Question about Mitsubishi WD-73732 73" Television
MODEL WD-73732 REPLACED BULB YESTERDAY, WORKED FINE FOR 1 DAY, NOW THE PICTURE IS TURNING GREEN AFTER THE TV IS ON FOR 30 MINUTES OR SO.
  • hawkins_donn Sep 28, 2009
    TRIED THAT, NOW THE LAMP SENSOR ON THE FRONT OF TV IS FLASHING. YOU ARE RIGHT, IT WAS HOT, HAVE A FAN BLOWING NOW.
    I ordered a bulb from Pureland supply item# 69440. I noticed on the back of the lamp cartridge the number is 915P049020 is this the reason it gets so hot because it is not the right bulb.
    President:
  • 2,923 Answers
It may be related to heat issues. Try turning off the TV, unplug the cable from the socket and leave it disconnected for 15-20 minutes. Turn the TV back on.
If same problem occurs, removed the back cover where the lamp is housed and stuck a piece of folled up paper into the slot that that has the "cover open" switch. then put a regular fan to blow in there. This should resolves the issue. But this is just a temporary solution. I would still suggest you to contact the manufacturer so that the TV won't generate too much heat that would cause the TV to display green.
Have a great day!
Posted on Sep 28, 2009
  • Melvin Ramos
    Melvin Ramos Sep 28, 2009
    You may observe the behavior of the TV while using a fan, BUT still, this is just a temporary solution. I don't consider this as a fix. The TV should work properly even without a fan. That is why I suggesting to contact the manufacturer for second opinion, so that you could completely resolves this problem.
    Thank you!
  • Melvin Ramos
    Yes it could be. You need to use the right part for the TV to work correctly. Bulbs uses different Wattage. If the voltage that the TV is giving out to the bulb is too high and the bulb could not handle it, that would cause too much heat.
    Be sure to use the right part for the TV.
    Thank you!
Flashing green light
I have a mits. 82738 tv which would shut off after 20 minutes when first turned on .
Loose sound and picture.
Looked up error code in service manual and it said the lap was the problem.
Replaced lamp and now it works fine and the picture quality is great.
Jan 20, 2014 | Mitsubishi WD-82738 DLP TV
Tv shutdown
check your lamp door interlock switch.
Jul 31, 2010 | Mitsubishi WD-65733 65" HDTV
Mitsubishi WD-73732 TV
It could be a bad lamp but I've run into many of these TVs with bad color wheel assemblies. Also, if you are getting a dialog box coming up with these words," airflow blocked, TV will shutdown ..." that's a defective thermal fuse.
This is a job for a mitsubishi authorized service center. A tech can disassemble the light engine and confirm that the wheel is the problem. If you're still in warranty, great. If you're only recently out of warranty, call mitsubishi for assistance. Remember that persistance pays off when dealing with large corporations. You very seldom get what you're looking for on the first call or from the first person you speak to.
michtech
Apr 29, 2008 | Mitsubishi WD-73732 73" Television
Half of the screen goes black
the light engine is defective and needs to be changed..this set is not that old..contact mitsubishi customer relations to see about having it done under a customer accomodation, as they have had a lot of problems with the engines
Nov 28, 2007 | Mitsubishi WD-73732 73" Television
Mitsubishi WD-73732 73" Television Logo
117 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
