Fan not working on a Bryant air conditioning system
  • 358 Answers
If is the inside fan could be a fan relay , the capacitor ,or the fan motor itself ; if the problem is with the outside fan , first check for bunrt wires , or could be the fan capacitor or the fan motor itself.
Posted on Sep 28, 2009
Just replaced the capacitor, and reconnected. Turned power on and heard a buzzing sound from the condensor, then the fan turned on. the unit only runs for a few minutes then shuts off
The buzz is the compressor failing to start.The blue or purple wire from the compressor goes to herm on the capacitor. If it's wired right and does not stare the compressor is bad.
Jun 23, 2014 | Bryant 2 Ton 17 Seer Air Conditioning...
Bryant central a/c working great, then suddenly inside fan not working, but outside unit on and pipe frozen.
sounds like inside coil froze due to low air flow. bad fan motor, fan relay,dirty coil or filter.
Sep 09, 2013 | Bryant Heating & Cooling
Furnace heats up fan turns on then turns off 2min later then back on backoff might finish cycle
Sounds like an air flow problem furnace going off on limit check filter and blower could have a clogged air conditioning. A coil. 20 years plus experience in this fieldl
Jan 18, 2012 | Bryant Heating & Cooling
Ac compressor runs, no blower fan. fan and capacitor ok. bryant
so the outside compressor and fan are working good ? If the fan and capacitor check out good then check that the wire from the thermostat for the fan (usually green and tied to grey on a bryant) has voltage and if it does the control board needs replaced because it contains the fan relay
Aug 19, 2010 | Bryant 462AJC021BA Air Conditioner
The fan on my outdoor compresser unit has stopped working the motor is humming and the fan doesn't turn if you manually push the fan blades around the fan will spin but at a very slow speed. The unit was...
It could be either one or both...usually I like to do both at once because either one can cause the other to fail...that problem is a common one for air conditioning units...
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool…
Air Conditioner Trouble -Review the Possibilities
http://www.fixya.com/support/r3571569-air_conditioner_trouble_review_the_possi
heatman101
Jul 23, 2010 | Bryant 463AAC008BA Air Conditioner
I have a Bryant split unit. After incurring some water damage that I assumed was from the overflow pan (the damage came from a poorly insulated elbow in the duct that was sweating) I opened the unit and...
Most all brands of air conditioners are built along the same lines, and for the most part are equally well designed/constructed. Bryant AC's in my opinion are as good as any - and - although - I don't know all the facts about your problem - I do know - that the 'installation of the air conditioner' is as important (if not more) than the brand.
It sounds to me like the blame for your troubles can be traced back to how it was installed.
I would get in contact with an Expert Air Conditioning person who could 'look over' your system and correct this problem - along with any other 'potential problems' you might be unaware of.
hope this helps
Jun 25, 2010 | Bryant 463AAC008BA Air Conditioner
Bryant air condition fan outside not coming on
Check breaker for outside unit Also check to see if you ahve afloat switch on the inside air handler. Located under or in front of unit. It may be full of water and tripped. Blow out drain if tripped.
Jun 15, 2009 | Ruud UBHC Air Conditioner
Bryant Legacy Line air conditioning not blowing cool air..
Your outdoor condenser is in heat mode. Check the wires on the thermostat. Sounds like a small wiring problem and nothing else. Good luck. Please keep me posted as to you progress.
Apr 27, 2009 | Bryant 462AJC021BA Air Conditioner
Heating & Cooling Logo
257 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
