Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
My rca projection tv 52inch. attempts to come on but it fails. Seems to be the power supply fuse is out but how can we check it without the costly expense?
  • RCA Master
  • 8,457 Answers
It not the fuse,all the time it the capacitors are burn.Check for puff up capacitors.Take the back cover off check,check near right the deflection circuit.
Posted on Sep 28, 2009
RCA rear projection hd tv 52inch comes on sometimes other time green light goes on then off and then flashes and tv does not come on
Your power supply board is dead, u know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Hope this will help in solving the product.....
Jun 22, 2011 | RCA HD52W56 52" Rear Projection HDTV
52inch rca rear projection power button turns green but tv will not turn on will replacing the capacitors repair this problem
Often it will, But the Flyback transformer is also famous for failing in that Model which can cause the same symptom. Caps should alwasy be tried first with that model.
Oct 26, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA 52inch DLP TV - D52W17B Lights up, but the...
Your model uses CRTs instead of a bulb. Its usually the deflection board which causes that. Thats about 180.00 for a replacement board.
May 20, 2010 | Televison & Video
RCA 52inch HDTV (2004 model) green power light flashes 3 times
Replace the flyback 259296 and the cp150 You can get the aprts with detailed instruction on how to do the repair at the following link.
http://servicemanuals.vstore.ca/
Jun 23, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCa P52926 52inch
CHECK THE SIMPLE THINGS --MAKE SURE THE PLUG IS STILL PLUGGED IN AC...IF YOU HAD SOME POWER INTERUPTIONS ...MAY HAVE BLOWN THE MAIN FUSE BY THE POWER CORD.DO YOU SEE ANY LED LITES ON THE FRONT OF TV..POWER INDICATOR??? .REMEMBER ,ALWWAY S UNPLUG THE TV IF YOU TAKE THE BACK OFF...TUNICA
Sep 04, 2008 | RCA P52926 52" Rear Projection Television
RCA 52inch will not remain on...
Just after your cord goes into your tv there is a box that regulates the power supply the tv acctually gets (helps with surges and the like) it maybe that this part is faulty and needas replacing. Have had this problem befor and it turned out that was it. Very expencive to fix though.
Jul 14, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
52inch RCA model#D52W20 tv
the d52w20 rca chasis itc222 can be difficult to troubleshoot sometimes. there a few things you can assume at this stage. ONe it is NOT the fuse. The processor in this set is seeing a voltage or saftey shutdown issue. and is shuting the set down for saftey. THis is where the troubleshooting begins. High voltage or overcurrent conditions are generely the problem. \technicians have speceil computer diagnostic equipment that can read error codes in the processor. much like in a car. but without it yo0u pretty much have to check things like horizontal ouput transitor.
Mar 15, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Power on/off
I had the same problem with an older model, try changing the batteries in the remote.
Dec 31, 2007 | RCA D52W19 52" Rear Projection Television
No power on RCA p60921
Replace the Power Supply switching transistor, If a CTC195 chassis it is the Q14101. Cost about $8.00 for part if you can do it.
Aug 04, 2007 | RCA P60921 60" Rear Projection Television
P61940 RCA TV does not turn on.
Get a schematic and trouble shoot the main power supply if you have solid state experience. If you dont , PLEASE call a trained TV tech to assist you in this repair.
Sep 04, 2006 | RCA P61940 61" Rear Projection Television
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
188 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
