Question about Mitsubishi HC1600 Projector
I have a faint rolling line moving from the bottom of the screen to the top. It's very noticable with dark screens. I have a new bulb in and have checked to make sure it wasn't the cable box. Any ideas?
    Problem Solver:
  • 7 Answers
Typically this problem is caused by line noise or interference, such as an appliance such as a fan, AC unit, or other motorized device on the same electrical circuit or electrical ground that your projector is connected to.
In a worse case scenario,like what happened to me, is that it may be that your neighbor has some device like an air conditioning unit that is poorly grounded and it sends a rolling line through the round and through to the cable tv's coax cable and back to the junction box. If this is the case, your neighbors probably have similar problems. For this type of problem, you can report it to the cable company for line quality problems, they can send a tech out and try to isolate the problem and where it is originating from. In my case, the third cable tech that came out traced it to a grounding problem on my neighbors house, but the cable company can't fix the problem unless the home owner grants them access to their property to investigate further.
Posted on Sep 28, 2009
Diagonal lines at 45 degree angle from left top to right bottom of screen
db:: 4.31::Diagonal lines on tm2 screen? fz - Hivmr
www.hivmr.com/db/fzap9jk8dp87mcjk3cc9jsp7fzxk7pz1
There are faint 45 degree diagonal lines covering my brand new tm2 LCD ... with some static looking diagonal lines going from bottom left to top right. .... DB:3.01:Dv6113 Us - Computer Freezes Showing Diagonal Lines On Screen aj ... Also there arediagonal lines that run across the screen at about a 30 degree angle.
3M Privacy Filter for Laptop diagonal-14.1" viewing screen ...
www.amazon.com/3M...diagonal-14.../B00006B8A9
Amazon.com, Inc.
Rating: 3.8 - ‎1,617 reviews
Amazon.com: 3M Privacy Filter for Laptop diagonal-14.1" viewing screen ... Premium 14.0 Inch Privacy Screen for Widescreen Laptop or Computer Monitor .... 3M™ Privacy Filters create a 30-degree cone of vision so on-screen data is .... You'll also notice a large "3M PF14.1W" printed in the top right hand corner of the filter.
FZ190: Faint Diagonal lines on screen? ' NotebookReview
forum.notebookreview.com > ... > VAIO / Sony
Jan 27, 2016 | Computers & Internet
LG LCD TV - Buzzing Sound and Faint Horizontal Lines
From your description, the sound you are hearing is the inverter(s) that drive the back light for the LCD screen/module.
The inverters mounted on the back side (one lower right and one left side) of the LCD screen/module. They are under the sheet metal cover/shields.
The inverters are going out and or the LCD screen/module is going bad too.
That LG TV has only a 1 year on parts and labor from the date of purchase, but you could call LG and ask for their help for such a new TV. They might do it under a warranty, for little or no cost to you.
I hope this information has helped you.
Good Luck.
May 23, 2010 | LG 47LG70 42 in. LCD TV
Dark picture on RCA Scenium 61 in DLP
Yes, the lamp will gradually get darker as it nears it's end. The rolling lines sounds more like the set is on a local channel for the cable hook up. If your local area has a channel 3 or 4 live terestrial broadcast simply tune the cable box output to the other one, the same for the tv.
If this is cable/local broadcast issue it will go away in Febuary when the NTSC broadcast ends.
Jan 15, 2009 | RCA Scenium HDLP61W151 61 in. HD-Ready...
Red & Green lines rolling from the bottom to the top
You could have a ground loop problem. To test plug DVR and TV into same outlet.
Dec 27, 2008 | Televison & Video
Mitsubishi DLP WD 52525 has small green lines on the screen
do the lines go from top to bottom, and are they about 1 inch apart? or do they move diagonally across the screen?
Dec 27, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Faint horizontal lines from top to bottom after an hour of use...
I can tell you right off the bat that is a service issue you will have to take up with sharp. Contact their operational support, they have a quick turnaround with things like that. When you call, they will most likely ask you to take digital pictures of these black lines and have you e-mail the pics to them.
Dec 08, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Shadows and Ghosts on the Screen
Plugged up display via the VGA cable to an HP dv6000 laptop; the Acer powered up and displayed fine ... however, noticed a faint waving motion in the picture, as if the screen was literally gel and began to wave, from top to bottom as it appeared. Best I can describe it ... any suggestions as to why? I only connected it to this HP to try it out, I ordered it from newegg and wanted to make sure pixels werent dead on arival. I will be getting an Aurora 7500 (Alienware): AMD X2 6000, Windows Vista Premium, 2GB RAM, GeForce 512 8800GT, SLI ready motherboard ... I heard good things of Acer and hoped this display would look great with my soon-to-come setup and im sure it will. However, just nervous it will do this on my Aurora. Any help or suggestions would be beyond appreciated!!
Feb 19, 2008 | Samsung SyncMaster 191T 19" Flat Panel LCD...
Faint blue vertical bars on screen
What you see on your screen are retrace lines, it can happen for various reasons. Jut lower the screen voltage by adjusting the knob specified as "screen" on the LOT, this will disappear.
Jan 27, 2008 | Sharp 32R-S50 32" TV
Bright light on bottom of screen
sounds like your light engine. Very easy to replace.
Jan 14, 2008 | Toshiba 62HM95 62" HDTV
Mitsubishi HC1600 Projector Logo
106 people viewed this question
Top Mitsubishi Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Mitsubishi Office Equipment and Supply Expert? Answer questions, earn points and help others
