Question about Sony PlayStation Portable (PSP) Console
PSP Problem - Help Please
Hi There
Ever since my partner ran the last update on his PSP he has been unable to use text entry - i.e cannot set up broadband link or enter name on profile set up in game etc etc - He also says he has lost his joypad off the stick ? - Whatever this means?
Any help or advice would be greatly appreciated...
Joanne
joanne.marsden-hall@parcelforce.co.uk
  • fatalzen Dec 19, 2007
    same problem here... cannot access text menu. i tried flashing several times to no avail... pls. help.
  • kookieee May 11, 2010
    my psp analog stick keeps on getting stuck and i just cant move it. It stays stuck in one direction and stays there. i heard people say that you can take it off but i dont know how. ppppppppllllllllleeeeaaaaaaasssssssseeeeeee hhhhhhhhheeeeeeelllllllppppp!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Thanks Frank! I will try replacing the power PCB and back ribbon.
Have A Happy Holiday!
Posted on Dec 21, 2007
  • 79 Answers
There's nothing to do with the firmware, I am 99% sure you have a hardware failure with your L trigger or R trigger, try to go to the nickname section, give the L and R couple of taps, and see if you can enter any text, note, if you can enter something within a short time, that means you got hardware failure with your L or R, if you psp is still under warranty, go for a replacement.
Btw, this link come with my answer to another similar problem, enter a game, while it's running, press home button, and see if you can move the cursor between "yes" and "no" , if you cannot, press the R trigger or L for couple of times, and see if the coursor starts to blinking within a short time, if it blinks, I am sure you have hardware problems with L or R.
Posted on Dec 20, 2007
Hi, I have bought PSP 2000 with firmware version 5.03. The shopkeeper hacked it for me and installed chickhen software on the memory card. I ran it several times but now I am facing a problem. When I...
If you can't load only the NEW games that require higher Firmware versions, then you need to update Prometheus. Unfortunately, I can't help you with that here. Just google it.
Mar 21, 2011 | Sony PlayStation Portable (PSP) Slim...
When i try to get on the Internet, it won't let me because my text entry won't show up.
before you can go up to text entry,
you have to make sure your psp is not on hold position
also you have to push the triangle button and select the file option then select address entry.
if it works in any other pattern or refuses to work, you can try to format it and see if that helps. maybe the memory is too full and as a result it cannot process the commands properly.
you can also try removing the memory stick and see if that helps.
lastly, if all these refuses, the only option is to upgrade your psp firmware from under the settings option and that should solve it.
hope this helped you? please rate
Dec 23, 2010 | Sony PlayStation Portable Slim Black...
How to use internet on psp
Fully charge your PSP. Using WiFi requires a lot of battery power.
Verify that you have access to a router or HotSpot. If your router is password protected, then be sure you know what the password is. Be aware that some public WiFi access point are incompatible with the PSP.
Update your PSP's firmware to the most current version. Newer versions of the firmware have better Internet features than older versions.
Turn on the WiFi switch on your PSP. On older PSP models this switch is located on the left side of the device. On newer models, it is located on the top of the device.
Select the Internet icon from the PSP's main menu.
TO START BROWSING
Look at the screen once the browser loads. By default it will load the Sony webpage. You can set your own homepage later.
Use the analog stick to control the mouse cursor. The "X" button is equivalent to clicking the mouse.
Use the circle button to reject a choice or to disconnect from the Internet.
Press the triangle button to bring up the address bar at the top of the screen and the options bar at the bottom of the screen. Selecting the address bar, or any place on a webpage that requires text entry will automatically bring up the virtual keyboard screen from which text may be entered.
Choose the icons along the options bar at the bottom of the screen to change settings, set a new homepage or access other browser features such as browsing history, bookmarks or help. Tool tips will help you identify the features you are looking for.
Press ENTER to look up in Wiktionary or CTRL+ENTER to look up in Wikipedia
Sep 30, 2010 | Sony PSP-3000 Silver Console
Unable to update my protection after uploading new 2009 Micro Trend Internet Security package using a 64-bit operating system. Error message advises to check my proxy settings. I've done that. System is...
