Question about Lexmark Z1420 InkJet Photo Printer
I can't install my printer
When I try to install my printer I get a message that says printer processor not detected what should I do?
Hp photosmart 310c will not install on windows 7
IssueThe HP printer software installation fails to run in Windows 7 on a computer with an AMD C-50, C-60, or Z-01 1.00 GHz processor. After you insert the HP printer software installation CD or run the driver installation downloaded from the HP website, the setup does not open. You might receive an "HP Installer Setup has stopped working" error message.
'HP Installer Setup has stopped working' or Setup Does Not Run When Installing the HP Printer Software in Windows 7IssueThe HP printer software installation fails to run in Windows 7 on a computer with an AMD C-50, C-60, or Z-01 1.00 GHz processor. After you insert the HP printer software installation CD or run the driver installation downloaded from the HP website, the setup does not open. You might receive an "HP Installer Setup has stopped working" error message.note.pngNOTE:This document does not apply to HP LaserJet printers.Preliminary stepThe solution in this document resolves software installation issues only for Windows 7 computers with an AMD C-50, C-60, or Z-01 1.00 GHz processor.
  1. On the Windows taskbar, click the Windows icon (c01319360.gif ), right-click Computer , and then click Properties .
  2. In the System section under Processor , find the manufacturer, model, and speed (GHz) of the processor.
If your computer runs an AMD C-50, C-60, or Z-01 1.00 GHz processor, continue with the steps in the following solution.SolutionFollow these steps to download and install the newest, full-feature version of your HP printer software. Then, download and install a software patch to complete the installation.Step one: Download the softwarenote.pngNOTE:You must download the Full Feature software to resolve the installation issue.
Mar 24, 2013 | HP PhotoSmart Office Equipment & Supplies
Installation
uninstall the printer completely and then try installing it back
Aug 23, 2008 | Canon PIXMA MP470 All-in-One Printer
I have a canon pixma610 printer scanner. it gives an error message 'print head is incorrect "uo52"
The data connection between the processor of the printer and its printing head is flawed. This can be caused either by a bad connection (the head is badly installed in its carrier) or by a failure of the processor.
Try reseating the head - if the situation isn't fixed then the processor has failed. In that case the printer is dead, time for a new one.
Jun 09, 2011 | Computers & Internet
Motor error on lexmark printer c540
Motor error comes up when motor of the printer fails to turn or run. Here's what you can do:
Run motor detect (NOTE: You may need to run motor detect procedure two or three times to be successful.). To run motor detect, you need to go to the Diagnostic Menu.
1. Turn the printer off.
2. Press and hold Left and Select.
3. Turn the printer on.
4. Release the buttons when the installed memory and processor speed displays. Scroll down to Miscellaneous Tests. Press the select button
Motor Detect
This test initiates an automatic motor detection process that should be performed whenever the controller board
is replaced.
To run Motor Detect:
1. Remove the imaging unit and the waste toner bottle.
2. Reinstall the right cover assembly.
3. Close the front cover.
4. Enter Diagnostics menu (Turn the printer off, press and hold Left ( ) and Select ( ), turn the printer on,
and release the buttons when the installed memory and processor speed displays.
5. Select MISC TESTS in the Diag Menu, and press Select ( ).
6. Select Motor Detect, and press Select ( ).
If you press Select before closing the front cover, a message appears: Close Cover. Press Select.
Motor Detection In Progress… appears.
The motor detection process takes about 10 seconds, and stops automatically.
Detect Complete. Rebooting… appears, and the printer performs a POR (Power On Reset).
If the motor ran, the test was passed. If the motor did not run, the test failed. If problems persists, the printer might need to be serviced or exchanged depending on the warranty/entitlement.
Apr 14, 2010 | Lexmark C540N PROD SPECS TBD Printer
The printer is not working duo to installation problem
First of all go to Control Panel->Add Remove programs. There select this printer and delete it. Disconnect the printer from the PC and reboot.
Now reinstall the drivers of this printer from the CD that came with it. reboot the PC.
Connect the printer to the PC and allow Windows to detect it and load its drivers. You will get a message in the right bottom corner of the screen "The new HW has been installed and is ready for use". Now start the word processor and go to File->Print. Here select this printer as default printer. And print away.
Remember to reboot when I have said you must.
Dec 04, 2009 | Epson TM-T88III (C420863)
I have a acer laptop. i also have the printer usb cord sonnected to the computer and i inserted the disk to install the option to use the printer. but it doesn't want to install. how can i get the printer...
First disconnect the printer from the laptop. install the drivers from the CD that came with the printer. Reboot. Now connect the printer. Allow Windows to detect the printer and load its drivers and give you a message in the right bottom corner saying "The new HW is installed and ready for use". Now run the word processor and go to File->Print. Here specify this printer as your default printer. And print away.
Dec 04, 2009 | Brother MFC 210C All-In-One InkJet Printer
Printer not responding message on epson TM-T88iv
You must first uninstall the printer from the Control Panel. Reboot the PC. Then reinstall the printer with the printer NOT connected. Then connect the printer and allow Windows to detect the printer and load its drivers. When you get a message in the right bottom corner of the screen "The new HW has been installed and is ready for use" then fireup the word processor and set this printer as default printer and start printing. All the best to you.
Dec 03, 2009 | Epson TM-T88IV Thermal Printer -...
When I try to print something, it doesn't print. It seems to be connected properly.
It seems that either the drivers are not installed for this printer or the printer has not been selected in the word processor. First insert the CD that came with the printer in the drive and install the driver for this printer. reboot. and connect the printer and allow Windows to detect it and load its drivers. Now second, open the document that you want printed in a word processor and give the print command. Here you will find an option on which printer to print on. Select this printer and get the prints.
Nov 19, 2009 | Epson Stylus C62 InkJet Printer
Toner cartridge error message
try putting another cartridge even used one just to isolate the problem whether with cartridge or printer, probably a sensor not detecting the cartridge
May 26, 2009 | Epson AcuLaser CX11N All-In-One Printer
Computer cannot detect printer
ok..
remove all software from computer for printer
go to www.canon.com and get new drivers by model and operating system
re install
try it again.
Jun 11, 2008 | Canon PIXMA iP3000 InkJet Photo Printer
Lexmark Z1420 InkJet Photo Printer Logo
23 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
