Question about JVC AV-48WP30 48" Rear Projection Television
Split color red blue - JVC AV-48WP30 48" Rear Projection Television
  • JVC Master
  • 8,617 Answers
THE JVC AV48WP30 convergence repair kit from www.tvrepairworld.com usually will fix that issue. The kit contains the parts and the CD with detailed instructions.
Posted on Sep 30, 2009
I have a 3 ton Bryant split unit I'M trying to rewire.
what colors are landed where on the tstat? and does the tstat wire that goes BOTH inside and outside have the same colors. also why are you in this situation, has everything been unhooked?
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Feb 09, 2018 | Heating & Cooling
Hi.i can't split the screen on the ps3 when playing mine craft.to add a second player.my settings must be wrong somewhere?
To split the screen for a player 2 in Minecraft for the ps3 version, you must use a cable with the colors red, blue, and green, OR an HDMI cable to connect to your TV. If you are using another type of cable, you are out of luck.
Jan 02, 2015 | Video Game Consoles & Games
Beamerproblem! I've got a red-color problem with
Take it to GameStop. They can find the problem lickety-split!
May 17, 2013 | Office Equipment & Supplies
Red color seperating
If you mean the red light is displaying offset from the blue and green then the red LCD panel inside the projector needs to be physically adjusted. If you take the projector apart you'll notice that the light source is split into red, green and blue light by passing through an optical splitter. Each color then passes through it's own LCD panel. Next, each color is joined back together by another light splitter to be projected to your screen. The red LCD panel is misaligned.
Jun 03, 2012 | NEC MultiSync MT1050 Multimedia Projector
How do i wire red white and yellow rca to an xbox 1 av plug. my av plug has blaack white orange and green wires
In the old school standard AV: Red and White are usually audio channels (Red:Right - White:Left), Yellow is video.
Orange can be coax audio, (both L&R channels in one cable). Before digital (optical) came out, some receivers actually had a coax (orange) jack in the back. Radio Shack sells a splitter if necessary.
In higher resolution systems video is separated into three colored cables: RGB or Red, Green, Blue
called 'component' video. The green cable carries Yellow, the blue cable carries (PB) Blue and the red cable carries Red (PR). And with today's tech, the component signal is carried YCBCR as (digital video.) cf. http://en.wikipedia.org/wiki/YPbPr
Component 'wire colors' are there just to remind us. If your TV has "Component" input. Try green to green, white to yellow and black to red. Orange to audio (splitting L&R if necessary)..
Also, here is a PS3 link that might help: http://www.ps3hax.net/showthread.php?t=9238
Good luck !
Apr 23, 2011 | Video Game Consoles & Games
Color is splitting, and almost looks 3D.
the ITC222A convergence option missing repair kit at the following link should repair that issue. The kit contains the parts and the instructions on CD
http://www.tvrepairworld.com/
Jul 19, 2009 | RCA R52WM24 52" HDTV Projection Television
Distorted picture on RCA LCD TV
it can be replaced with a t0220 stile case dioded 220k ohm go to nte look up and do a search on the rca part #moz-screenshot.jpg 259638 search the web for the part.
Jun 29, 2008 | RCA R52WM24 52" HDTV Projection Television
Split screen
It appears that it has something to do with Progressive Scan been turned on. Progressive Scan is a feature built in your dvd player, wich by using it, it would give you a better picture//resolution on your tv, you need to use Component or HDMI cables to hook up the dvd to your tv if you want this settings, but if you are using composite RCA cables (Red,White & Yellow) and the Progressive funtion is turned on by accident, it may give you a split screen, black & white, or no picture problems. Also if you are using Component (Blue, Green & Red) cables, if one of them is unplug, the picture can be out of colors, or no picture. Check this things, if not, write back with more details about your set up.
Jun 23, 2008 | Panasonic DVD-RP56 DVD Player
Colors splitting.
max, go into "video menu" and find "convergence set-up", follow the on screen directions. Basically you want to move the "red" onto the green and then the "blue" onto the other two and the cross will turn white, once it turns white it is re-converged and your done, note: If any of the red or blue adjustments do not function then the set needs convergence circuit repaired, questions? e-mail me back, otherwise Happy New Year, BMW Rider
Dec 30, 2007 | Sony KP-51HW40 51" Rear Projection...
JVC AV-48WP30 48" Rear Projection Television Logo
135 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
