If the batteries were wrong you would not get power at the joystick and you wouldn't be able to turn it on. If it is coming on and working then your problem is either a bad charger or a bad battery. If you charge the chair and the green light on the charger is on (indicting a full charge) unplug the charger and if you have a digital voltmeter put it on 200 v dc and plug the leads into the 2 outter pin holes of the charger port located under the front of the joystick you should be reading 25-27 volts after charging if less than that then either the charger didn't work or you have a bad battery or batteries. New ones sometimes can be bad. If you know of a friend or can borrow another charger try charging with it to see if it makes a difference Hope this helps
try a new battery pack or let your's charge for 12 hres
about ;its seems that the battery pack you have is low in charge;because if its works with the chargerit should works with battery;about the bad fuse if it was the problem ,the camera will not work at all,
and that is a big problem that fuse is inside the camera on the pwr board,
Your laptop does not charge the battery, the charger plug charges the battery. Could be a bad charger or battery, just because its new does not mean it works.
the battery is bad and it won't charge all the way. Try another battery and it should charge all the way. If it does then you know the battery is bad. If the battery is bad then you know the main board is bad.
sounds like your charging circuit isn't working or the adapter isn't putting out enough power or amprage to fully charge the battery, or you battery went bad. if the charging circuit is bad then so is *********** board, time to burry the system and buy a new one
If the old one works you have another power supply or wrong one. Check the properties of your power supply.
Related to your issue you also may consider this:
1.- Computer AC / DC cable is bad not allowing the computer battery to charge. 2.- Battery is bad. 3.- Battery charger board is bad.
Solutions: 1.- Computer AC / DC cable is bad not allowing the computer battery to charge
Verify that the AC and or DC cable is not bad by testing the computer only with the power plug connected and the battery out of the laptop. 2.- Battery is bad
It is possible that if the power plug is good that the computer battery is bad. Leave the computer connected to the power with the battery connected in the computer for at least one hour; if the battery does not charge, consider having the battery and/or the laptop serviced or repaired.
If the computer and/or battery is not in warranty consider just replacing the battery as it is very likely that it is just a bad battery. 3.- Battery charger board is bad
If the battery has been replaced or an alternate battery from an alternate identical laptop does not work in the computer, it is likely that the power or charger board within the laptop is bad. It is recommended that the laptop be serviced or repaired.
Please don't forget to rate my help! Thank you for using FIXYA! Have a great day! Pablo :-)
