Question about White Sewing Speedylock 1600 Mechanical Sewing Machine
Ihave 1600 speedyloock my machine lower looper part is broke-how to get this part please tell me where i get this part
    Sergeant:
    Champion:
  • 269 Answers
Go to Mfg.'s website
Posted on Sep 28, 2009
    Sniper:
  • 61 Answers
I've found parts quickly at www.a1sewingmachine.com/parts.html. They will check availability from email, let you know price, and get it to you quickly. Check with them.
Posted on Nov 10, 2010
I have a funlock 004D/004, the lower looped broke and I replaced it with one I ordered online. It makes a chain when I run it but when I try to sew fabric nothing catches. Any suggestions?
you have to make sure the looper is properly positioned. With the screw loosened slightly you should be able to move the looper up and down slightly, thus adjusting the timing. You are looking for the lower looper tip to come in slightly above the needle eyes, as close as possible without touching. Then the upper looper must come in right behind the lower looper "head" as close as possible without touching. The upper looper should then extend past the left needle by about 2-2.5mm, and the needles will come down before the eye of the upper looper returns to the right.
Dec 12, 2016 | Sewing Machines
Thread broke on bottom looper the first time out of box i had to try and thread and the tension was still tight The bottom threads were not stiching
I'm going to assume here you're talking about a serger. Unthread the lower looper and the eyes of the needle. Set the lower looper tension to 0. Rethread the lower looper, then the needle eyes. Then reset the lower looper tension (try about half a number lower) and see if it chains. If it won't chain, try replacing the needles.
Mar 17, 2014 | Janome Sewing Machines
Lower loopers are loose
what ever fabric you use the tension must be adjusted if nessary
here are 2 links for a free manual from singer pick the one best for
you
http://www.singerco.com/uploads/download/754_sl-1600-x.pdf
http://www.singerco.com/uploads/download/979_sl-1600-x.pdf
Aug 23, 2012 | White Sewing Speedylock 1600 Mechanical...
Fix timing on juki
Don't forget there is a "hidden" threading phole all the to left side of lower looper before it gets threaded front to back in the threading hole on horizontal lower looper that is visible looking at machine head on.
Hope this helps.
Jimmy
Apr 06, 2012 | Sewing Machines
I have a coverstitch PF857 and I have broken the upper over edge looper I have sent for the spare part but been told it must be set what does this mean and how do I do this
There are many adjustments which can be made: up, down, twist right or left, slide front or back. The main question is why did the looper break? The needlebar, upper and lower looper and the needle guard all must be in perfect syncronization. The upper looper must be set so that, on its movement to the right, ever so slightly brushes the needles. Then, as it travels upward, it must cross behind the lower looper at just the right spot as close as possible without touching. If you are very mechanically inclined, give it a shot. If not, the risk of further damage is high.
Jul 12, 2009 | White Sewing Speedylock 1600 Mechanical...
White speedylock 7340 loose/missing stitches, up.looper unthreads
All tensions should be on 4. Also, make sure the threading is done correctly. Or if you wish; You can contact me on other sergers for sale. "Best prices guaranteed"! rick_coccia@yahoo.com
May 21, 2009 | White Sewing Speedylock 1600 Mechanical...
Lower looper unthreads itself while sewing
Change the needle. I know this sounds wrong but it does fix this problem.
May 10, 2008 | White Sewing Speedylock 1600 Mechanical...
Lower loop broke- do I have to start from step one?
yes, take all threads out, and re=thread according to the diagram, following the threading order.
Mar 02, 2008 | White Sewing Speedylock 1600 Mechanical...
Lower looper needle broke
 Well, first of all, while it might be possible, I highly doubt it.
More then likely the timing is off. There are several adjustments that need to be made correctly or you will end up with more problems. Your best bet is to take it to a qualified service technician.
Aug 23, 2007 | Janome MyLock 634D Mechanical Sewing...
My 1034D serger has a broken part that holds the lower looper.
call brothers hot line 1-901-373-6256 tell them your problem and part no, if you know it if not they should be able to help you
Aug 16, 2007 | Brother 1034D Mechanical Sewing Machine
White Sewing Speedylock 1600 Mechanical Sewing Machine Logo
145 people viewed this question
Top White Sewing Sewing Machines Experts
Tally Girl
Tally Girl
tsalagi152
Are you a White Sewing Sewing Machine Expert? Answer questions, earn points and help others
