Question about Canon PIXMA MP150 All-In-One InkJet Printer
I can't print from the computer. Only copies. It
I can't print files. Only copies. When I send the order to print, it flashes the "On" light, and the letter "E" and the number "2" also flashes in the display. I already re installed the driver, but, nothing happened. It's still blinking. It also blinks the light "Alarm"
El Duderino
  • 47 Answers
SOURCE: HELP!
Hi taximom, Is the light alternating back and forth between green and orange (GR OR GR OR GR OR GR)? Or is there a pattern like (GR OR OR OR GR OR OR OR GR) or (GR OR OR OR OR OR OR OR OR GR OR OR OR OR OR OR OR OR GR) If it the first case (alternate back and forth) then I hate to be the bearer of bad news but it needs service. (and it's probably not worth fixing) If there is a pattern to the blinking let me know exactly how many times it goes orange and I can tell you what to do from there. The Dude
Posted on Nov 17, 2006
JongCur
  • 88 Answers
SOURCE: alarm light wont stop flashing
How old is your printer? Maybe a part in your printer has reached its service life and has to be replaced. Please indicate error messages if there are any.
Posted on Apr 09, 2008
  • 33 Answers
SOURCE: Canon mp780
I would say that you have a paper jam or maybe you did have one & pulled the paper out backwards & you may have damaged the little paper switch right down the bottom of the paper slot if thats the case you will need to take it to a proper repairer
Posted on Oct 27, 2008
SOURCE: Error code 6A00, alarm light flashing, no copy, print or fax function working
I tried everything. I unplugged the machine and moved the printer cartridges to the far left and cleaned and pressed down the spring loaded sponge on the right, over and over again. I also moved the springloaded thing (w/white plastic) forward and backward. Another suggestion was to move the print cartridge holder back and forth sideways. None of these things helped. And there was nothing visibly out of place. I was stumped. Then I found a thread that suggested Windex!!! Even though the error seemed to correlate with a paper jam that had occurred, I was ready to try anything. I got paper towels and windex (I didn't have an eye dropper). I sprayed the paper and cleaned where the cartridges normally sit. Nothing. In desperation I sprayed each pad below the cartridge in the middle area and I sprayed the "sponge" thingy to the right. Really soaked it. Cycled the on/off about 3 times and IT WORKS! (Fingers are black but that's a minor issue compared to unhooking and transporting and waiting and paying for service...) When you cycle the Windex through it soaks up the sticky dried up ink and cleans things up. Don't use other cleaners--use Windex or water.
Bonni
Posted on Feb 26, 2009
goodgold
  • 389 Answers
SOURCE: My Canon MP830 Printer will mot work. Alarm
Canon MP750, MP760, MP780, MP830
The Unset mistake:
##341. Maintenance jet waste ink capacity full
##342. Cleaning absorption waste ink capacity full
##343. Ink detection waste ink capacity full
1. Include the printer.
2. Press button Menu , then Scan , Copy and once again Scan (entry in service mode, on дисплее will appear #1 SSSW)
3. The Arrow to choose 7. Printer test , press Ok .
4. The Arrow to choose 5. Ink abs capa , press Ok , install importance 0 .
5. Switch off the printer.
Posted on Sep 28, 2009
How can i send an ascii file to a network shared Datamax Prodigy Plus printer? It is not printing via send file, windows driver send command to printer works. Thanks for any help!
copy file.txt lpt1 is the command to copy the txt file to the printer, but it must be correctly formatted for the Datamax. I don't know Datamax's programming language, but at first glance that file looks like ZPL to me. If it is ZPL the Datamax can't print it.
Jun 15, 2015 | Datamax Prodigy Plus Thermal Printer
Print is encrypted, nothing is readable.
If you are printing it from online, try copy and pasting the content to Word or Excel and print from there.
Oct 02, 2008 | HP PSC 2210 All-In-One InkJet Printer
HOW DO I copy a file on my document to my flash drive
There are a couple of ways to the this.
1. you can right click on the file and select copy then select your flash drive and right click inside the folder you want to place it and select paste.
2. Open your flash drive and your my documents folder and click & hold the file you wish to copy and (while left click and holding) drag the file to your flash drive
3. If you have the file open you can save as and select your flash drive as the location to save it.
Youtube clip here (not mine): http://www.youtube.com/watch?v=UkOVz32z51U
Mar 05, 2011 | Computers & Internet
Can you give step by step instructions on how to send text messages
Dear Mliesenfeld,
My solution for you is by way of providing you the manual so you can either view it on your computer, or so if you want a hard copy of this you can keep it on paper. So here is the answer.
Here is a copy of the manual I have found for you, the only trick to this though that it is in .PDF file format, so what you will need to do is print this out, or save it to a USB Solid State Flash Drive (or known as a usb pen drive, thumb drive, key drive etc etc), and walk it to another computer and then print it from that location if you do not own a printer. One quick note though, you will need either adobe reader or some version of acrobat in order to view .PDF file formats/ extensions. These you can find pretty much anywhere.
Anyway the link you will need is
http://cache.vzw.com/multimedia/mim/lg_ally/ally.pdf
Feb 27, 2011 | LG Ally Cell Phone
I have attached the HP 4255 officejet with my computer and want to send the file directly from my computer via fax. how i can send directly without geting print . mubashir@ellahifabrics.com
Well, you'll need a modem to send a fax. Either that, or an online faxing service. Your printer / scanner is only intended to either print files, or scan hard copies into files that can then be printed (or faxed). The printer itself does not fax.
Might I suggest the following online fax service, free of charge:
http://faxzero.com/
There are plenty of others.
-Jon
Oct 21, 2009 | HP OfficeJet 4255 All-In-One InkJet...
How to use flash drive
Cruzer Micro is an USB external memory where you can store files.
It is automatically detected and installed on all Windows OS from Windows 2000 onward, same on Mac OS and recent Linux versions.
All you have to do is plugging the device into USB.
After the flash drive had been automatically installed , it will be displayed under Computer as an external disk.
You can copy and transfer files using Cut, Copy and Paste functions, or Send to function in windows, or the file manager, depending on the OS used.
In Windows, before unplugging the memory from USB , it is better to turn off the computer or use the 'safely remove USB' function located near to the clock, on the lower right hand corner.
Read also the documents below:
Introducing the Cruzer Micro
Find Answers || BeCompliant Corporation
How to Use Sandisk Cruzer Flash Drive
May 15, 2009 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
Bizhub C 250 stops printing! Hepl please!
Sounds like the controller has crashed.
If you have a Fiery, reboot it and see what happens.
If that does not help you better call a Technician as it may need to be reloaded.
Sep 08, 2008 | Konica Minolta bizhub C250 All-In-One...
2gb usb 2.0 flash drive
I hope someone has helped you by now! After you plug your flash drive into your computer USB 2 port, your flash drive should appear in "my computer" as a drive. You can rename that drive by clicking once on the drive and then right clicking your mouse and selecting "rename" and name it Your USB or something that reminds you its the USB Drive.
Whether you rename it or not, all you have to do once your computer has recognized the USB drive is to open the folder where your documents are kept and either "move" or "copy" them to the USB drive. Remember that "moving" the files will remove them from your computer and transfer them to the USB drive. Copying the files will leave a copy on your computer as it copies the file to your USB drive. You can also right click the file with your mouse and move the pointer over "Send To" and choose your USB drive from the list and it will Copy the file to your USB drive.
Jun 29, 2008 | PNY 4GB USB 2.0 Flash Drive - Grey/Black
Canon PIXMA MP150 All-In-One InkJet Printer Logo
old marine
old marine
