Toshiba 36A50 36" TV
Problem for Toshiba 36A50 36" TV
Only thin white line across my toshiba tv
By mmason002 on Sep 28, 2009
Has sound. No picture. Gradually started losing the screen...it got smaller from the top and bottom until it eventually was a thin horizontal line in the middle of the screen. Then no picture at all, only sound.
Best Solution
posted on Sep 28, 2009
Very Helpful)
johnnydiode
Rank: Guru  Toshiba Televisions & Videos  Expert
Rating: 94%, 196 votes
This is an easy repair if you've ever soldered and would not be too costly for a repair shop to do it for you. The problem is a bad Vertical Output IC (usually mounted on an aluminum heat sink with the part on it labeled LA78?? ) and 1 or 2 bad capacitors. Some times you can even fix the problem by re-soldering the contacts of the IC- To find the IC follow the 4 wires that come from the Yoke (which is a contained coil of wires slipped over the neck of the picture tube(s)) back to the board. 2 of the wires go to the horizontal o/p and 2 to the Vertical o/p the thinner gauge wires are for the vertical.
Was this helpful?
Yes
No
2 people thought this was helpful
Popular Solutions for Toshiba 36A50 36" TV
Questions and Unsolved Problems for Toshiba 36A50 36" TV
Do you recommend Toshiba 36A50 36" TV?
Answer
Answer
not able to use volume, stays on screen all the time. it is toshiba set
Answer
Codes to make my Time warner remote control my Visio 32" HDTV
Answer
The screen black the played out,and didn't come on anymore, cam this be fixed?
Answer
Toshiba 36' tv wont power on how do I fix this?
Answer
need the remote code for a JVC model AV 36200 tv. And the remote control is a Time Warner cable... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Toshiba 36A50 36" TV:
Top Standard Television Experts
Rank: Guru Guru
Solutions: 727
Experience: 30 Years of professional repair and design.
Ask Me
Find more Standard Television Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
