Question about Toshiba 57H82 57" Rear Projection Television
My picture is distorted at the top of the screen .
In the past the picture improved as it warmed. Now it improves but to a lesser degree. What is the fix? Can it be repaired without professional assistance?
  • 157 Answers
What you need to do is seek prodessional assistance and it's actually going to be either your bulbs are going out and/or the cpu board in your television is going out and once fixed that will solve your distorted picture issue. It may even be cheaper to buy a new television.
Posted on Sep 28, 2009
Testimonial: "Thanks for the quick response. What would you suggest as a replacement at the low end on price? "
Lcd tv picture
Replace backlight lamps
Jun 03, 2017 | LG Televison & Video
2008 silverado EGR location on a 5.3 fuel injected v8
Doesn't have a EGR valve ! Has Camshaft Actuator System .
Camshaft Actuator System Description
The camshaft position (CMP) actuator system is used for a variety of engine performance enhancements. These enhancements include lower emission output through exhaust gas recirculation (EGR) control, a wider engine torque range, improved gas mileage, and improved engine idle stability. The CMP actuator system accomplishes this by controlling the amount of intake and exhaust valve overlap. For the 6.0 liter (LY6, L76) and the 6.2 liter (L92) engine, the Park position for the CMP actuator and camshaft is 8.5 degrees before top dead center (BTDC) or 17 crankshaft degrees BTDC. The engine control module (ECM) can only command the CMP actuator to retard the valve timing from the Park position or advance the valve timing back to the Park position. The total range of valve timing authority is 31 degrees camshaft rotation, or 62 degrees of crankshaft rotation. The control range is from the Park position of 8.5 degrees camshaft or 17 degrees crankshaft BTDC, to 22.5 degrees camshaft or 45 degrees crankshaft after top dead center (ATDC).
May 31, 2017 | Cars & Trucks
How can increase the resolution on a photo
Technically you can't improve the resolution. Photoshop or similiar photo editing programs can improve the picture to some degree .
Oct 11, 2014 | Apple MacBook 13"White /2.0Ghz Intel Core2...
I have a samsung lcd lnt4661fx/xaa tv and the picture is all blurry, how does this get fixed and how much will it cost me
Does it improve when the set warms up? Is it the entire screen or just the left or right side? These sets are notorious for faulty LCD panel tabs which causes blurry/delayed picture problems.
Mar 11, 2013 | Samsung Televison & Video
I have a 42" Toshiba
The main logic tv Tuner signal board it is the problems and the causes.That the board where the tv incomming broadcasting signal cable plug into it.This tv repair by a tvs shops will cost u like $500 for a refurbish tv Tuner signal board part and labors.If u have some basic mechanical skills like take things aparts and putting it back together again.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish tv Tuner signal board for the replacement by urself like $110 -120 plus shipping and handdling.
Aug 21, 2011 | Toshiba REGZA 46RV530U LCD TV
I'm trying to improve the picture- seems to be TOO DARK- tv is 10 yr old ser3 935351541- ihave tried color adj etc
Rca Screen Control These sets have screen control adjustment usually located behind the speaker grill(pops off -velcro or press tabs) and convergence front board. There are 6 contols on a black molded assembly about 31/2"x21/2" square. adjust only the top controls marked "Screen R G B" the bottom ones are focus
Method:
-turn on set and let warm up for 30 min at least
-switch tv to blank unused video input channel
-adjust each control in turn until you see the picture glow (with the corresponding color) and slightly back off the control - repeat for each color - this will increase screen brightness and ballance your color
Hope this helped.
Oct 18, 2009 | RCA P52945 52" Rear Projection Television
Periphery of screen changes tint
hit crt with open palm in distorted area.if changes broken shadow mask no repair except crt replacement. if not could be magnatized. needs degaussing
Dec 07, 2008 | GE 35GT690 35" TV
Sony DCS-T1 Vertical cloured lines on screen and distorted image after camera taken from cold to warm environment. No improvement after 4 weeks.
CCD Imager in your camera got defective and needs to be replaced.
Sony will repair it free of cost as per announced scheme for CCD Imager problem in same model cameras.
Click on Sony CCD Support to know details of free of cost repair scheme.
Dec 03, 2008 | Cameras
The positioning of my desktop's imageis still distorted despite running the easy tune display wizard and my using the auto tune keys on the side of the monitor.
Use the manual methods on your monitor (horizontal and vertical size and position), not the auto tune and see if you can get it to improve.
Try using a different desktop picture as well.
Right click on the desktop where there are no icons, and change the picture. Also, play with Stretch/Center/Tile - stretch will distort a file if it doesn't exactly match your screen settings.
Jul 17, 2008 | Gateway Computers & Internet
Toshiba 57H82 57" Rear Projection Television Logo
128 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
