Question about Cell Phones
I have a ZTE F852 Mobile Phone. For some time the plastic bit inside the charger hole on the phone has been broken, hence cannot charge. Is there any other way to charge this phone battery? What is the plug on the lower right back for.
pingping
  • 111 Answers
SOURCE: Razr V3i charging problem
Hi V3 is very fragile and if you use the incompatible accessories, you can ruin their ports easily. One weak point of V3 Phone is the SIM card Port is not an opening flap like other GSM phone but using pin and spring Port style which is mean you have to push your SIM card in and use the SIM Card edge to push the pin down in order to contact with SIM metal area interface. But by pushing force is varied from users so too strong and too hurry will damage the pin. If one of the pins is damaged, when you slide the SIM card in, the contact is missing of one or two pins due to damaging of the pin cause the error message "Insert SIM". In this case, only way is needed to replace the SIM Board underneath. If you can do it yourself, please follow the instruction pictures below. If you are not sure and never do this before, I suggest you send the unit to Motorola Repair Center. Your SIM Card Board and charging port will need to be replaced. http://www.itsjustmerob.com/files/V3_Razr-repair.pdf This is a Full Motorola V3 Officially Service Manual and even the Motorola Repair Center also has this one. so copy this link and print it out. Around hundreds plus pages but can be your Guide which you cannot find anywhere else. I gave it to you free but I have purchased it before. Hope that you can get it fix. Other solution is looking V3 parts on sale a lot on Ebay and use them to replace part to your phone will be cheaper if your phone is no longer under warranty. If it is still under cover then send the unit to them and don't spend time and money to do it yourself. But if it is out of warranty and want to avoid costly repair then use the method in the manual I provided you and you will be able to get your phone fix. Good Luck
Posted on May 15, 2007
ahlrub
  • 283 Answers
SOURCE: V3 not charging
it's a hardware failure,, cant fix it here ..
Posted on Apr 16, 2008
thehumble1
  • 137 Answers
SOURCE: battery charger
I'm not sure what the problem is with your phone, but this happened to me with another Motorola phone and it turned out to be a battery problem. You can try another charger, which might work for some time before you get the same result, but I believe you will need to replace the battery. You can try calling Motorola and checking to see if they will give you a discount on another battery. I've had several Motorola phones give me this same message and most of the time it was only infrequently and resetting the phone and reinserting the charger worked, but if it persists, try the battery.
Posted on Oct 07, 2008
GrinningFool
  • 625 Answers
SOURCE: env2 charger wont fit in the hole and wont charge my phone
The issue is the charger port on the ENV2 breaks fairly easily. The first step is to contact your carrier to see if it is covered under warranty. If it is, great get it replaced.
If not, you have 3 options:
1. you can get the charging port repaired. The cost is about 50 dollars.
2. you can get a new phone. cost ???
3. you can get an external battery charger to charger battery separate from phone. cost about 25 dollars. check out the following link for ones that are available on ebay. LG VX9100 ENV2 External Battery Chargers
Posted on Jul 02, 2009
GrinningFool
  • 625 Answers
SOURCE: MY MOBILE PHONE CHARGING SOCKET HAS SNAPPED
You have 3 options when the charge port breaks.
1. get it repaired, warrant if possible
2. Get a new one
3. Get an external battery charger and charge battery separate from phone. Another battery and charger will set you back about 10 dollars on ebay.
For more information and links to the parts check the following link below.
Fix for Broken Charge port on Samsung SGH-D900
Posted on Aug 18, 2009
New samsung phone. Has been on charge 40hours . Not charging
either charger faulty or phone or battery is faulty
new phone take it back for a warranty check/ replacement or refund
Jan 14, 2017 | Samsung Cell Phones
How to turn on a ZTE z812 phone that won't turn on
Sounds like the charger is broken or the phone is broken. You need to do one of two things. Put your phone on a charger that is known to work or a phone that is know to work on your charger.
The internal batteries can fail. The ZTE is 'cheap' phone.
Sep 29, 2016 | AT&T Cell Phones
My phone was working fine, I put it to charge the next day I realized was not charged
probably your fone batt is extrem low. you need to find 5volt dc source to "recharge" your batt to the minimum state so you can recharge it again using your daily charger.
Sep 23, 2015 | ZTE Boost Max Black Boost Mobile
Dropped my new zte n9130 boost mobile phone when it was just about dead . Went to charge it and no light no charge and not turning on?? Is this product a good one?
You may have knocked loose the little "plug" that your charger fits into to charge it. It is soldered onto the board inside and, and if it is no longer attached it won't charge anymore.
See if the plug jiggles a bit if you play with it when a cord is plugged in. If it moves that is a problem and means that you need a repair. Even if it doesn't move, it may just be packed in there tight but is still broken.
Sep 10, 2015 | ZTE Cell Phones
Cannot charge battery on ZTE Whirl 2
I would recommend buying a new charger. The link for a cheap charger is below.
ZTE Brand OEM High Quality Micro USB AC Home Charger for ZTE Merit Valet...
Mar 27, 2015 | ZTE Cell Phones
My cell phone will not charge
Check for the correct voltage output at the charger end. If its there, play with it a bit when its plugged in to see if while moving it around it starts charging, if it does the phone charging socket or end on charger is too loose and not making constant contact.
Aug 24, 2014 | ZTE Cell Phones
Wont charge
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
Sep 09, 2012 | ZTE Avail Bluetooth Music 3G GPS Android...
MY ZTE-Z990G WILL NOT CHARGE
First Option:
Second Option:
Jul 23, 2012 | ZTE Cell Phones
2. Get a new one
Mar 07, 2009 | Samsung SGH-D900 Cellular Phone
Charging receptical has broken off inside the phone
you both will need to take the phones in to a mobile service center and have them replaced the charging ports.
Feb 25, 2008 | LG CHOCOLATE VX8500 Cellular Phone
Cell Phones Logo
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
