Question about Linksys WUSB300N Wireless Adapter
No power as led indicates
Led for link turns on but for the power is off when adapter is inserted inot the usb port.
adapters seems not working as i hav checked my connections. b4 it was working well. what seems to be the problem. thanks.
    Problem Solver:
  • 4 Answers
Turn off monitor of, wireless, so that windows wireless zero is your adapter the installed adapter dose not work as good as windows.restart your computer. if you try another port always restart after plugging it in a new usb port. I had the same problem. also you might have to uninstall and reinstall. then down load the latest updates.
Posted on May 15, 2008
My laptop is not powering on help
1.Connect the Ac adapter to a known good power outlet. Check the Power LED indicator on AC adapter (without plugging into the Notebook). We are only checking the power AC adapter to see if that is working.
2.If LED on the AC adapter is not lit (when unplugged from notebook), reseat the AC adapter brick and cable. If still there is no light on AC Adapter replace AC adapter and Power cord.
3.If LED on the AC Adapter goes off only after connecting to Notebook, the issue is with the motherboard. Replace Motherboard, DC-In port (AC adapter connector).
4.If the AC Adapter LED is always ON, take a technician's help and reseat the Power Button Board. You can refer to the Service Manual for details on how to reseat the Power Button Board. (NOTE: Before the notebook chassis is opened ensure all the power connections including battery and external devices are disconnected)
Jun 07, 2014 | Dell Inspiron Laptop 1440
Laptop port is broken
When you connect the power adapter into the laptop, does the power LED light up? If not then - The battery adapter or the adapter's power lead or the laptop's power socket could be faulty. Check power adapter's DC plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced. If the adapter is OK then connect it to the laptop and power it up, then look at the power/battery charging LED light and wriggle the power plug in the laptop's power socket. If the power/battery LED light flashes and in a certain position this LED light stays firm, then the power socket is either faulty or it has a dry solder joint where it is connected to the motherboard. This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. If you cannot DIY then I suggest you get a quote first.
Apr 16, 2013 | Samsung Computers & Internet
Hi, I'm facing following problem, can any one help me please? Seagte external hard disk GoFlex Desk 1TB (STAC1000300) with USB 3 adapter STAE 106 is not working. When the USB 3 cable is connected to...
just install seagate free agent using this link
http://www.seagate.com/ww/v/index.jsp?locale=en-US&name=goflex-software&vgnextoid=11c1fab114b48210VgnVCM1000001a48090aRCRD
then try again if problem not solved, mail me to tsnp@ymail.com
Apr 19, 2011 | Seagate FreeAgent GoFlex Desk Desktop...
I have an AspireOne netbook that has always worked till yesterday when it did not want to come on. It lights up for a couple of seconds and turns off. It did this last night ... but finally did come on...
Whenyou connect the power adapter into the laptop, does the power LED lightup? If not then - The battery adapter or the adapter's power lead or the laptop's powersocket could be faulty. Check power adapter's DCplug that connects into the laptop power socket with a multi-meter, the voltageshould be slightly higher than the voltage that is printed on the label on thebottom of the adapter. If the voltage is zero or way below the voltage that isprinted on the label then the power adapter is faulty and needs to be replaced. If the adapter is OK thenconnect it to the laptop and power it up, then look at the power/batterycharging LED light and wriggle the power plug in the laptop's powersocket. If the power/battery LED light flashes and in a certain position thisLED light stays firm, then the power socket is either faulty or it has a drysolder joint where it is connected to the motherboard. This can be repaired but itrequires the laptop to be completely dismantled to get at this power socket andrepair. If you cannot DIY then I suggest you get a quote first.
Apr 14, 2011 | Acer Aspire One AOA150-1570 Notebook PC
Hai mr.igot problem when i install usb bf-810 iwas isntal driver but when i plug the port inthe PC it's show"USB devivice not recognice"can u solve my problem
Before you start installing the driver, please don’t plug your USB TO Serial Adapter into the USB port of your computer.  Follow the steps below to install Windows® 98 or Windows® ME driver 5.1 Turn on the power of computer and make sure the USB port is enabled and can working properly. 5.2 Insert the driver of USB-SERIAL ADAPTER into CD-ROM drive. Select “Install Products - USB-SERIAL ADAPTER - Install”. 5.3 Select the “Next” to install.
