop pc with ASUS P5Q3 Deluxe Wifi AP @n motherboards onboard WLAN as an Access Point to my Nokia X3-02 phone for WLAN. Would be nice to use same internet connection through...
you might have to open up your network connections click start control panel network connections this may vary depending on your operating system look for local area connection if you see a red x or a yellow exclamation or question mark you will need to update or install the driver or it could be firewalled
make sure your modem/routers settings are correct ie:password user name,firewall settings to allow your internet to connect to your phone
hope this helps
May 10, 2011 | ASUS P5Q3 DELUXE/WIFI-AP CH1-11 LGA 775...
I am trying to install my netgear Universal Wifi Range Extender WN2000RPT. I have green lights for my connection to the router, the extender is on and it is connected to the main PC. But I only have...
For that you need to check WAN settings and also make sure local ip settings gateway should be your router ip address. Make sure WAN settings are fine connect internet cable to WAN port of router. Then check. You can configure router with below method. Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. Then configure wan settings and lan settings enable wireless if you want to use wifi Then save settings and restart router Then connect cable from internet service provider to WAN port of router and connect ethenet lan cable from computer to lan port of router. . Let me know if you need further assistance. Thanks for using FixYa.
Nov 10, 2010 | NetGear Computers & Internet
Compaq Presario 700 470024-192 Notebook Logo
111 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
