Question about Panasonic PT-50LC13 50" Rear Projection HDTV
I have replaced the lamp on my Panasonic PT-50LC13 but now it says I need to reset the lamp timer. How do I do this?
  • 557 Answers
1. Plug in the AC Cord, and turn on the power by pressing the
POWER button.
2. Press and hold the VOLUME DOWN button on the unit and
the SPLIT key on the remote together for over 5 seconds in
power on condition.
Posted on Sep 28, 2009
How to reset lamp timer on pt 50L C-13
Their manual says:
After lamp replacement, you must reset the lamp
time. Refer to the instructions enclosed with the
lamp unit (Part No.: TY-LA2005).
lamp unit (Part No.: TY-LA2005)."
http://www2.panasonic.com/consumer-electronics/support/Televisions/LCD-Projection-TVs/model.PT-50LC13
Aug 09, 2010 | Panasonic PT-50LC13 50" Rear Projection...
PT-50LC13 reset lamp timer
Replaced the Lamp, on my PT-50LC13 pan TV. But cannot reset the timer because the screen does not light up. and the instructions say to hold down the -Vol button and the pip button. But which one? there are 3 buttons with the word PIP
Apr 02, 2010 | Panasonic PT-50LC13 50" Rear Projection...
I have a large screen panasonic tv. The lamp
Turn On tv.
Press and hold Volume Down button on TV Front and PIP/ SPLIT button on Remote at same time for 6 Seconds to reset Lamp Timer and tv will show you timer reset message screen.
Hope this info will help you.
Thanks.
Mar 31, 2010 | Panasonic PT-50LC13 50" Rear Projection...
How do you remove the lamp
To replace lamp in Panasonic PT-50LC13 tv, please follow this...
1- Place your fingertips under the front cover and pull it from the projection display.
2- Loosen the lamp cover screw using a screwdriver.
3- Using a screwdriver, loosen the lamp unit screw.
4- Grasp the lamp unit handle and slowly pull the lamp unit from the projection display.
5- Put new lamp and fix things in reverse order.
Now need to reset lamp timer as follows,
While pressing the VOL Down button on the projection display, hold down the PIP or SPLIT button on the remote control simultaneously for more than 5 seconds.
When lamp timer will reset, tv sill show "lamp time was reset to 0" message.
Thanks.
Feb 25, 2010 | Panasonic PT-50LC13 50" Rear Projection...
Replaced bulb,still not turning on-power flashes green then red and lamp light comes on
Did you reset the lamp timer? If you replace the lamp and dont reset the lamp timer the TV will continue to display the lamp error until you do.
Sep 22, 2009 | Panasonic PT-50LC13 50" Rear Projection...
I just replaced the lamp in my tv and now it shuts
You probably have a defective new lamp. Did you put the lamp door back on?
Aug 08, 2009 | Panasonic PT-50LC13 50" Rear Projection...
Panasonic PT-50LC13 reset hour meter
on the tv itself push the volume down button and at the same time using the remote control press the pip button. I just did this on my tv - had the same problem. it worked perfectly. Jeanne
Jun 21, 2009 | Panasonic PT-50LC13 50" Rear Projection...
PT-50LC13 lamp
Replacing the lamp on a Panasonic PT-50LC13
Unplug the unit from the wall and wait for all the lights to stop blinking. Ensure that the lamp and the area around the lamp has cooled.
Remove the front cover of the set. You should be able to see the lamp door at this time, loosen the screw and remove the door. You will now have access to the lamp, loosen the lamp screws and remove the lamp cartridge. Reverse the above process and you should be back in business.
For the full instructions and how to reset the lamp timer go to the following site
http://fixyourdlp.com/blog/wp-content/uploads/2007/09/panasonic-tyla1000-lamp-instructions.pdf
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I have helped you, please help me, and rate this suggestion a the highest FixYa rating (Give it Two thumbs up). If not then please comment to this post and I will try to help you further.
Thank you for your support.
May 22, 2009 | Panasonic PT-50LC13 50" Rear Projection...
How to reset the meter of lamp
You need to have your Panasonic remote.
1. Make sure the power cord is plugged into a properly grounded outlet and turn on the set with the power button on the projection unit or the remote control.
2. While holding down the (VOL -) key on the projection unit press the PIP or SPLIT key at the same time. Hold it for longer than 5 Seconds. The PIP or SPLIT key is model specific:
PIP for Models:
PT-50LC13/PT-60LC13/PT-50LCX63/
PT-60LCX63/PT-43LCX64/
PT-50LCX64/PT-60LCX64
SPLIT for Models:
PT-43LC14/PT-50LC14/PT-60LC14
3. When the unit resets the lamp timer it will display a screen on the TV indicating it was reset to zero. You press recall on the remote to exit.
You will find a PDF of the instructions at this site:
Aug 23, 2008 | Panasonic PT-50LC13 50" Rear Projection...
Panasonic PT-50LC13 50" Rear Projection HDTV Logo
273 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
