Question about General Electric WCVH6800J Front Load Washer
I want to change my LG front load washer so i will open to the right
  • 1,543 Answers
Sorry, but the door on the washers are not reversible, only the dryer doors are reversible. I'd suggest using a low profile telescopic style dryer vent to allow you to put the washer on the left side without worrying about the dryer vent location. You can get longer dryer power cords if needed, and water supply extention hoses, or just longer hoses if needed. The drain hose is usually long enough to still reach the drain. I have done this many times.
Posted on Sep 28, 2009
  • Carl Schulzetenberg
    Carl Schulzetenberg Sep 28, 2009
    Larger Image Be the first to write a review.18-29 Adjust PeriscopeBuilders BestModel: 10133Do it Best SKU: 274585Online Price: $21.99 Online Price vs. In Store Price Free Shipping: Ship-to-Store
    At this location
    Arrives in 7-10 business days
    Learn More
    Builders Best
    Adjustable Periscope 18" To 29"
    Adjustable periscope from 18" to 29". Used to reduce space between dryer and wall from 4-1/2" to 2-1/2" for closer clearance. Beveled ends eliminate interference with floors and side walls. Sections separate and can be reversed for easier connection. May also be used for side access venting. All metal rigid construction.
    You reverse the one section so the inlet points the oposite direction than the way it is pictured. Available at Do It Best hardware, and most likely others, plus appliance parts sources.
Makes noise in spin cycle and now it started smoking. Tub seems to spin more easy but i don't hear anything like a bearing.
LG WM2688H Front Load Washer Smoking power ... - Fixya
www.fixya.com > ... > LG > WM > LG WM2688H Front Load Washer
LG WM2688H Front Load Washer, smoking power related issues. ... is it worth trying to fix drum loud and rattles when on spin cycle, then smoke started pouring out of ...hi working till smoke came out the back and now no power - Unplug it. ... washer makenoise doing spin cycle smell smoke make the power cord warm to ...
LG 4280FR4048L Bearing - AppliancePartsPros.com
www.appliancepartspros.com > ... > Washer > Kenmore Washer Parts
Rating: 5 - ‎189 reviews - ‎$32.19
Burnt rubber smell at end of cycle from 11 yr old lg wm2277hw front load washer i hand spun inner drum it was ... Appliance: LG Washer WM2277HW ... Our LG "Tromm"washer (a.k.a. "Trommy Baby") started making a horrible ... The bearings were worn and made very loud noise in the spin cycle John A. • Punta Gorda, FL.
LG WM2455HW washing machine problem - YouTube
? 10:29
https://www.youtube.com/watch?v=__abhTwmi1I
Sep 15, 2010 - Uploaded by djmcarter
I also have an LG refrigerator, which makes a loud sound (it's the.... I am watching your video while mopping up water underneath the exact same machine right now. ... How to Fix an LG Front load washer machine that wont spin - Duration: 5:32. ...
Jan 19, 2016 | LG WM2277H Front Load Washer
Do I have to take apart the whole machine to fix the drain pump on my LG WM3455HW washer/dryer combo? I can't seem to find any instructions on this model.
Lucky You. The newer models of LG Combo units WM34xx have the filter on the right hand side and the pump can be changed through the bottom panel.
Nov 17, 2015 | LG Washing Machines
Does LG Model WM2301H come in model with door opening left to right instead of right to left
Sorry - there is no retro-fit adapter that will allow you to change the swing.
Thanks for using FixYa - a 4 THUMB rating is appreciated for answering your FREE question.
Jul 19, 2010 | LG WD-1080FD Front Load Washer
Where do I find the serial number on my lg washer
Open the front door on front-loading washers. Look at the upper part of the door frame just above the opening.Look at the right side of the washing machine near the front, upper corner on top-loading washers.Identify the location of the metallic rating plate attached to the frame.Find the serial number by identifying the number that follows the "S/N" printed on the plate.
Jun 12, 2010 | LG WM2301H Washer
Washing machine makes noise on spin machine type LG
THE SOUND YOUR HEARING IS THE REAR BEARING BETWEEN THE STATOR AND THE DRUM. IF YOU'LL PULL THE BACK PLATE OFF THE WASHER IT'S PROBABLY STARTING TO GET A LITTLE DRIP RIGHT ABOUT NOW TOO. BEARING COSTS AROUND $20.00 OR SO AND IS RELATIVELY EASY TO CHANGE. YHE EASIEST WAY TO MAKE SURE IT'S THE BEARING WITHOUT PULLING IT OUT AWAY FROM THE WALL IS OPEN THE FRONT DOOR AND SEE IF YOU CAN SHAKE THE DRUM UP AND DOWN AND SIDE TO SIDE.
Sep 25, 2009 | LG WM-2277HW Front Load Washer
Washer door opens with hinges on the left
nope sorry but all front load washers are built with a locking system on the door and that makes them impossible to change the door swing.
the only thing you can do is move the washer and dryer position by getting longer hoses and venting so you can have the washer on the left and the dryer on the right.
Dec 28, 2008 | LG Washing Machines
Suds leaking from back of washer near top
Suds are not supposed to leak from the top; means you are not using the right detergent. Use front loading powders. You can open up the top during next wash to locate where the leak is coming from (after changing powder). I understand suds appear in the window during spin....but leak? Caution when machine works with top open!
rate if helped pl........
Dec 29, 2007 | LG WM1814CW Front Load Washer
"Door Locked" Indicator Switch Faulty
You should access the lid switch (the switch is inside the machine main housing near the door frame) and to see whether it become loose or was broken. Good luck!
Aug 18, 2007 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
General Electric WCVH6800J Front Load Washer Logo
795 people viewed this question
Top General Washing Machines Experts
Dan Webster
Dan Webster
Sal DeAngelo
Chris Goulet
Are you a General Washing Machine Expert? Answer questions, earn points and help others