Before you start installing the driver, please don’t plug your USB TO Serial Adapter into the USB port of your computer.  Follow the steps below to install Windows® 2000 driver 6.1 Turn on the power of computer and make sure the USB port is enabled and can working properly. 6.2 Insert the driver of USB-SERIAL ADAPTER into CD-ROM drive. Select “Install Products - USB-SERIAL ADAPTER - Install”. 6.3 Select the “Next” to install.  Before you start installing the driver, please Don’t plug your USB TO Serial Adapter into the USB port of your computer.  Follow the steps below to install Windows® XP driver 7.1 Turn on the power of computer and make sure the USB port is enabled and can working properly. 7.2 Insert the driver of USB-SERIAL ADAPTER into CD-ROM drive. Select “Install Products - USB-SERIAL ADAPTER - Install”. 7.3 Select the “Next” to install.
.1 Driver Installation (MAC OS X) 8.1.1 Power on your computer and make sure that USB port is enabled and working properly. 8.1.2 Insert the USB adapter software driver into CD-ROM driver. 8.1.3 Click "USB-SERIAL ADAPTER\DRIVER\MAC\OS X " folder run on "PL2303_1.2.1r2.dmg", it will auto run the program and appear "PL2303 driver" folder in the desktop. 8.1.4 Click on "PL2303 driver" folder , execute "USBSerialOSX1.0.9b6.pkg" will auto install, you may change the driver directory that you want to install. 8.1.5 System will demand restart computer. 8.1.6 Plug in the USB-Serial adapter into USB port. 8.1.7 To make sure that your computer can use the device, you have check the "Apple System Profile"-"Device and Volumes". It will show the USB Device.It will show in USB port "USB-Serial Controller". 8.2 Driver Installation (MAC OS 8&9) 8.2.1 Power on your computer and make sure that USB port is enabled and working properly. 8.2.2 Insert the USB adapter software driver into CD-ROM driver. 8.2.3 Click "USB-SERIAL ADAPTER\DRIVER\MAC\OS_89" run on "PL2303_OS9_v136b1.hqx",it will auto run the program and appear "ProlificUSBSerial" file. 8.2.4 Copy "ProlificUSBSerial" file into "system folder"-"Extension". 8.2.5 Plug in the USB-Serial adapter into USB port. 8.2.6 To make sure that your computer can use the device, you have check the "Apple System Profile"-"Device and Volumes". It will show the USB Device.It will show in USB port "USB-Serial Controller". Follow the steps below to install driver of USB-Serial adapter:
hope that helps you
May 29, 2010 | BafoTech BAFO BF-810 Serial Adapter
My Microsoft Xbox 360 Wireless Network Adapter stopped working.
Shut off your console and unplug everything.
Connect the adapter then connect the console back together...Turn on console......Go to network configuration...Make sure u are connecting the adapter from the back!
If you are not able to achieve a connection for several attempts this means your should check warranty status for the adapter also.........If you unplugged it while the console was one you could of shocked the cable an blew the fuse.......Normally when u detach any components with a usb port u should alway make sure every thing is shut off before so.
www.xbox.com/support
Jan 14, 2010 | Microsoft Wireless Network Adapter Xbox...
Xbox 360 Wireless adapter no power
try to use the front USB ports if this wont fix it you will have to send the adapter back to the CO or the store where you got it
Jul 20, 2009 | Microsoft Xbox 360 Console
Hard drive doesnt turn on
It appears that your USB hard disk is drawing power that exceeds what the computer's USB port can deliver.
If your USB drive has a power adapter, connect it to your USB drive before you connect it to the computer's USB port.
If your USB drive does not have a power adapter/connector then you need to insert your USB drive into a USB hub that is powered from the mains adapter. Connect this hub to your computer's USB port first and then connect the USB drive into the powered hub.
If none of this works then it is possible that you have a faulty hard drive. If possible test this drive in a computer, use a old computer.
Dec 02, 2008 | Acomdata Computers & Internet
No connection
check when u insert wireless adapter in usp port, does any light comes on or not on the adapter itself
if it comes and it still does not work then try to uninstall and reinstall the drivers for this adapter in ur pc
and if no lights come on , then also try to uninstall and reinstall the drivers and also check it device manager whether the usb port is enabled or not
Feb 18, 2008 | D-Link 802.11g Wireless Router WBR-1310...
After connecting to the usb, led lights up, then off, windows does not detect it.
Is the hub you mention, an extension from another usb port only, as the adapter may need to be powered and require a AC/DC powered hub to work.
Jan 10, 2007 | Ashton Digital WRUB-2011i (Twin Pack)...
Linksys WUSB300N Wireless Adapter Logo
66 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
