Dell aio 926 comes up with error 2200 when i need to print. it says that the printer is not communicating with the computer, have un plugged tried mostly everything help
My Dell 926 AIO Printer will not print after installing new ink cartridge. Ink level on computer still says empty.
you must cleaned cartridge before you plug on printer, for level ink detection you must waiting for moment for ink spread on cartridge.
Mar 09, 2011 | Dell 926 All-In-One InkJet Printer
I'm tryin g to scan a photo with my Dell AIO 926 Printer, connected to my Dell Inspiron 1525 laptop. But the laptop doesnt seem to be bringing up the AIO 926 printer file folder/menu, and when I request...
Did you figure this out? You should have a "Dell All-In-One Center" that was installed with the drivers for the printer. Try searching for it by pasting that phrase in the box in your "Start" button. When you locate it, drag the shortcut to your desktop or up in the top of the programs in the Start location. When you click on the Dell All-In-One Center icon, you should find some options for scanning.
Nov 12, 2010 | Dell Photo 926 All-in-One Printer
Deleted the whole Dell photo aio 926 program in error. Try to run the orig cd that came with printer but it won't run. How can I get it back? Went to search and came up with 'google icon' and 'folder' but...
Try reinstalling the printer using the instructions located at....
926 Photo All-In-One Printer owners thread (W7)
You'll need to disconnect the printer. Download and run the patch(printer cleanup utility) until it prompts you to restart your computer.
Restart your computer.
Install the proper drivers. You'll get the message, the printer is not connected. Connect the printer at this time.
Rick
May 21, 2010 | Dell 926 All-In-One InkJet Printer
Error 1203 for Dell Printer AIO 926
Ok Error 1203 is an issue that occurs either when a cartridge is bad or the printer cartridge Slot is bad...
1 - try cleaning the copper contacts of the both carts and cart slot in the printer and try again..
or
2 - when error shows up, shut the printers power off; wait one minute and turn it back on press copy.
Jan 17, 2010 | Dell 926 All-In-One InkJet Printer
Printer status window interface stopped working dell AIO 926
I know this sounds too simple, but get a new USB cord. I had the exact same problem and it was driving me crazy. I followed all the advice about uninstalling, reinstalling and updating multiple times and it never fixed the problem. Finally, my husband made the simple suggestion that maybe it was a problem with the connectivity of the USB cord. I didn't have much faith in it, but I bought a new USB cord and hooked it up - and I have never had a problem with the printer since then. My original USB cord (the one replaced) was the one that came with the Dell printer - perhaps there is a flaw in the cord somewhere. ?
Jan 16, 2010 | Dell 926 All-In-One InkJet Printer
Dell photo aio Printer says Error:2200 Will only feed paper half
Remove the jammed paper. Unplug the printer from the mains and PC. Inspect the rollers, etc for tiny paper piece(s) that may be stuck, or other debris. Try to clean rollers and make sure they are dry.
Keep printer unplugged for about 2 minutes and replug and try a test print.
Also make sure that you have waited long enough for the printer to heat up before giving a print job.
Finally, it could be an issue with the paper sensor. If this is the case, you will probably have to take the printer in for servicing..
Hope that helps!
Aug 26, 2009 | Dell 926 All-In-One InkJet Printer
Won't copy, error message 2200 pops up and says to check manual. Manual doesn't reference that error message.
Try this - turn off the printer.
Remove the power supply.
Press the power button for 15 seconds.
Then plug it back in.
That should've cleared the printer!
Apr 17, 2009 | Dell 962 Photo All-In-One InkJet Printer
Communication Error DELL 926 AIO Printer
Found on another forum. For 926 this worked great.
1. Go to Control Panel - Printers : Delete 926 printer
2. Go to Control Panel - Programs and Features : Uninstall All Dell 926 related software. There should be 3 programs. (When prompted to restart, respond to wait.
3. Rename Folder C:\WINDOWS\SYSTEM32\SPOOL\DRIVERS\W32x86 to W32X86OLD
4. Now restart your computer
5. Reinstall 926 Software.
This worked terrific for me.
Jan 16, 2009 | Dell A920 InkJet Printer
Follow these steps in order to resolve the issue:
Stop the Print Spooler Service: 1) Click Start. 2) Type ‘cmd’ in the Start Search box.Search results should appear. 3) Right-click on ‘cmd’ in the search results, and select Run as Administrator.The command window will appear.4) Type ‘net stop spooler’ into the command window and press <ENTER>.The Print Spooler service should now be stopped.
Delete the Printer Drivers: .
1) Click Start.
2) In the Start Search box, type ‘C:WindowsSystem32SpoolDriversw32x86’ and press <ENTER>.
3) Delete all the files and folders in this directory.
NOTE: If the folder will not delete, rename folder to w32x86.old.
Remove the Dell printer software:
1) Click Start.
2) Click Control Panel.
3) Click Programs.
4) Click Programs and Features.
5) Click the software related to the attached Dell printer to highlight it.
6) Click Uninstall/Change.
7) Follow through the prompts in order to remove the software.
8) Restart the computer.
At this point, the user should install the latest printer software from http://support.dell.com and be able to print successfully.
Dec 24, 2008 | Dell 926 All-In-One InkJet Printer
Communication Errors with DELL AIO 926
Well just try another cable for the connection between the printer & the computer... your can also check print spooler service under the services of the system....
Dec 24, 2008 | Dell 924 All-in-One InkJet Printer
138 people viewed this question
k24674
jasbo
jasbo
