Question about GE Profile 36" Electric Induction Cooktop - Black
Why does hot surface light remain on...anything I can do?
  • 42 Answers
No it is part of the warning system that it has been used,the same as a halogen hob.
Posted on Sep 28, 2009
Tip
Proper Use and Care of Ceramic Glass Cooktops
Here's some helpful tips that can hopefully ensure many years of quality use of your ceramic glass cook-top.
NOTE: It is important to maintain PROPER care of your ceramic glass cook top as they can be very expensive to replace. Prices vary between models, but most are in the $200 to $300 range. With added labor charges, this repair can cost over $600 from an appliance repair company.
WARRANTIES: Most manufacturer warranties DO NOT cover cosmetics. That is, if your cook-top paint starts to wear off from normal use, or from the selection of cookware you choose to use, manufacturers typically WILL NOT replace it. Warranties also DO NOT cover accidents such as dropping something on the top and chipping or breaking it. Some warranties WILL cover, however, blistering, warping and heat related breakage that were no fault of the consumer (as long as you were using the recommended cookware). It is important to become familiar with, and follow, all the manufacturer's use and care instructions that come with your range.
CERAMIC GLASS CHARACTERISTICS:
It is normal for the ceramic glass to change color when heated. This is especially true for lighter colored surfaces. The color should return to normal when cooled. It is also normal for the enameled or painted areas on the cook top to show signs of wear and fade over time. Proper cleaning and cookware selection can extend the cook top appearance.
It is NORMAL for the radiant heat surface elements to glow red and cycle on and off. There is a thermostat associated with each individual element that regulates the temperature. The frequency at which the elements cycle on and off is determined by the heat setting.
PROPER COOKWARE:
Use ONLY flat bottomed cookware for the best results of heat transfer from the surface elements. Cookware with warped, rounded or ribbed bottoms can cause uneven heat transfer which can result in uneven heating of the cooking surface and cause damage to the cook-top such as cracking and/or permanent surface discoloration.
An easy test you can use to determine the flatness of your cookware, is to turn the cookware upside down and place a ruler across the surface. As you rotate the ruler around the surface perimeter, you should not see any light along the ruler edge where it meets the surface. Cookware with slight indentions or expansion grooves can still be used, however.
Make sure the cookware bottom is always clean and dry before use to prevent any foreign matter from burning to the cook-top surface and leaving stains. ALWAYS place your cookware on the cook-top surface BEFORE turning the surface elements on.
Make sure the selected cookware matches the size surface element in use. The cookware surface should NOT exceed one inch beyond the radiant surface element surface.
COOKWARE CHARACTERISTICS:
The material of the cookware you select will determine how well it transfers heat and how evenly it cooks. The ideal cookware should be of medium to heavy thickness.
NOTE: A non-stick surface will take on the characteristics on the base metal used. (i.e., non-stick over aluminum, will take on the heating characteristics of aluminum).
*ALUMINUM - Heats quickly and evenly, light weight, suitable for all types of cooking tasks.
*COPPER - Heats quickly and evenly, light weight, suitable for all types of cooking tasks.
*Both aluminum and copper are great when used as a core metal cover with a non-stick or enamel surface. However, when used as a base metal, alone, they can leave metal transfer marks on the cook-top surface which will have to be cleaned immediately following use.
GLASS or CERAMIC - Heats slowly and unevenly, may scratch cook-top surface if there are any rough edges, best results are when using low or medium heat settings.
CAST IRON - Heats slowly and evenly, maintains heat for slow cooking, great for browning and frying, rough on cook-top surfaces, may scratch.
STAINLESS STEEL - Heats quickly and unevenly, a base or core of aluminum or copper can provide more even heating.
DO's and DON''T's:
DO NOT store heavy items, such as jars, cans, pots and pans above the cook-top surface. Any inadvertent dropping on the cook-top surface and cause cracks or shattering.
DO NOT lay hot lids on the cook-top surface. Heated air can become trapped under the lid creating a hot spot as the rest of the cook-top surface cools. The cook-top surface could potentially crack when the lid is removed.
DO NOT slide cookware across the cook-top surface. LIFT cookware as much as possible when moving from surface to surface. This will minimize metal transfer marks and scratching.
DO NOT cook popcorn in prepackaged aluminum containers. The aluminum could potentially melt and may not be able to be removed from the cook-top surface.
DO NOT store anything on the cook-top surface that could melt (such as plastic and aluminum foil). Once melted to the surface, some of these substances may not be able to be removed.
