Question about Mitsubishi WD-62525 62" Rear Projection HDTV
White dots on rear projection
I have a 73'' mitsubishi 1080p rear projection tv white dots started appearing on screen how do i fix?
  • 1153 Answers
SOURCE: 73" rear projection Mitsubishi TV
1. Check for no 8.4 volts DC at pin 3 of PC9A10 on the Power PCB, if low or missing replace PC9A10 part # 268P058020. 2. LED does not blink at plug in. Check for 3.3-volts DC at connector RF pin 3 (system reset) if low or missing suspect the reset switch S7L20 part # 432P109010 on the Control PCB. 3. LED does not stop blinking after plug in. Verify the standby supplies, 12-volts at connector KA pin 17, 6-volts at KA pin 18 and the 28-volts at KA pin 19, if the supplies are present suspect the DM PCB part # 934C067002 4. LED does not stop blinking after plug in. Check C9B01, C9B02, C9B10, and C9B11 (1000 UFD 16) on the DM PCB, if they are bad replace them with part # 181P734030 (680 UFD 16 V). 5. LED stops blinking after 70 seconds of plug in but will not power on. This model is equipped with a keyboard lock feature; this can be mistaken as a no power condition. To unlock the keyboard press and hold the "menu" button on the front panel for 10 seconds 6. LED stops blinking after 70 seconds of plug in but will not power on. Check for 3.2 volts DC at connector RF pin 4 and 5 on the Signal PCB if low suspect problems with the switches/buttons on the Control PCB part # 935D736001 7. LED stops blinking after 70 seconds of plug in but will not power on. Keyboard is not locked and key inputs at connector RF pin 4 and 5 check good suspect the E2P PCB part # 934C061001
Posted on Sep 05, 2007
ladywinn
  • 5138 Answers
SOURCE: samsund rear projection tv
I hate to tell you this but its a good chance its your light engine,if the dots begin to spread over the TV it is the Light engine.
Posted on Jun 23, 2009
welcomejee
  • 10594 Answers
SOURCE: What causes 900+ blue dots appear on my Sony rear projection tv?
Dot problem in Sony DLP TV caused by bad light engine (optical block)
Its costly part and needs qualified TV tech to fix it.
Posted on Jul 25, 2009
SOURCE: hls 5065 samsung rear projection tv
This could actually be an issue with either your DMD board or your Video board. With the TV on, select your menu, if the white dots are still there, the issue will be with the DMD board, but if they don't appear on the menu, the issue would be with the Video board.
Posted on Jul 30, 2009
  • 8457 Answers
SOURCE: My rear projection 73 in. Mitsubishi TV is
Power supply board have dead parts.Tries Websites Shopjimmy.com,Ebay.com to buy a refurbish power supply board for replacement.
Posted on Feb 22, 2010
HOW DO I FIX A VERY LOW BRIGHTNESS ON SCREEN
Yes. It appears that your lamp is nearing the end of its life. You will need to replace it. Here is the part number. I hope this helps.
Apr 25, 2016 | Mitsubishi WD-73640 73" 3D Home Cinema...
My Mitsubishi WD-73737 73 in TV has white dots taking over the screen
Bad DMD chip
call Mitsubishi, they will send one to a servicer at no cost, you will only pay for labor
Sep 19, 2014 | Mitsubishi Televison & Video
I have small whitr dots on my picture screen
I went through the same problem with mine started out as one ended with many Its the optical lamp board cost is $600 and some dollars for a model 73-733
Dec 06, 2011 | Mitsubishi WD-73733 73" HDTV
I have a 73" mitsubishi diamond edition tv and
this is when dmd (digital mirror device) ic begins to fail. these dots will become more numerous until they fill the screen. replacement of dmd board will solve
Sep 27, 2011 | Televison & Video
Just paid to replace the lamp 2 weeks ago in our mitsubishi 73 dlp 1080p tv purchased a 5 year in home contract with Tweeter Sevice net 1/2008 lamp fixed and picture is once again great but now the 73...
Mitsubishi that the one,who u should contact.Talk to them make some kind of deal with them to help u to do a repairing or replace the tv Light Engine Projection Block.That the tv problems,this problems a design flaw on the tv Light Projection Egine Block the IC they put in that causes of this white spots are showing up will continue showing up more and more white dots.It will not stops.
Sep 03, 2011 | Mitsubishi WD-73833 73" HDTV
Bright white spots on mitsubishi wd-73833 I just replaced the lamp and now these bright white spots have started to appear!
This unit uses a DLP (digital light processor) chip and if this starts to fail then you will get spots appearing on the screen. The DLP chip will need to be replaced.
Mar 24, 2011 | Mitsubishi WD-73833 73" HDTV
What Causes the white dots on a DLP Mitsubishi tv?
the white dots (sometimes you get black ones too) are caused by a faulty DLP chip. you can find the replacement for your TV at the following website:
http://www.shopjimmy.com/dlp-chips/
Mar 20, 2010 | Mitsubishi WD-60735 Projection Television
White dots appearing on Mitsubishi 1080p DLP tv.
Actually you must replace the DLP chip that is buried deep in the works of the tv. Unfortunately this can run into a nice lump of change. Do what I did. Perhaps you've heard the old addage
Mar 05, 2010 | Mitsubishi WD-73734 73" Television
Mitsubishi WD-62525 62" Rear Projection HDTV Logo
684 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
