Question about Electrolux EL1000A2 Pronto Bagless Stick Cyclonic Vacuum
Roller problem Roller keeps stopping. I've emptied the dustbin. removed the roller to see if it is clogged, but appears to be nothing impeding it.  It stops on a short napped rug, and even on the wood floor.  Is the spool that the roller slips into driven by a belt? Can I get in there behind the spool?
  • jenkybobinky Dec 23, 2007
    After vacuuming for a few minutes the roller stops working and the green light goes out like it's not getting power. I've tried taking it apart to see if there is a problem with the wires, cleaned it effectively and cannot get this problem fixed. I would appreciate any help with this!
I have 3 Prontos, one in each part of the house. Two of mine had the rollers stop. I figured out the problem and it fixed both. Take the roller out by turning the plastic screw and popping the plate off. Pull all debris off the wheel that turns. Turn unit on and make sure this wheel is turning freely. Take the brush and look on the end with the square part. Take some pliers and gently pull this square piece off. I had to wiggle it a little, but it pops right off. Clean all debis (mine had several small dust balls and 1 long hair) in the square part and down in where the square part goes. Push the square part back on and put brush back in unit. This fixed both of mine. Hope it helps.
Posted on Sep 23, 2008
    President:
  • 1,673 Answers
Either you have a bad belt, they stretch, and maybe a problem with the brush roll.
Posted on Feb 22, 2008
The brush of my shark cordless vacuum keeps stopping
Hello, this is Ava with Think Crucial.
There are a number of reasons why your brush roller has stopped moving. General maintenance to your vacuum is crucial and will help it work at peak performance.
First things first lets focus on the brush roller. Unplug the vacuum and turn it on its side. Look for any noticeable clumps of debris or hair strands that may be caught in the brush roller. Remove these obstructions, probably best to do so with a scissor if it's hair or long pieces of carpet fibers. After removing the debris try manually rotating the brush roller to uncover other hidden clogs. Another thing to take note of is the condition of the bristles on the roll itself. Are they loose or worn down? These are signs that your brush roller is in need of replacing.
While checking out your brush roll you might as well take a look at your vacuum's belt. Your belt should be replaced about every three months. After regular usage, the belt will stretch out, lessening the tension on the brush roller. Lesser tension diminishes the brush roller's turn rate and speed. If the belt feels loose then it certainly is affecting your vacuums suction as well as your brush roll not moving at all.
You can purchase a wide variety of high-quality Shark replacement parts for your Shark vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/search?type=product&q=shark
I hope this was helpful.
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
Apr 14, 2017 | Shark Vacuums
My 2 year old Dyson roller head keeps sticking and won't turn unless I bang it several times. Can the roller be worn and needs replacing?
While checking out your brush roll you might as well take a look at your vacuums belt. Your belt should be replaced about every three months. After regular usage, the belt will stretch out, lessening the tension on the brush roller. Lesser tension diminishes the brush roller's turn rate and speed. If the belt feels loose then it certainly is affecting your vacuums suction as well as your brush roll not moving at all.
You can purchase a wide variety of high quality Dyson replacement parts for your Dyson vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/search?type=product&q=dyson
Ava B.
Dec 14, 2016 | Dyson Vacuums
So I have a dyson dc35 multi floor and it was working great then i turned it off to empty it and the brush wouldn't spin anymore. I cleaned it charged it and still nothing.
https://www.thinkcrucial.com/search?type=product&q=dc35
Ava B.
Nov 04, 2016 | Dyson Vacuums
Hover uh70400bca the bottom cleaning brush stopped working the belt is good the vacuum part workes good
The brush roller may be clogged with debris, especially inside the end caps. You will have to remove the brush roller and disassemble it to check inside the end caps.
Dec 21, 2014 | Vacuums
Roller stops working after just a few seconds
Haven't had this problem, but sounds like an obstruction of some kind. Turn the vacuum upside down and clean any lint, thread or hair around the roller and make sure there is nothing stuck in there that would impede the roller. I have a long haired dog and have to do this regularly.
Jun 19, 2014 | Shark SV1100 Navigator Freestyle Cordless...
Brush not turnning
The brush roller is driven by a belt installed on the motor shaft. The belt could be broken or off the shaft. The brush roller could be clogged inside the end caps with debris which prevents rotation. To solve the debris problem, it will be necessary to remove the belt from the motor shaft, then note the orientation of the end caps and remove the brush roller. Next, remove one end cap and check for clogging material. Remove the material. Slide the brush roller shaft away from the end of the brush roller to check for clogging material at the opposite end. Remove the material. Slide the brush roller shaft back into position and reinstall the end cap. Reinstall the brush roller in the correct position. Reinstall the belt. Check for proper rotation of the brush roller.
Apr 08, 2014 | Electrolux EL8905A Nimble Brushroll Clean...
Shark navigator uv300 roller stops while vacuuming filters are clean and not clogged up
The belt that turns the rotating brush is loose. Make sure it is on correctly or replace with a (new) tighter belt. This will require you to unscrew a few screws on the bottom & remove the cover. Then remove the roller.
Nov 06, 2013 | Vacuums
Belts keep burning and breaking on turbopower 7100
If a roller brush does not rotate freely, the motor shaft spins in one place on the belt until it heats it up and breaks it. Roller brushes can become clogged on the ends, especially with pet hair. The solution is to remove the roller brush completely and inspect onder the endcaps, removing them if necessary to clean them completely. The roller brush should be reinstalled carefully, observing the upward orientation of the arrows on the end caps. Check operation before assuming that the problem has been solved
Mar 24, 2013 | Vacuums
My Hoover brush spins, but doesn't have very strong suction. I've checked the filter, tubes, but it seems as though something is stuck inside. Can you tell me how to check behind the roller to...
To get the roller out.Turn the machine upside down.You will see some screws.Remove them.That allows you to remove that plate.The roller will just lift out.Some have a cap on it and can fit tight.On the back of the machine are two more screws that hold the hose on.You can take the hose off there ,if you have not already.Running a straightened out wire hanger through the hose will insure that there is not a clog you may be missing.As it is a few years,replace the belt while you have the roller out.It is on one end of the roller and the other end slips on a small wheel.It is easy to do and may improve the over all performance of the vacuum.
May 16, 2011 | Hoover U8145-900 Savvy Bagless Upright...
No suction using extension hose for Bissell Bagless Upright vacuum. i checked for clogs and found nothing. shannon
Check the sole plate where the beater bar is. You may have to remove the roller brush flap to get into the roller brush and then check the main dust channel beside it. Usually if there's no suction on the hose it means that:
1) The hose is blocked 2) The filters are needing cleaned / washed and dried for 24 hours or see my tips! 3) There is dust clogging after the beater bar/roller brush.
Jul 18, 2009 | Bissell CleanView II Plus Upright Bagless...
Electrolux EL1000A2 Pronto Bagless Stick Cyclonic Vacuum Logo
202 people viewed this question
Top Electrolux Vacuums Experts
Marvin
Marvin
Chris Nomland
Chris Nomland
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
