Question about Lexmark X4550 Multifunction Wireless Color Inkjet Printer
Got new MacBook computer. Printer won't show up and nothing prints. Seems like it doesn't respond at all.
Canon pixma 922 won.t print..computer says not printer not responding also says printer in error state..no printer codes showing
Depends on if you have it set up correctly for proper port config. Is it set up for USB or LPT? Check it out with PRINTERS showing printer details on driver etc.
Feb 23, 2015 | Canon PIXMA Office Equipment & Supplies
HP 5600 printer won't print
Is your HP printer having printing problems due to incorrect printer configuration and driver installation? For the quick tech assistance, you can also go to the Printer USA Support, which is an online directory, offering the certified HP toll-free number that is helpful to directly get in touch with the technicians and get your printer problems repaired in no time. HP Printer Tech Support Phone Number HP Printer Help
Apr 26, 2017 | HP Officejet 5610 All-In-One InkJet...
I just got a new computer and nothing is printing
try to install the driver of your printer..this is always seems the problem why your printer doesn't print.
Sep 18, 2011 | Office Equipment & Supplies
My printer won't print. my computer is hooked up to it, and it doesn't give any error messages. it just doesn't do anything.
Go to Control Panel/Printers. Right click on your printer's name, and hit Print Test Page. If printer prints a page out, then the problem is likely with the software you're using to print - make sure you have selected the right printer in the dropdown. If the printer's name doesn't show in the Printers folder of Control Panel, the driver for it has not been installed. Do so and try again.
Jun 18, 2011 | Lexmark X2670 All-In-One Printer
My wireless will not connect to my macbook
First two are mentioned here,
1. wireless
2. usb
if you are using a USB cable to connect, first you have ensure that is system is working perfectly and turned on, secondly make sure u have the printer turned on after proper connection with your usb to your computer from the printer, this is suppose to pop up a message demanding for printer driver installation.
If it does not respond, you have to check your USB port on your system or the USB cable. check these i believe one will certainly work for you. thanks gud luck.
Oct 07, 2009 | HP J4680 Office Jet All-In-One Printer
MacBook Printer Problem
If you have OSX, the computer already has the drivers, do not use the ce, just connect the printer via usb, make sure the power cable is connected, turn the printer on, restart the computer.
After the reboot, go to the apple in the top left, select SYSTEM PREFS, select PRINTING and FAX, add a printer based on the model number. That should do it, if not, let me know, you may need 2 more steps.
Aug 24, 2008 | Apple MacBook Mac Notebook
EPSON STYLUS CX3900 MacBook MacOS x tiger
I use the CX3800 talking to a printer connected to a PC on a network and it seems to work fine. You can also download drivers from OSX from epson's web site
Jan 08, 2008 | Epson STYLUS CX3900 All-In-One InkJet...
Lexmark X4550 Multifunction Wireless Color Inkjet Printer Logo
113 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
