I need to replace the lid switch in my Kenmore 90 series washer, model 110-22912-101 Type 111. How do I remove the cover over the timer and switches and gain access to the lid switch connection? It looks like the top trim piece is held only by two screws on the back, but it won't come loose after removing those two screws. The endpieces look like they just pop into place, but I can't pull them loose. How should I proceed?
    President:
  • 1,776 Answers
Check out the video at the following link and see if it helps you in replacing the lid switch. I sure hope it does and best wishes.
http://www.youtube.com/watch?v=fC8SY3cU1Yc&feature=PlayList&p=A8EAB62928245279&playnext=1&playnext_from=PL&index=61
Posted on Sep 28, 2009
My kenmore 90 series washer will not drain i have tried playing with the lid leaver any thing else i can do ,can i replace the leaver switch?
Yes you can replace the lid switch its fairly easy to do...this tip i wrote will help ya to replace the lid switch http://www.fixya.com/support/r9939128-whirlpool_kenmore_estate_kitchen_aid
Series 90 is unfortunitly not a model number please reply with exact model number as found on a label on the rim of the tub inside of the lid and i will give you the part number for the lid switch.
GENE
Sep 12, 2011 | Kenmore 24032\24036 Top Load Washer
My kenmore 90 series washer won't spin or agitate Model: 11022912101 Serial: cl5113153 type: 111
true. there is no belt on this model. most likely, the motor coupler has broken. very inexpensive part and fairly easy to replace if you have about an hour. the old part was all plastic and the new part has some reinforced metal in the center. these parts break easy, especially if the person washing lets the machine run off balance all the time.
Jan 12, 2010 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Washer Kenmore 70 Series Model # 110.247323000 Serial# CR3845255 Type 111 Washer fills cold, warm, hot - no agitation - no draining
IF THE MOTOR DOES NOT RUN CHECK THE LID SWITCH. IF YOU HEAR IT RUNNING YOU MAY HAVE A BAD COUPLER.
Jan 12, 2010 | Kenmore Washing Machines
It is a door switch for Kenmore 80 series top load washer model no. 110.25842400, type 111
I'm not sure what your question is but following is the Sears parts site for your washer.
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?pop=true&modelNumber=110.25842400
If you look in the top and cabinet section, you'll see a description of the Lid Switch.
If you need to replace it, you'll have to remove the cabinet first.
Following is a site with a description of how to do it.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=534500897c8bf705d91c620362438f0e
Nov 01, 2009 | Kenmore Washing Machines
I HAVE A KENMORE 90 SERIES WASHER JUST REPLACED
it mounts to the metal where the lid closes, not on the drum... there's usually two holes where the screws go through... and a third hole where the actuator(plastic post) on the lid goes through to activate the lid switch...
Sep 25, 2009 | Kenmore 24032\24036 Top Load Washer
Washer wont drain
Go to sears web site and enter model number of machine and look for lid switch. The cabinet of the machine needs to be removed to replace this switch. Go to Appliance Guru for details of removing the cabinet
Jan 04, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 90 Series Washer
You have a broken lid switch. Its # ll in the diagram. Part # is 3949238. Let me know if you need info on how to replace it, Dave www.washermd.com
Dec 17, 2008 | Kenmore 23822 Top Load Washer
Have kenmore 70 series washer model #20702991 ser #1069231 type 111 will not drain. It starts the cycle by agitating then stops and will not go to drain cycle. switch on top lid does not ckick, tried...
The lid switch must close for the washer to spin. I've seen a lot of these break where it's mounted to the top. You may still be able to reach under the top to grab the switch to close it and get it to drain. You'll almost certainly need to replace the lid switch.
Jul 21, 2008 | Washing Machines
Intermittent spin cycle on Kenmore 90 Series washer
You may try the speed selection switch.....Ive had problems with these.
Jan 23, 2008 | Washing Machines
Washing Machines Logo
340 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
