Question about Albatron Nforce2 (KX18D PRO II) Motherboard
Your CPU had a problem
Hello, I had motherboard Albatron KX18D proII, when I turn on my komputer with normal bios I heard a sound like "Your CPU had a problem" but when I switch to mirror bios (backup bios) on the sw1 the komputer turn on normally but on the screen there a message "rescue bios", could you tell me what throuble is it ? ( I had already change VGA, DDR but still cannot turn on except I switch to mirror bios) thank for your information
  • bobzombie Nov 25, 2008
    computer cannot bot normaly and a voic said: "your cpu may have a problem"
    But i can boot it from mirror bios
Rescue bios on kx18dproll is used to restore original bios and should only be used for this purpose to fix download a bios from albatron create a flkoppy boot disc with a bios flash utility and bios on it start computer to floppy then using dip switch turn off rescue bios this will then have original bios on you can then flash it. when running rescue bios and screen displaying "bios settings changed do not power off" alow power to go off if it does the board will be dead
Posted on Jan 01, 2009
  • imakedust Jan 01, 2009
    if you really search the forums you will probably find a easier solution than the one i have suggested and you probably should not use winflash ok
TRY TO RE SET THE CMOS BATTERY
Posted on Dec 18, 2007
Albatron motherboard px865pe pro. while trying over clock the cpu the system did not reboot after changing the settings in bios. i proceded to reset the bios to defaults by using the cmos clear...
Start the computer.
Enter BIOS SETUP.
Choose Load Default Settings.
Choose Save & Exit.
Check that the fans are working, and that the computer is not over-heating.
Sep 26, 2010 | Albatron PX865PE Pro Motherboard
Hello When trying to turn on my pc I hear a mesage from the voice genie, saying that there is a problem (your CPU might have a problem, I think). I have amd sempron 2500+ socket a albatron kx18d...
Have you tried removing the Cmos Battery? if not remove it and leave it outside for few minutes (5 mins) and reinstall it (do this while the Machine is off). Boot the system again. It's also important to re-seat all the components like, front panel connectors, usb connectors, audio connectors, hard disk, cd/dvd rom, processor, Ram, fan, power connector, etc... and clean whatever you can and then reconnect or reinstall them. If there's no actual cpu failure or motherboard faulty, your problem will be fixed.
I wonder where's that Genie voice came from :-)
Good luck.
Thanks for using FixYa.
Aug 18, 2010 | Albatron K8T800 (K8X800 PRO LL)...
I have been searching the world for an Albatron KM18G Pro Motherboard to replace one that has fried. Do I need the motherboard to be exactly the same?
No you don't. Find out what CPU you have and what socket is on the motherboard (it will be printed on the CPU socket).
Then look at the memory to see what speed it is.
Now look for a motherboard that supports both that CPU socket and that memory type/speed.
Everything else just goes along for the ride. (Video card, though--do you need on-board video or do you need a socket to support the external card--check that, also)
Nov 23, 2009 | Albatron Nforce2 (KX18D PRO II)...
No video and no posting
Your GA-7N400 PRO2 motherboard does not have a built-in video graphics card. You need to install an AGP 8x graphics card into the AGP slot on the motherboard. When you removed the heat-sink & fan assembly the CPU starts to over heat & the CPU will shut down the system. That's why you heard the, european ambulance sound.
If it wouldn’t, you would fry the CPU. Make sure you add thermal grease on to the CPU before re-assembling the heat-sink & fan. Don't forget to plug the CPU fan power connector on to the board.
Motherboard specs;
http://www0.dealtime.com/xPF-Gigabyte-GA-7N400-Pro2
Download & read your manual. Open the link provided here;
http://www.gigabyte.com.tw/Support/Motherboard/Manual_Model.aspx?ProductID=1756
Mike
Aug 12, 2009 | Albatron PX865PE Pro Motherboard
Cannot boot up
maybe you must reset the bios in the motherboard. try to open your system then look for a 3 pin in the motherboard near in the CMOS battery.. it has a number 1,2 and 3 it is called jumper settings.... try to put the pin in number 2 and 3 then w8 after 10 seconds then gput it back to 1 and 2 in try to boot up.. ^^ i wish this could be help.. ^^
Feb 06, 2009 | Albatron Nforce2 (KX18D PRO II)...
Where Can I get Ethernet Controller
hey buddy go to ur computer's properties then u will able to know that which co.'s mmotherboard is installed on ur computer..
if it is intel then goto INTEL.COM then in search box write ur motherboard no. then u can download ur drivers for ur motherboard..
reply if u get my point..
Jun 13, 2008 | Albatron Nforce2 (KX18D PRO II)...
HELP! Albatron K8SLi motherboard not starting!
Hi, you have tried all the standard test, could you give some history about this board? Maybe one of us can pick something up from that. Awaiting a furthe post, mistyman
Oct 05, 2007 | Albatron K8SLI Motherboard
Albatron Nforce2 (KX18D PRO II) Motherboard Logo
529 people viewed this question
Top Albatron Computers & Internet Experts
Iqbal Husain
Iqbal Husain
Mark Gough
Are you an Albatron Computer and Internet Expert? Answer questions, earn points and help others
