I just bought a new car and the speakers were really fuzzy and popped and all the symptoms of blown speakers when i turned the volume high. The speakers weren't stock speakers. The owners had them replaced with 220W kenwoods and replaced the stereo with a panasonic. So i got new speakers, kenwood 500W, and a new kenwood stereo. It sounds exactly the same when i turn it up. Still fuzzy and pops. Any advice?
If it is an older vehicle you could have interference from the ignition system. You can wire the radio to be powered up from a toggle switch that get its power straight from the battery, with a fuse between the battery and switch of course. This will eliminate powering up the radio with the ignition switch and take the ignition system out of it. Also need to make sure the ground wire is grounded good and the ground wire is the same wire guage if not larger than the power wire.
I purchased a used vrvd630 everything work fine. I installed it everything but the DVD works. It...
(More)
I purchased a used vrvd630 everything work fine. I installed it everything but the DVD works. It says Wrong Region on all my DVD s. Are there any codes. Thanks Ray
I have a 1994 dodge grand caravan se the head lights quit working but everything else seems to be...
(More)
I have a 1994 dodge grand caravan se the head lights quit working but everything else seems to be working high beams are also working. I didn't start having problems until someone installed after market radio and cut the wires.
screen froze while playing the radio, and then a line appeared on the screen.. turned off the car,...
(More)
SCREEN FROZE WHILE PLAYING THE RADIO, AND THEN A LINE APPEARED ON THE SCREEN.. TURNED OFF THE CAR, AND SCREEN WILL NOT COME OUT NOR WILL IT TURN ON AT ALL. THE RED SECURITY LIGHT STILL BLINKS, BUT NO SOUND
