Question about Sanyo DS31590 31" TV
Unit turns on and after little while has strong odor and a horazonal wave starts to go from bottom to top.
  • 156 Answers
There is problem in the power supply section.Try to replace the main Electrolytic capacitor usied in the power.
Posted on Sep 28, 2009
It is running hot but no heat. There is a strong antifreeze odor after it has ran. Is it the thermostat?
maybe, it could be that your thermostat has locked in the closed position, not allowing coolant to flow through the engine from the radiator. your best bet is to check your thermostat before starting the engine again to avoid risk of heat damage to engine, the strong antifreeze odor could be from the little bit still in the engine cooking off or a small leak onto a hot engine part. don't really know but check your coolant level and thermostat just to be safe.
Mar 24, 2015 | Cars & Trucks
2001 Tundra 4.7 L won't idle when cold. Has new plugs and coils.
The coolant temperature sensor signal to the computer determines fuel injection ratio. When it fails the car will be slow to start and a strong odor of gasoline. turn it off and it will start as normal. A failed sensor will also cause stall at idle speed and poor gas milage. the sensor is located near the top radiator hose connection at the thermostat housing.Use a 19 MM deep well socket.
Feb 19, 2015 | 2001 Toyota Tundra
Bad Odor on the Lakewood Oil Filled Electric Radiator Heater
Pull the 4 small screws from top & bottom of plastic cover (2 under plastic tab on top, pry off) and then check ALL connectors and all wires. Chances are one of the leads has been overheating and smoldering (mine burnt wire off on lower Thermal switch.) You may need a KDS 301themal switch matching the one in your heater. Google for sellers.
Jan 16, 2012 | Lakewood Oil-Filled Electric Radiator...
Strong odor of ammonia. Winter refrigerator is turned off odor dissipates. Returns after unit is turned on for a while.
HI
You have a leak in the operating system. What kind of unit is this, does it have a model number I can research for you?
Glad to help
Jul 28, 2011 | Dometic Refrigerators
There is a strong odor coming from the freezer something like a fish smell or a burnt wire. The ice maker is working ok and the fan blows air just fine and the freezer and refrigerator are operating just...
The smell could either be the fan motor or the defrost heating coil...
Check out these tips...they can help you figure out what is going wrong withyour refrigerator
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Mar 18, 2011 | Amana ABB1927DE Bottom Freezer...
Whirlpool Duet was purchased December 2009 and lately has a strong odor. Does this front loader have a filter we can clean? Please advise how to get rid of this ongoing odor.
There is no filter but you might want to remove the bottom front cover and clean out the sump filter(a large white thumb screw attached to pump) turn to the left. After cleaning this out get a product called Affresh available at grocery and other stores. Put your unit on a clean cycle. If you can't find affresh try a cup of bleach and run that through a clean cycle. Another tip leave your door open when not in use
Feb 26, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Norcold 982 will not get cold.
If the there is a strong ammonia odor and no cooling, then you probably have a leak in the system somewhere. These types of absorption units must be repaired in a specialty shop. The most common place for a leak is the condenser coil, but can also be the evaporator inside the unit, if the odor seems to emanate from that area.
Apr 06, 2009 | Refrigerators
Chemical odor in refrigerator/freezer
put coffeee grains or orange peeles this will take the smell away thanks from gilles
Mar 14, 2009 | Refrigerators
Reddy Heater 60k kerosene suddenly smells
Here are a couple of tips that I wrote that tell you how to troubleshoot aTorpedo or Reddy heater...
Reddy Heater - Troubleshooting Torpedo Heaters Torpedo Heater Pump Pressure Adjustment
heatman101
Mar 09, 2009 | Reddy R60A Utility Heater
Have Virtical and horazonal lines ....Please help
· http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
· http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Mar 14, 2007 | Toshiba 57H81 57" Rear Projection...
Sanyo DS31590 31" TV Logo
26 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
