Washing machine shakes
I just got a washing machine that shakes horribly. I checked the balance by the legs and made sure the rear legs were stabilized and they are. The tub sits off to the right, like a spring is missing but the washer is only a year old and the springs are in excellent shape so I don't think one is missing and I don't believe a hole has rusted through. I don't know how to tell is there is one missing or if maybe the one there is stretched. When I tilt the washing machine over I can see everything inside but it seems really complicated to get the back of it off. What to do?
    Scholar:
  • 83 Answers
  1. Find out the reason for the shaking during the spin cycle. The cause will usually be either a badly out of balance load, or a poorly leveled and set up machine.
    • Balance the load of clothes by opening the lid, and looking to see if there is a lot more on one side of the agitator than the other, and if this is the problem, move them around, close the lid, restart the spin cycle, and observe the results. You may try repositioning the clothes in the tub slightly more if you original efforts helped significantly.
  2. Try to tip or tilt the machine. If it wobbles when you do, the adjustment screws on the machine's base may not be set correctly, or on older machines, the threads may be stripped or corroded out, causing them to fail.
  3. Relevel your machine and insure it is supported correctly. This is done by kneeling down in front of the machine, and rocking it to see which corner seems to be floating, or not in contact with the floor. The leveling screw should be screwed out (clockwise, if viewed from above), which lengthens it, or the adjacent side should be screwed in (shortened), so that each leveler is in contact with the floor.
  4. Use a pair of pliers if the thumbscrews are too tight to turn with your fingers, and spraying the screws with a lubricant may help, also.
  5. Restart your machine when you have made sure all the leveling screws are in contact with the floor.
  6. Use shims to support the machine if the screws have become unusable for some reason (broken, stripped, or otherwise damaged). Shims can be made of almost any resilent, non-degradable material which can be cut easily, like scrap vinyl composition tile, rubber matting, or even plastic margarine container lids.
  7. Cut a number of shims, about 3 or 4 inches in width, and stack them under each corner where they are needed, until the corners are equally supported.
  8. Restart the machine and observe your results.
Posted on Sep 28, 2009
How do I fix a front load washer that shakes violently on the last spin cycle?
CLOTHES UNBALANCED? OR COUNTER BALANCE SUPPORTS BROKEN, AND NEED REPLACMENT? WASHERS have many different weight balancers but sounds like u need to take body off and have look at the counter weights set up while running machine, just jumper the door switch to keep a closed line. and then agin sometimes its as simple as making sure ur washer is leveled on ur floor, check ur leg adjusters as they do get funny at times..
Sep 13, 2014 | Washing Machines
Washing machine shakes violenly at slow speed
have you leveled the machine by its legs and locked them in place with the jamb nuts between the case and legs? if so then it could be your drum bearings going bad on the inner drum
Apr 04, 2010 | Hotpoint Ultima WF860 Front Load Washer
Maytag washing machine gets out of balance
Maytag uses an auto balancing mechanism, based on the rear legs. These legs should move freely. Lay the machine on its side, and try to move the rear legs. If they won't move and appear rusty, then spray penetrating oil on both legs and move them until they move freely.
Sep 27, 2009 | Washing Machines
My washer shakes horribly during the spin cycle. I have tried adjusting the legs numerous times but it seems no matter what I do it shakes bad. Is there probably a more internal problem that needs to be...
Yes you do, need to get it fixed whilst under warranty. The drum is out of balance. Now you need to check that you are distributing the load and not exceeding the recommended dry weight before you do call them. Make sure load is evenly distributed when you put the wash in DONT just throw them in and leave it to the machine to wotk it out. Just the legs at the fromt to ensure the machine is level , bot tipped back.
Please rate our help to keep the service online
Aug 30, 2009 | Washing Machines
Whirlpool Kenmore 80 Series is making loud noises during washspin
Hi, Make sure the washer is solid to the floor. To level the washer, Put your foot against the front panel at the floor and tip the back of the washer toward you. Then set the washer back down and the rear legs should self adjust.
Hopefully this will stop the washer from shaking.
Vic
Jul 05, 2009 | Washing Machines
Excessive shaking
your suspension dampers is damaged on washing machine causing bad balance on spin cycle..
Mar 03, 2009 | LG WM2277HSW XL Front Load Stackable...
Washing macine balance
Adjust the legs on the washer that seems to be the problem. Or you could have broken the hinges and springs on the tub itself. The easiest thing to try is the legs first they just twist like a screw
Feb 09, 2009 | Kenmore Washing Machines
Maytag model LAT9605AAE serial # 13662937QD washer gets out of balance constantly on every spin cycle
make sure all of the legs are adjusted correctly. maytag washers also have to be on a very stable floor. if the floor is not stable or if the legs are not adjusted properly then the machine will shake all over as if they are out of balance.
Jul 01, 2008 | Maytag Washing Machines
Speed Queen Top Loader heavy duty washer
First unplug the machine, now take off the front panel, two screws at the bottom of the front panel, front panel swings up and off.
check to make sure the six springs are still in place.
Under the tub is bearing housing between the tub and base usually white in color, under this is a plastic ring, does it seem to float easily when you move the tub. it could be broken. Also look around for loose or missing screws.
If all seems fine, make sure you have all four rubber feet on, level machine, in the front first side to side, then pull machine toward you to bring rear legs off floor, these are self leveling, have someone assist and make sure they are not stuck, use a pliers and break loose if they are. So with the machine on its front feet and the back feet off the ground set the machine down on all four feet check level front to back adjust as needed on the front legs. You should reset rear legs as you adjust the front. now with machine level tight the nut between the front legs and the base locking them.
This should help, if machine still shakes it could be the balance ring, has lost if solution its filled with a salt water solution, the hard part is you need to find it under the tub cover. we will go into the detail if we need to. ask more questions later
Jun 24, 2008 | Speed Queen AWS75NW Top Load Washer
How to balance machine during the spin cycel?
i have found that by leveling the washer all four sides turn the locking nut up on the rear legs lock them then run up both front legs about 1/8 in higher than rear also lock them it takes almost all shaking out if the 2 dampner shocks are hooked up
Jan 13, 2008 | Frigidaire ATF6000ES Front Load Washer
Washing Machines Logo
57 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
