Question about Canon MultiPASS MP730 All-In-One InkJet Printer
I am having trouble with my Cannon Multipass MP730. It is only printing in color, the black will not print. I have changed the black cartridge twice and it still doesnt work. Any suggestions? Thank you, Aviva, New Jersey
My toner was low, so I replaced it...it printed one page and now won't copy or print (cannon multipass mp730)
If you changed the toner cartridge before the previous one was completely empty, it is possible the machine simply did not reset.
Turn the power off and take the new toner cartridge out. Turn the power back on and wait for a message telling you there is no toner.
When you get the no toner message re-insert the new toner cartridge.
If this does not clear the message, you will need to find the button to press to manually reset the toner cartridge from Canon.
Thanks,
Pat
Apr 26, 2010 | Canon MultiPASS MP730 All-In-One InkJet...
Canon mp730 has stopped printing magenta. We had just changed all the other color tanks (black, cyan, yellow) and magenta stopped printing. We then found we had dislodged the magenta tank (was...
Unclip it again and clean contacts on both printer and cartridge with a lint-free paper and a little alcohol (isopropyl alcohol if you have it). Clip it back and run the head cleaning and alignment routine; that should be enough.
Nov 29, 2009 | Canon MultiPASS MP730 All-In-One InkJet...
Printing
if your problem is printer setup page in go
and select to the b & w print and ink setting
are dark print set and give your print page
problem is also
Sep 12, 2009 | Canon MultiPASS MP730 All-In-One InkJet...
Cannon multipass F60 scanner/printer striped color printing
What you have is a dried up color cartridge. You can try to use the <clean print heads> in the diagnostic tools section of you priner software. (usually, just try to print something & the window will appear) Sometimes you have to clean heads, then print test page like 2 or 3 times before it clears up. If that doesn't correct it, don't worry. Have your color cartridge filled (staples, office depot, & other stores do it cheap) - or - replace it with a new cartridge. You may have to run the clean print heads program after installing a new cartridge, but this will definitely fix your problem.
Jul 26, 2009 | Canon PIXMA MX850 multifunction InkJet...
Printer prints wrong colors
As a guess you have the color ink cartridges in the wrong places. Take them out and run a whole bunch of head cleaning routines. I'd expect the wrong colors for a while until the incorrect ink has been flushed out.
Check your manual or setup guide for the actual order . Usually black-cyan-magenta-yellow
Jul 09, 2009 | Canon MultiPASS MP730 All-In-One InkJet...
MULTIPASS MP730
I just replaced my blk ink cartridge also, nothing prints
Jul 24, 2008 | Canon MultiPASS MP730 All-In-One InkJet...
Cannon multipass 390 print problems
I have the exact same problem, cleaned heads, replaced cartridge, nothing prints, no ink at all no colors or black.
May 08, 2008 | Canon MultiPASS MP370 All-In-One InkJet...
MP730 prints all colors EXCEPT Black
I had the same problem. After replacing the Cyan and Black the Black would not print. I deep cleaned the cartridges about 8 times, interchanging cleaning and printing test pages. Eventually the cartridges began working properly again. I know this is not much help, but it has worked for me.
Mar 01, 2008 | Canon MultiPASS MP730 All-In-One InkJet...
Print quality is poor
if you replace the black ink cart with an original one then it's the print head
Solution: Cleaning the Print Head - C555 / C560 / C635 / C530 / C545
Untitled Document Follow this procedure to clean the BJ cartridge print head:
1. Press c755funckey.gif 2. Press c755cleankey.gif 3. Use c755down.gif or c755up.gif to select the [HEAD CLEANING]..
4. Press c755set.gif.
The MultiPASS cleans the print head.
Feb 12, 2008 | Cannon MULTIPASS C530 Printer
Canon MultiPASS MP730 All-In-One InkJet Printer Logo
59 people viewed this question
old marine
old marine
