Question about HP Officejet 4315v All-In-One InkJet Printer
Paper is feeding through printer like it's going to print but doesn't actually print the document
  • Mujahid498 May 11, 2010
    Thank you but your information is not good enough to resolve the issue so I request you to please getback with this below information. Let me inform you that I can help you in resolving the issue.
    * Operating System:
    * Connectivity:
    Sergeant:
    Champion:
  • 269 Answers
Uninstall the printer from the CPU.Reinstall the driver according to the installation guide that should solve the problem.This may sound stupid but are the ink cartridges have ink or installed properly?
Posted on Sep 28, 2009
Panasonic KX-P7110 printer won't print from the auto feed tray, shows error when printing is attempted.
Please check the entire length of the paper feed path from input to output for a small piece of paper that is stuck causing a "Paper Jam".
You are lucky that you can still print manually as this usually shuts a printer down until the jam is found and removed!
Good Luck!
Rich Lilja
Jan 06, 2014 | Panasonic KX Office Equipment & Supplies
Blank page feeding during print job
Please adjust paper size in printer properties.
Oct 09, 2008 | HP Deskjet 6940 InkJet Printer
The paper will not feed through the printer
There could be something blocking the paper path that's not allowing the paper to not go all the way through the feeder. Try to open the printer and access the cartridge area. Remove the cartridges. Check for any foreign objects blocking the paper path. Rebrick your printer by removing the power adapter (black box found on the back of your printer where the power cord is plugged in) and then re-plug after 30 seconds. When your printer turns back on, re-insert your cartridges. Then try print your document again to verify that the problem is fixed.
Nov 10, 2011 | Lexmark X2670 All-In-One Printer
Double printing on pixma mp470
Double printing or double feed??. Double printing means document printed in 2 copies. Double feed means printer feed double paper in one moment. For double printing,please check number of copy of document in printing preference properties.
Double feed occurs when pickup roller fails to pick the paper correctly. It's usually caused by shaft of paper pick up roller which is broken. You should replace drive assembly (include pick up roller) in this case
May 13, 2010 | Canon PIXMA MP470 All-in-One Printer
Brother mfc-7420, how do I get off manuel paper feed
Thank you for following me up, I managed to discover that the document I was trying to print was set up for manuel paper feed, other documents subsequently went back to normal after printing the offending document. However is there a setting on the actual printer to control this.
Regards John
Oct 09, 2009 | Brother MFC 7420 All-In-One Laser Printer
Tray selection issue: Documents may be setup to print to the MP feeder, (multipurpose feed, not manual feed), but the printer will only pull from tray 4. I'm not sure why, earlier this week it would o
The usual reason that the printer will ask you to load paper into the MPF is that the green paper guides in the paper tray is not clicked in the right position. It only needs to be slightly out of position to give the wrong paper size info to the printer. The easiest way to confirm if the guides are correct is to print the Menu Settings Page. Check that the paper sizes listed in that report are the same as the actual paper sizes in each tray. If it's different you need to adjust the guide correctly. It's remotely possible that the sensing switch is faulty but it's more likely that the paper tray guide isn't latched in it's correct position.
May 29, 2009 | IBM Infoprint 1532 Laser Printer
I have an HP printer scanner 1310 series. Have trouble with printing. It will run about 3 blank pages through before it will print. Then it will run a page part way through so have to open back to get it...
Hi Audrey-
There are many things that will effect how your printer handles paper. The most overlooked being the size of the document or image to be printed. If the image or text bleeds over the edges (left, right, top, bottom) of the document, several sheets can be ejected before the "visible" printing takes place. Often those first few pages look blank, but actually are the outer edges of your picture or text. If you are printing a large picture or large text document, this may be your situation. Try printing a document with just a few words on it (like a small email) as a test.
The second most common culprit is dusty, dirty feed rollers in the printer. Consult your HP 1310 series manual for instructions on cleaning the feed rollers, or consult this general cleaning article on HP.com. HP PSC 1310 All-in-One Printer series cleaning
The type of paper can also effect how many sheets are pulled into the rollers. Is the paper new?, Thick?, Very thin?, or is it the same ol' printer paper you've always used? Either way, remove the stack of paper from the feed tray, "fluff" it by fanning it (like flipping through a book very quickly, or the way Superman counts a stack of money!) and replace. Print a test page.
Let me know if this helps!
Dec 29, 2008 | HP PSC 1315 All-In-One InkJet Printer
HP 6200 without telling it to print, feeds and jams continually
I already encounter that problem lately. when you print your documents, the only response of the printer is paper jam. feed and jam.
try this tip if acceptable of your situation now.
only to do is copy your documents by edit button and then select all or highlight all that your going to print and then right to copy
and then, open a new documents page set up if needed.
and then print it without saving your file because that already save.
Dec 05, 2008 | HP Officejet 6200 All-In-One InkJet...
The Paper light keeps flashing when theres paper in the printer
A few things could be happening here.
1. Clear the print queue, and if there are jobs that won't delete, reboot the computer.
2. Now clear the jobs on the printer (cancel job button) until the status light turns green.
3. Put a piece of paper in the manual feed tray on the front.
4. Print a test page.
If the test page prints to the paper in the manual feed tray, then it is set as the default tray. Go into the printer settings and change it to "auto" or tray 1. If the test page prints to tray 1, but the original document you tried to print (when it got stuck) still won't print, cancel the job. Now, again, put paper in the manual feed tray. Try to print the document again and if it pulls from there, go into page setup of your document and change the setting from "manual" to "auto" or tray 1. Clear the job again (if it's stuck) and you should be able to print again. Hope this helps. This is one of the most common solutions - it happens a lot, especially with documents that are emailed from other people and once they get stuck in the queue, nothing will print (except the test pages directly from the printer, like you describe).
Jun 25, 2008 | Brother HL 5250DN Laser Printer
Paper Feed
The problems are particularly frustrating if it's a Word 2007 document that you're trying to print. Open the document, go to the Page Layout tab, select Page Set Up > Paper and set your printer source to whichever tray you want. Apply to the whole document and voila !
Apr 08, 2008 | Canon PIXMA iP5000 InkJet Photo Printer
HP Officejet 4315v All-In-One InkJet Printer Logo
29 people viewed this question
Seeker5211
Seeker5211