DO NOT store empty pots and pans on the cook-top surface.
DO NOT attempt to use the cook-top surface while the oven is on a self-cleaning cycle. The oven super heats to temperatures in excess of 500 degrees and causes radiant heat to be exhausted from the oven vent on the stove surface.
DO NOT use a cook-top that is cracked. Any spill overs could potentially leak into the radiant heat elements and create an electrical hazard.
DO clean up any spills from the cook-top surface that contains milk or sugar. You may allow the cook-top surface to cool in order to safely clean, but do not allow these substances to remain on the cook-top for extended periods. If not removed, these substances can cause permanent discoloration and stains.
DO wipe down the cook-top prior to, and immediately following use, to maintain the surface appearance.
DO NOT attempt to cook any foods directly on the cook-top surface without a pan!
CLEANING and CARE:
Clean all spills and boil overs immediately.
Any substances that become adhered to cook-top surface can be removed by wiping up excess with hot soapy water and a kitchen sponge.
Use a non-abrasive pad (the green kitchen pads are considered non-abrasive) and a straight edge razor blade, pushing in one direction to remove stubborn particles.
Some metal transfer marks (copper and aluminum) may be removed by simply wiping cook-top surface with a damp sponge. Any remaining marks can often be removed with an approved cook-top cleaner.
Use only approved, non-abrasive cook top cleaner to keep the surface clean and polished.
DO NOT use scouring pads that will dull or damage cook top surface (i.e., steel wool or SOS pads).
DO NOT use any harsh chemicals such as ammonia or bleach that can etch or dull cook-top surface.
on Apr 19, 2011 | Cooktops
My left front burner was turned off for almost half hour but remained hot. the hot surface light was still lit. I had to throw my main breaker to turn it off. What could be my problem
Sounds like the thermostat on that burner gas gone. When you switched the breaker back on, did the burner get warm after being cold? If so, you need a new controller. They are easy to change if you can get to the back of the unit. Make sure you turn off the breaker and physically remove the plug.
Nov 24, 2013 | Whirlpool RCC3024 Electric Cooktop
The surface light on my mothers stove stays on and all burners are off and cold any ideas why
Here is a tip that I wrote about why the hot surface indicator light will not go out...
Oven Hot Surface Indicator Light stays on
heatman101
Jan 18, 2011 | Maytag Cooktops
Whirpool cook top surface light countiune on even surface are cold
How long does it take for the light to finally go off?or does the light ever go off when a cooktop decrease in tempreture has to reach the tempreture set by the factory for that light to go off. Sounds like a thermal switch which controls the hot surface light is stuck closed If this is a new unit, I'd return it. If not, I would check the switche(s) for the hot surface light -- when the unit is cold, unplug one wire going to the thermal switch and check it for electrical continuity. If you get current from a multi-meter through the switch, replace it -- it's not opening when it cools down.If you have any further questions please message me back and please remember to rank how this opinion has helped in your appliance situation Thanks again
Rick
Dec 12, 2010 | Whirlpool RCC3024 Electric Cooktop
Switch remains red after unit is turned off
The reason why the switch is still red after it is turned off is to let you know the surface is still hot. When the surface cools down it will go off. It is a safety feature that is built in to the top.
Good Luck and please rate 4 thumbs for the free answer.
Mar 11, 2010 | Jenn-Air JED8430 Electric Cooktop
Just installed an electric cooktop and the Hot Surface indicator light has been on since installation. How do we fix this?
Sounds like a thermal switch which controls the hot surface light is stuck closed.
Charlie
Aug 20, 2009 | Whirlpool Cooktops
Hot Surface Indicator Light has not turned off since last night.
if the hs ind light does not turn off then that particular heating elemnt needs to be replaced.heat sensor is built in the elemnt.when elemnt is turned off and it cools down it makes a switch to open and inturn ind light turns off.but sometimes thst gets stuck and light remains on.but do not worry abt element,it remains off,its just that indicator light that remains on.
Jul 30, 2009 | Jenn-Air JED8430 Electric Cooktop
HOT SURFACE LIGHTS
Hold the button down 5-6 seconds and it will go off...then to cut on...press down again for 5-6 seconds and it will come back on.
Sep 06, 2008 | KitchenAid 30 in. KECC506R Electric...
GE Profile 36" Electric Induction Cooktop - Black Logo
254 people viewed this question
Top GE Cooktops Experts
Dan Webster
Dan Webster
Dave Harrison
Are you a GE Cooktop Expert? Answer questions, earn points and help others