this is the resolution i got from trend micro regarding this error. it worked for me, so i thought i should share: I have reviewed your case and I understand that you are getting an error message that says “Unable To Update Your Protection” when updating the Trend Micro Consumer Product. With regard to your concern, this problem happens if there’s a missing component in your computer’s Registry. Let us configure the registry of your computer using the Registry Editor of Windows. Refer to the following. 1. Click on the Start button or the Windows Orb Button. 2. Windows XP: Click on Run then type regedit on the text field then click on the OK button. Windows Vista: Type regedit on the Start Search above the Windows Orb button then press Enter key on your keyboard. And the Registry Editor window will appear. 3. Click on the plus sign (+) or the arrow sign (>) besides HKEY_LOCAL_MACHINE. 4. Click on the plus sign (+) or the arrow sign (>) besides SOFTWARE. 5. Click on the plus sign (+) or the arrow sign (>) besides Microsoft. 6. Click on the plus sign (+) or the arrow sign (>) besides Windows. 7. Click on the plus sign (+) or the arrow sign (>) besides CurrentVersion. 8. Click on the plus sign (+) or the arrow sign (>) besides Explorer. 9. Click on the Shell Folders. 10. Look for the Common Appdata entry on the right panel. If there’s a Common Appdata entry on the list: - Double click on the Common Appdata entry and the Edit String window will appear. - Windows XP: Type C:\Documents and Settings\All Users\Application Data on the text field under Value Data. Windows Vista: Type c:\ProgramData on the text field under Value Data. - Click on the OK button. If there’s no Common Appdata entry on the list: - Right click on an empty space and options will appear. - Click on New and options will appear. - Click on the String Value option. - Set the name to Common Appdata. - Double click on the Common Appdata entry and the Edit String window will appear. - Windows XP: Type C:\Documents and Settings\All Users\Application Data on the text field under Value Data. Windows Vista: Type c:\ProgramData on the text field under Value Data. - Click on the OK button. 11. Close the Registry Editor window. 12. Restart the computer for the changes to take effect. After doing the suggested solutions, you should now be able to update the program successfully.
Jan 22, 2009 | Computers & Internet
Acessing internet from my psp
Your PSP will detect any wireless wireless network within its range as long as the wireless adapter is switched on. The switch for this is on the left end of the PSP, near the analogue thumbstick. If the switch is in the down position, the wireless network adapter is off; push the switch into the up position and it'll turn it on. If you're not going to be using wireless networking it's a good idea to keep it turned off as it'll make your batteries last longer.
When you turn on your PSP's wireless adapter it'll look for any wireless networks nearby. If there's another PSP within range it'll automatically set up what's called an 'ad-hoc' network between the two. This will enable you to play multiplayer games between the two PSPs with one hosting the game and the other joining it. When you want to join an existing wireless network, such as when you want to browse the internet, you'll be using an 'infrastructure' wireless networking mode.
Pick New Connection and press X. You can give the new Connection a name by pressing X and using the text-entry screen. Give it a descriptive name like 'Home Network' or 'University Network' so you know when and where you can use it. When you've entered the name for your new Connection you'll be asked whether you want to scan for WLAN settings or to enter them manually; select the Scan option and press right on the directional-pad. Your PSP will then scan the area for any available networks and collect the settings needed
A list of available networks (called Access Points) will be displayed, giving its name (called an SSID), whether it's encrypted or not and the signal strength. If there is more than one network, use the D-pad to scroll down to the one you want to join and press X. You'll be asked to confirm the settings so press right on the D-pad to scroll through each. When you get to the security settings, choose the appropriate setting from the list, which is WEP in most cases, and press right on the D-pad again. If you need to enter the WEP key, speak to whoever runs the wireless network and they'll provide it for you. Press X and enter the WEP using the text-entry screen.
Once you've done that you can check the settings you've entered on the final screen and save them. Now you'll be able to connect to the wireless network. If you return to the main home screen you can now update your PSP's software by going to Settings and selecting Network Update. Alternatively you can go to the Network section on the far right of the home screen to browse the internet using the PSP's in-built internet browser. Or you can fire up that multi-player game you've been itching to try out and get going!
Aug 12, 2008 | Sony PlayStation Portable (PSP) Console
Internet
Aug 11, 2008 | Sony PlayStation Portable (PSP) Console
PSP slim silver
Aug 10, 2008 | Sony PlayStation Portable (PSP) Console
PSP wont play games
To play game on your memory stick you'll need Custom Firmware installed such as M33/OE on your PSP, else if you play a UMD. The last CFw Update is 3.71M33-3.
What is version on your PSP? (on PSP Menu, move across to the "Settings Menu". Scroll down, select to "System Settings" > "System Information" and you should see version of your PSP.)
Here's, how to install CFw Guides. Hope this be of some help/idea. Pls post back a detail should you need additional information. ^_^
Nov 20, 2007 | Sony PlayStation Portable (PSP) Console
Sony PlayStation Portable (PSP) Console Logo
99 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
