Question about Roper Dryers
I set the timer then push the ignition button all I get is droning sound and no drum rotation mallardman
  • 48 Answers
Bad or broken belt or it may have`slipped of motor pulley due to overweight load
Posted on Sep 28, 2009
What could possibly the reason my amana dryer wont tumble and just buzzes when you push the start button
Could be a broken belt spin the tumbler by hand it if it spins real easy the belt is off or broke another thing to try if you have resistance when turning the drum have a helper for this one open the door and hold the door switch in set timer to a cycle and press start while holding switch and buzzing spin drum and see if it will continue to rotate while holding switch if so motor going bad
Feb 17, 2015 | Amana Dryers
Washer will not shut off.
sounds like the final phase is not being registered on the timer or the computer chip may need to have a service tech diagnose but it isn't a complex problem just an annoying one, the final phase is a cool down cycle and also you may need to see if you have the settings for cotton clothes, the dryer will tumble them so as not to let them wrinkle. hope this helps
May 27, 2008 | Maytag Neptune MAH5500B Front Load Washer
The selector knob on my Whirlpool LER4634JQ1 does not move, so the dryer will not turn off automatically and no "end of cycle" buzzer sounds. Do I simply replace the timer?
Your timer most likely does need to be replaced. The timer has a small motor that causes it to rotate during the cycle and those can go bad causing the timer to not advance. Unfortunately, you cannot get just that timer motor anymore. Hope this helps!
Feb 16, 2015 | Whirlpool Dryers
GE dryer model DDE8200GALAD was working fine. After removing a load and trying to dry another, after inserting the load and shutting the door when you turn the timer to start it before pushing the start...
If you hear the motor humming and not starting at all it most likely has a severe friction problem with the drum or motor. It could possibly have some type of garment jamming the blower wheel preventing the motor from starting too.
Open the dryer door and manually rotate the dryer drum counter clockwise (CCW). It should take very little effort to rotate the drum. If it's hard to rotate that could explain why the motor hums instead of starting up. If it turns freely, shut the door and see if will start. If it still hums and not start it may have bad motor or a low voltage supply to the motor.
Jan 23, 2011 | GE Dryers
I push the start button and nothing happens
Turn your power off and reach inside the drum and rotate the drum 1/4-1/2 turn, turn the power back on and try pushing the start button again.
Sometimes motors get dead spots in them and this helps to move it from the dead spot.
If that doesn't solve the problem try to listen very closely and see if you can hear the motor running...if it is then the problem is a broken belt.
Otherwise could be your timer switch faulty, or the start switch faulty.
I hope this helps
Oct 01, 2009 | Whirlpool Dryers
Whirlpool Dryer Drum Won't Rotate
sounds like your drum belt has broke. remove two phillips screws at lint screen. pull top towards you then up. you will expose drum.
Jun 24, 2009 | Dryers
Our Kenmore clothes dryer is not starting.
its sounds like you have a broken belt or a bad door swith open the door rotate the drum manually if it feels verry easy to turn that means your belt is broken if not you can check the wires then replace the door switck thanks from gilles
Mar 15, 2009 | Kenmore 84052 Dryer
Indesit washing machine
Sounds like belt has fallen off!
Mar 15, 2008 | Indesit WA 125 Front Load Washer
Dryers Logo
32 people viewed this question
Top Roper Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Roper Dryer Expert? Answer questions, earn points and help others
