Heating & Cooling Logo
Posted on Sep 28, 2009
I have a question about the dual hose comfort-aire
I was lent the unit for the weekend and do not have a owners manual so I am unsure if I am operating it correctly
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Sep 28, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
66
Points
Does anyone know the capacitor I need for my Armstrong Comfort 1000? Model number SCU10G60A-1
If you look at both the fan and compressor data plates the will say mfd ratings. Not the unit data plate but motor data plates.
1helpful
2answers
Bought home with comfort zone II thermostat. Want to change all settings. It won’t let me Keeps reverting back to the ones the previous owners set
If you want to manually control the temp, not running the program, press the hold button. If you want a new schedule, read the manual.
Humidifier gets ice on top of cabinate. It still produces water.
Most dehumidifiers have a defrost cycle that they run through, as needed. But, apparently, your is not functioning. Eventually, yours will stop collecting moisture, if this continues. In the interim, I would suggest turning the Master OnN/OFF Switch to OFF and unplug the unit until it thaws. While it's unplugged, remove and clean the air intake filter on the front of the unit. If it's clogged it causes the unit to strain and may cause it to ice up. Once the filter is clean and the unit is un-thawed. Plug the unit back in and turn the Master ON/OFF Switch to ON and set the controls as you normally do. Hopefully, that period of being unplugged will have allowed the unit to reset itself and work properly.
I have included a link to your Owners Manual that you can download and print for future reference.
aire.com/index.php?option=com_rubberdoc&view=doc&id=436&format=raw">http://www.comfort-
If the above link fails go to the following link below and click on Owner Manual, near the top of the page.
aire.com/room-air-conditioners/149-portable-dehumidifiers/122-bhd-301-g">http://www.comfort-aire.com/room-air-conditioners/149-portable-dehumidifiers/122-bhd-301-g
Hope this helps you solve the problem.
7helpful
2answers
Where is the location of the thermostat on a 1997 Nissan XE 2.4 Liter engine? Is it top or bottom hose? It sure would be nice to find a free download of the engine's diagrahm without me having to buy a...
It's the bottom hose. I just changed mine this past weekend. Take the power steering pump bracket loose and fold the power steering pump back. Can get to the lower hose and thermostat housing then. Make sure to bleed the air out of the system when starting the truck after replacement of thermostat. The bleeder valve is a bolt on the housing where the upper hose attaches.
For air conditioners is also stay at 64 i dont go up or down whit the remote why
Please elaborate! I'm unsure if your A/C will not change temperature without the remote. Some units have a "lock" which if set, will keep the unit at the same temperature & if it's only not working with your remote, my guess is that your remote is bad or the batteries are dead or placed in it incorrectly (or may have leaked & ruined the remote.)
Top Comfort-Aire Heating & Cooling Experts
Mike Cairns
Mike Cairns
ADMIN Andrew
ADMIN Andrew
Arnie Burke
Arnie Burke
Are you a Comfort-Aire Heating and Cooling Expert? Answer questions, earn points and help others
