Question about Thermos Grill2Go Fire+Ice
Got a Thermos "Griil 2 GO" not sure what kind or size propane to use or how to connect it. Don't have the owners manual, and have never used it before--a hand-me-down from my dad.
  • 439 Answers
You can use a large tank or the small green tanks. There will be a connection on the right side of the grill for the can to screw onto either mounted or hanging. It will be in the back of the grill.
Posted on Sep 28, 2009
Why it can't keep hot?whats the problem?
dumb thing to check. Make sure all propane tubes feeding gas to burners are clear. Spiderwebs or bugs making nests inside will block most/all propane and it will leak out the air ports where the tubes connect to back of valve. fire hazard. use pipe cleaners or special flex brush available at hardware stores.
Jun 15, 2013 | Thermos Grilling
Need a regulator for Thermos Grill 2 Go
I bought this to replace the regulator I lost for my Thermos Grill2Go. Little modification to the grill and it worked like a champ. Portable Propane Table Top Regulator 1 by 20 Female Throwaway Cylinder... need-regulator-thermos-grill-2-go-2i4ggwcr0e0sverpwaph0wvr-1-0.jpg
Aug 22, 2012 | Thermos Grill2Go Fire+Ice
Gas is connected and when the igniter button is pushed the grill does not light
I am assuming this is a problem with an out door propane grill, most igniter are charged by a battery AA size, to excess the battery you should check your owners manual but some of them twist off to expose the battery so it can be changed, if the battery is good(new) make sure you hear a click and look into the grill(make sure the propane is OFF while doing this step) and you should see a spark. If you need a owners manual you can online to the manufacture and they usually are available for a free download. to recap: 1. Test Battery 2. Turn on propane tank 3. Turn on grill 4. Press Igniter 5. Turn all gas off after testing If you still have problems I would recommend getting a owners manual and see what they recommend in the trouble shooting area. If you still need to please contact me and I will help you.
Thank You.
Jun 06, 2011 | Garden
Dual fuel thermos m#461262006 swicth back to propane
You can get the manual on the link below. Make sure you have the right regulator for the propane and not one for Natural Gas.
http://www.managemylife.com/mmh/lis_pdf/OWNM/L0807110.pdf
Apr 28, 2010 | Thermos Stainless Steel Gas Grill
Converting Thermos Stainless Grill to natural gas
You have to install a conversion kit for it to work the way you want. The reason is because the orifice in either the valves or the main "jet" that feeds the burner tube has to be changed. Natural gas is really not as efficient as lp gas (propane) because it takes more natural gas to create the same btu output as propane.
In short, your grill will not work if you do not do the conversion. I am including a link that lists the conversion kit for your grill, you can order it there and you can download the assembly manual as well.
Here is the link: http://www.charbroil.com/Consumer/product_detail_e.aspx?ProductID=1723&CategoryID=25
Nov 20, 2009 | Thermos Stainless Steel Gas Grill
Inefficient high pressure cast iron propane burner
Make sure you are using an adjustible high pressure regulator. Make sure there are no obstructions insde the burner tube or burner holes.
Oct 31, 2009 | Thermos 0210-1309 Turkey Fryer
Converting to gas
If it does not get hot enough when using natural gas then the small propane orfices must be sized larger for the equivalent BTU rating of propane. Conversion tables are online via Google
Jan 03, 2009 | Barbeques Galore Turbo Elite 4-Burner with...
Grill 2 go parts
I have the same problem no reg. and no connection pipe, where can I get?
Mar 18, 2008 | Thermos Grill2Go Fire+Ice
Gas bottom shelf for Thermos Grill2Go ,Fire and Ice.
try this: http://www.thermos.com/contact.aspx
Mar 07, 2008 | Thermos Grill2Go Fire+Ice
Thermos Grill2Go Fire+Ice Logo
98 people viewed this question
Top Thermos Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
jdthefixer
Are you a Thermos Grilling Expert? Answer questions, earn points and help others
